Question about Sony KP-51HW40 51" Rear Projection Television
SONY KP53HS30 rear projection TV screen suddenly turned blue....
Its as if the settings have changed to make everything have too much blue color. Adjusting the colors on the menu screen has not helped. Its also started blinking 5 times which means something, but what? Any ideas? Thanks!
  • 3 more comments
  • greg1957 Mar 25, 2008
    I HAVE A SONY 51" REAR PROJECTOR. THE TV WILL TURN ON FOR ABOUT A MIN. THEN GOES OFF. THE COLORS ARE NOT LINED UP AND THE PICTURE IS TO HIGH ON THE SCREEN. ALSO RED LED IS FLASHING A CODE 7.
    THANK YOU FOR YOUR HELP
    GREG GORDON
  • jpecotter Jul 26, 2008
    My tv screen has a outline of blue around the edges
  • deborah39uk Dec 10, 2008
    my t.v went blue and i`ve notthink now, how do i repair it or isnt it worth repairing
  • darius10 Dec 10, 2008
    Hi
    I still have a picture but everything is blue. What needs to be fixed?
    Thanks
  • davenportcmd Dec 10, 2008
    when i turn the tv on the picture is fine as the tv warms up the red and green bulbs go dim. and they just don't stop dimming. then they just go dead. so the only bulb on is the blue one. any ideals on how to fix it or if its worth it.
  • 84 Answers
The blinking 5 times is an error code meaning that the white balance has a failure. And because you are experiencing a blueish screen then your problem lies in the circuit of the blue picture tube or possibly the blue tube itself is starting to go bad.
C-Dog
Posted on Feb 10, 2008
Hello - I love my Sony and do not want to have to get rid of it; the problem that is happening is, my Sony KP53hs30 has horizontal lines flickering through the picture. Any suggestions?? Thank you...
Hello this is an indication of a CRT in the set about to go bad, depending on the color of the screen you can tell which one. Also behind the speaker is a sreen and focus block, these can go bad over time or get out of alignment especially when the set has been moved. You can try to turn the control down or again depending what color the line are, will let you know which knob to turn.
Sep 24, 2011 | Sony KP-53HS30 53" Rear Projection...
I have a 2001 sony 53' rear projection tv model #KP-53HS30. It seems has a wavy section on the upper left hand corner and lower right hand corner of the screen. All the bulbs are working fine but seems...
Try this. The follow was found on tv-forums dot com by Zyntar...
There is a secret service menu to converge the Sony KP53HS30.
Caution: Be careful, there are many settings that can be tampered with. Some may be hard to undo.
Procedure: (use the remote control for these steps unless noted)
1. Turn TV off with System Off (under flap on remote)
2. Press: Display, 5, Volume +, then Power. If successful, service text will appear on the screen.
3. Use 2 & 5 to select the PJE Category.
4. Press 9 to get to fine convergence adjusting.
5. Press 6 several times to get the convergence screen of choice. I like the grid.
6. Use the remote's arrow keys (joystick), move the brackets around until you have found the area to adjust. Press the center of the joystick to change the bracket from white to a color. Use the joystick to adjust the color. Press 3 to change color to adjust. When done, press center of joystick again.
Note: Try to keep the grid even and squared up.
7. Repeat steps 5 and/or 6 for all parts of the screen that need it.
8. Once done, you need to save your settings. Press: Mute, Enter. Then on the TV, press "Flash Focus"
9. Turn off power.
TV is ready to use.
Oct 20, 2010 | Sony KP-53HS30 53" Rear Projection...
Picture looks concave. Words, people, everything
You have a convergence malfunction.......the convergence ic's and the protecter picp fuses in the power are will need to be replaced by a qualified perso. A reputable shop may charge around $300 to repair. If you have technical ability,I can guide you further to repair yourself as well
Jun 06, 2010 | Sony KP-53HS30 53" Rear Projection...
Pink,blue,green colors only on sony kp53hs30
U have one color gun is dead.The red color gun is gone.
Jan 05, 2010 | Sony KP-53HS30 53" Rear Projection...
Convergence problem, how to fix with my remote?
9. Turn off power.
TV is ready to use.
Jan 19, 2009 | Sony KP-53HS30 53" Rear Projection...
Sony KP53HS30 Picture Problem
correct, both ICs would be replaced for better performance of TV.
Dec 26, 2008 | Sony KP-53HS30 53" Rear Projection...
Sony KP53HS30 projection tv looks 3 d
You have a convergence problem, was it moved lately? Did you try the convergence setting in the customer menu?
Nov 25, 2007 | Sony KP-53HS30 53" Rear Projection...
Sony tv KP-61HS10 lenses wont align
This is common in those sets. One of your convergence IC's has stopped working and needs to be replaced. The convergence IC should be replaced and the convergence circuits realigned by someone with experience in Sony projection sets.
Aug 09, 2007 | Sony KP-61HS10 61" Rear Projection...
Yellow brush marking on Screen
Your problem is with the blue color,maybe some dirt is sitting on the face of the blue crt and is being projected bigger to the screen,you should try cleaning the face of all 3 tubes,if you familiar with tv service this should help,be careful when removing the back and make sure the set is unplug when you do the cleaning.Let us know how it goes.
Oct 06, 2006 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Sony KP-51HW40 51" Rear Projection Television Logo
408 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
