PANASONIC PT-52WX42F Hey techman, Check out my post. You helped someone with a similar problem. Originally when I started researching this online I thought the power light was only blinking 3 times. I could have been mistakin but the following day when I really looked at it, it was blinking 5 times. So, I don't know if I compounded the problem or not. The only response I have gotten is "5 blinks = IC4011 however doesn't always mean ic is bad." from ctf1800. This isn't much help unless I know what an IC4011 is and where to order it. I thought I read that you had a digital copy of the repair manual. I was wondering if you would email it to me? Thanks, Tyson
  • 59 Answers
SOURCE: panasonic projection TV power blinks in orange 5 times every 5 seconds
did you ck the lamp,  can you ck voltage to ballast should be around 300 volts
Posted on Oct 23, 2007
SOURCE: NO PICTURE, NO SOUND, TV TURNS ON THEN TURNS OFF
STOP THE PRESS!! I FIXED MY TV for a whopping $26.
I took a wild shot and purchased two STK392-110 convergence amplifiers from http://www.electronix.com/. They ship fast, placed my order on Tuesday evening after coming here and placing my comment. To my suprise the parts were in my mailbox on Friday. The parts were actually $12 but I also picked up a iron and a solder sucker.
So rarewish4us, If you're in the South Florida area I'd be more than happy to take that "JUNK" off your hands. LOL
If I were you, I'd give it a shot before you junk it.
Good luck,
Howie
Posted on Feb 09, 2008
  • 1779 Answers
SOURCE: DLP Powering Off after 5 minutes
Chances are the cooling fan for the lamp is bad, or the temp sensor for the lamp might be defective.
Posted on Mar 07, 2008
Slinteriors
  • 8617 Answers
SOURCE: PT-47WX54J 5-blinks between pasues - no audio or video
IC4511 is defective when the led blinks 5 times. that part is unavailable so you will need the entire circuit board.
Posted on Jul 19, 2008
Slinteriors
  • 8617 Answers
SOURCE: panasonic Pt-53TW53G projection tv
5 Blinks means IC4511 thats located on the DG board which is the small board on the left side in front of the signal board looking in from the rear of the set.
Posted on Oct 31, 2008
Car is jerking and the engine has come on but it has oil and transmission fluid in it
We had an issue with our 2005 PT Cruiser. The check engine light came on and had trouble starting. Once it did start it would buck and sputter. I did some research on the web and found similar problems. From what i found it is the cam shaft sensor. This happened yesterday. We are getting it checked today. I won't go as far as to tell you this is exactly what it is, but it is a good place to start. Hope this helps!
Aug 12, 2010 | 2004 Chrysler PT Cruiser
Black screen
how many times does the red light flash?
Techman
May 16, 2010 | Panasonic PT-53WX53 53" Rear Projection...
Remote control programming code
you can look up all the different codes in the remote manual. if you do not have that look up the codes for the brand of remote online or turn on the set and put the remote in the aearch mode and you might be able to find it that way. kind of dificult to tell you without the brand of remote you have!
techman
May 08, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic Projection HDTV
Hi odd johnny,
My sincerest apologies. My area of experience with Panasonic models are rather limited to diagnosis and power supplies. May I recommend instead hdtv_guru, techman or terryfic who I consider more knowledgeable and experienced on convergence circuits.
Nonetheless, I appreciate you bringing your concern to my attention and wish I could do more.
I have taken the liberty of pre-informing these gentlemen of your concern.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 25, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-45LC12 45" tv
Post yor zipcode I may be able to help you out.
Feb 19, 2008 | Panasonic PT-45LC12 45" Rear Projection...
Panasonic PT-47wx53 screen converged to middle of screen
This sounds like a classic High Voltage problem. Yes the two issues are related. Something in the High Voltage circuit has failed and originally caused the increased size. If you described the problem to the warranty people I'm surprised that they didn't recognize the problem and fix it under warranty. Now you have a short or partial short in the same circuit causing the fault (light blinking) after a few minutes. This problem will not cure itself. As I have told customers in the past "Electronics are not human and will not heal themselves". Maybe in the future, but not yet. You need a technician and it should be covered under warranty if things are as you described. I would recommend calling Panasonic customer service. They are usually a very good customer oriented company.
Nov 05, 2005 | Panasonic PT-47WX53 47" Rear Projection...
Televison & Video Logo
63 people viewed this question
Top Televison & Video Experts
