Question about Canon PIXMA MP830 All-In-One InkJet Printer
  • 1 more comment
  • bingogammy Feb 16, 2008
    I keep getting an error that I have more than one of the same ink tank. Its not accurate and I can't print anything as a result
  • Tim Craig Feb 20, 2008
    We have experienced a similar problem where the printer says there are 2 magenta cartridges installed which is not true (I also noticed when opening the carriage tray that the yellow cartridge was flashing, not the magenta).
    We have replaced both the magenta and yellow cartridges and installed them in the correct slot, but after working okay for a short time soon received the same error message.
    I purchased the Canon after owning 2 HP printers (never had this problem with the latter) and hope this can be corrected without replacing hardware.
  • Anonymous Feb 22, 2008
    I also get error code U150, following tank cannot be recognized. It is always the first, thin black tank. I cannot get the pronter to work???
Had the same problem - apparently a certain batch of these printer have a fault with the mainboard - mine was replaced under warranty and now the problem is solved.
Posted on Feb 13, 2008
Canon mp830 service error 5c310 alarm light keeps
You need to clean your waste ink i think. For troubleshooting purposes, please perform the following:
1. Open the printer and remove all ink tanks.
2. Insert a single ink tank in the printer then close the cover.
3. Confirm whether the printer recognizes the installed tank
properly. If it does, it will indicate it does not detect the other ink tanks, as
they are not currently installed in the printer.
4. Repeat steps 1-3 with another ink tank.
5. If the printer at any time indicates two of the same ink tanks are
installed, the cause will be the last tank installed. For example, if
you inserted an ink tank earlier, and you later inserted another ink
tank, and it said two of the same inks were installed, the cause of
the issue is the last ink tank.
May 17, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Error code U071 , more than one ink tank of te following color is installed, is the message on the screen. This is not the case as each cartridge is different and correctly installed?
Error U071 : More than one ink tank of the following color is installed. U071.
Action : Confirm that the ink tanks are installed in the appropriate positions.
The machine will not print if the wrong type of ink tank is used, or if it is installed in the incorrect position.
Be sure to install the ink tanks in the correct order. The proper arrangement from the left is Black (CLI-8BK), Black (PGI-5BK), Yellow (CLI-8Y), Magenta (CLI-8M), Cyan (CLI-8C).
Hope this hepls.
Nov 28, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Need to replace ink cartridge
Replacing the five ink tanks (cyan, yellow, magenta, black dye, and black pigment) is a simple task. The top of the printer flips up to reveal the ink tanks and the printheads, and by flipping a lever, you can pull out each tank individually. Being able to replace individual tanks is a boon, as you won't waste colors you use less frequently. Also, you won't need separate photo ink to print photos, which we appreciate. Canon ships the Pixma MP830 with full ink tanks. Replacement color and dye-based black ink tanks cost $14.25 apiece, while the pigment-based black ink tank costs $16.25. Canon estimates the cost per page for both black text and color text to be an inexpensive 2 cents.
May 31, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer, ERROR MESSAGE
Have you checked the ink tanks to verify that they are OK. If 1 of them is empty that could trigger the messages. Look in the user's guide starting at pg 161 for a list of messages. let me know if you need any further assistance. i've pasted the user's guide address link just in case you don't have it.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
May 23, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Printing Cartridge error
I've seen this problem before and it turned out to be a faulty chip on the cartridge as opposed to a problem with the printer. Canon should replace the cartridge free of charge if this happens.
Nov 26, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Trying to reset chip on refilled ink tank on CANON MP830
Looks like has a chip resetter for the CLI8 color cartridges, but I don't know if that unit will reset the big black PGBK cartridge in the MP830.
Nov 03, 2008 | Canon PIXMA MP780 All-In-One InkJet...
More than one ink tank BLK (5) Installed....
Hennie Youngman told this joke:
"I solved the parking problem in NYC." (He played the violin briefly at this point)....
"I bought a parked car."
I solved the Canon ink tank problem... I bought a new Canon ink tank.
Just how many non-working tanks am I subject to get in a lifetime is the question.
Sep 16, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon IP5200 printer - "duplicate ink tanks"
Hi i have Ip 5200 but the pawer lamp and yelow lamp are blink
Mar 26, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
I have a cannon mp830 wont print
Solution: Insert one of each color ink tank MP830
New Page 1 More Than One of the Same Ink Tank is Installed When installing or replacing an ink tank, only one of the following ink tanks should be installed. If the ink tank is not installed correctly, an error message will display. mp500_inktankorder.gif
  1. Confirm that the printer is powered on and press the Open button. (The paper output tray will open.)
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
    Note: When the scanning unit (printer cover) is opened more than ten minutes, the print head moves to the right side. If this occurs, close the scanning unit (printer cover), and open it again.
  3. Open the inner cover.
  4. Press on the tab to release the ink tank, then remove it from its slot. If you are replacing multiple ink tanks, make sure to replace one by one.
  5. Insert the ink tanks into the print head. Note: Press the mark "PUSH" on the ink tank firmly until you hear a click.
  6. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    <7> The ink tanks are installed properly.
    <8> The ink tanks are not installed properly.
    Note: Ink Tank LampYou can check the status of each ink tank according to the way its lamp flashes.
    • - On: The printer is ready to print.
    • - Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
    • - Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
    • - Off: An error has occurred and the printer is not ready to print.
  7. Close the inner cover and the scanning unit (printer cover). Note:
    • When closing the scanning unit (printer cover), be careful not to jam your finger.
    • When starting printing next time, the print head cleaning launches automatically.
Jan 18, 2008 | Canon IMAGERUNNER 6570 Copier
Canon PIXMA MP830 All-In-One InkJet Printer Logo
old marine
old marine
