Question about Kitchen Ranges
Repair/replace Door Hinge of my Admiral Stove
The left door hinge of my Admiral oven broke at the rivet. The Stove is 25 years old, model E2D79. How can I remove both parts to replace it with a new one, and do I need to replace the spring? The panels ofte stove and the door need to be removed, correct, how do I do that?
aborcass
  • 2651 Answers
SOURCE: I have a Maytag Model
no need to remove the side panel, the door itself lifts off the hinges, and it will be reall obvious, if its broke, theres no servicing it just replace, and its done from the fornt, 2 screws and the hinge falls into the unit ( can grabit from pulling out lower storage drawer. part number (74011141) , might as well replace he 2 hinges one broke whos to say the right one is gonna last much longer
Posted on Dec 07, 2008
SOURCE: Left side oven door spring broke. Maytag MOd. MGR 5770ADW
no,no the side. but the broiler drower, remove it and look on the left and right sides. that's where are they are.
RepairClinic
  • 32 Answers
SOURCE: I have admiral Stove top burner is workni but oven is not working
This may be due to a bad main clock/electronic control but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance. If possible use the meter and the wiring diagram to check input/output voltages looking for discrepancies between the diagram and the actual meter readings.
Go here for Admiral Stove Parts: http://www.repairclinic.com/Admiral-Range-Stove-Oven-Parts
www.RepairClinic.com
Posted on Feb 03, 2009
heavyice
  • 374 Answers
SOURCE: My Beaumark Stove is from
there is a lock for each hinge
lay the door down with hinges facing up.take a towel pull long piece
of hinge toward you(BE CAREFUL) take other piece up and lock them together do the same to the other hinge it should then go on easy next time lock before taking off .These are the instruction on how to remove and replace the door, be sure you locate the removal pins to being able to put it back
This [link] http://tinyurl.com/kogjg3 should help you out.[link] http://tinyurl.com/mzgjtq is added to the hold the hinge in place on the self clean doors. The screw and bracket have to be removed to remove the door and hinges. The metal clip bracket has to be reinstalled once the door is put back on. To reinstall the [link] http://tinyurl.com/mszglp just do the opposite, start the hinge blade in the receiver, lift slightly on the door and with your knees push the door and hinges back into place. One thing most people forget about these hinges is that there is a clip that must be moved to hold the upper (A) and lower (B) parts of the hinge together. Once the door is put back on, the clip must be put back in the rest position. To reinstall the door, put the door at a 80degree angle to the range front, push in the larger upper hinge parts first and then lower in the smaller hinge parts, push the clips forward into the rest position and close the door.
On this [link] http://tinyurl.com/lg76wg one common problem is the hinge will sometimes "pop" forward against the range instead of staying still while you reinstall the door onto the hinges. If this happens, use a screw driver at the marked spot to help hold the [Link] http://tinyurl.com/kren2c so you can start the door onto the hinge, them remove the screwdriver to finish installing the door.
I hope it helped.
Posted on Jun 11, 2009
ameliorate
  • 19 Answers
SOURCE: Who can replace a Admiral stove glass top?
i cracked mine too. the tops cost enough to make you just wanna buy a new stove.
Posted on Jul 16, 2009
Eletrolux wall oven modelE30ew7cgps2 change door hinges
The hinges mount inside the oven door, open the door all the way, then move the small clips that are riveted to the hinge to the position opposite of where they sit now... this will hold the hinge springs open. Lift up the door as if to close it, then the hinges will lift out of their slots and you can remove the door... Electrolux Range Stove Oven Door Hinge 318244305
Jun 24, 2016 | Electrolux 30" Built-In Single Electric...
My frigidaire microwave door is sagging and is about to fall off
You will need new door and hinge replaced
send model # for price quote
May 13, 2015 | Frigidaire PLMV169DC Microwave Oven
Oven door keeps open ay ideas about the fault cheers
make this test and fix it. GOD BLESS YOU
Door Hinge
An oven door repair may be needed if the door hinge breaks or is bent out of shape. Oven doors have two door hinges, a left and right. On some ovens the same hinge is used, on other ovens the right hinge and left hinge have different part numbers. The door hinge sometimes is sold with all necessary parts and springs, other times the parts need to be ordered separately. An oven door repair for a door hinge is a relatively easy repair for a do-it-yourselfer.
Enter your model number to see parts for your range/stove/oven.
Help me find my model number
Outer Door Glass
If the outer door glass is broken, it can be replaced. This oven door repair requires that the oven door be removed from the oven and layed down on a sturdy flat surface. The outer door glass is made of tempered glass. Use eye and hand protection when performing this oven door repair.
Nov 04, 2013 | Kitchen Ranges
Frigidaire microwave door fallen off
I had the same problem. I removed the door and used a rivet tool. I checked to make sure the door cleared the rivet head, which was nearly flat, so there would not be any microwave leakage.
Jun 28, 2009 | Frigidaire GLMV169D Microwave Oven
Oven door hinge detached from the oven
Pull the door completely off and re-insert the door on the hinge supports.
May 23, 2009 | GE Ovens
Dislodged oven door, can't re-attach.
All oven door hinges have small grove or tooth that must be engaged to opperate correctly.
Reinsert hinges one at a time, noting there is a small "tooth" or "gap" on each hinge.
This gap must engage with the lower part of opening in which you place door hinges. When you engage one tooth, do same on opposite hinge. Door now works correctly.
Apr 17, 2009 | Kitchen Ranges
Oven Door Hinge Squeaks
its not the hinge,,its the sping in the hinge,,you have to replace it,,,be careful with ludes on stove...onthejob
Dec 20, 2008 | Magic Chef 31000 Gas Kitchen Range
Loose microwave door
My over the range microwave had a loose door, it sagged when it was open but you could lift it to close. Called repair person he said no it could not be fixed. You could see the bottom hinge was loose and slipping. I loosened 3 screws that holds the bottom on the microwave -you have to do this to change the light bulb also. The bottom hinge on the door was loose there was a hole there, so took a screw and nut to hold the hinge in place..I am a 70+year old woman-if I can you can.
May 14, 2006 | KitchenAid KEMC377K Convection / Microwave...
Kitchen Ranges Logo
252 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
