Question about Mintek MDP-1030 Portable DVD Player
It won't spin
It's turned on, but when disk is put, it loads we can hear something like it's spinning but it's said no disc, when it's opened it's not spinning
    Champion:
  • 207 Answers
Oh no!!! that's bad dude!! have it checked to a liscensed technician since the player is malfunctioned. This is one of the most common problems with players especially if it played for long hours..
Posted on Feb 05, 2008
I purchased a toshiba portable dvd player and the disc is not spinning therefore reads no valid disc. I have put in a few discs still same reading? Any suggestions?
Hello
The Sled Motor is defective. this is the motor, whic spins the disc as it has been loaded properly. If the loader mechanism loads the disc properly into place and if the catch up magnet catches the disc in place, and still the dis do not spins, replace the sled motor. OK.
Feb 28, 2012 | Toshiba SD-P1900 Portable DVD Player
My CD player keeps displaying no disk and wont play the cleaner disc, is something dirty or broken?
Hello
If it does not play the cleaner disc, just inspect whether the disc inserted in spins inside it. You can check this by open the upper cover of the player, and inserting a disc into it. If inserted disc spins inside, and the player won't read it, the fault is with its laser pickup unit, and it should be replaced with same type and number.
If the disc dos not spins, the fault is with the sled motor [the motor that spins the inserted disc], has damaged, and should be replaced. OK.
Dec 25, 2011 | Sharp Audio Players & Recorders
When loading a dvd it displays, "NO DISK". Is it
Hello
There are mainly three motors for most of the DVD players. One to spin the disc we insert in, other to load the laser pickup unit to-and-fro inside it to read the disc and an other one to load the tray mechanism 'in-out'. According to your description, the disc spins inside, and you can hear its spin. So motor which spins the disc has no trouble at all I should say. Then comes to the second motor that moves the laser assembly inside it. If it do not work, the laser pickup unit won't move and no reading will take place and 'No Disc' display will be the result. The last chance is with Laser Pickup Unit itself. Just get this unit repaired by any well experienced service technician or by the authorised service center, because, there are special tools to open this unit. As it is a compactable one, more care should be given to it while repairing. Suspect the second motor I described earlier, and the Laser Pickup Unit. OK.
Jun 14, 2011 | RCA DRC628 Portable DVD Player
I have a Polaroid pdm-08228bd that whenever we put
when you open the cover for the DVD you will see the laser ..its a small lens like device mounted on a spring like assembly .. you can manually clean that laser with a soft paper towell soaked in eyeglass lens cleaning solution .. dont spray the solution on the laser directly .. make sure the spindle spins freely in the center where the disk mounts ... when you close the lid and turn power on you should be able to hear the disk spin .. if you can hear it spin and hear some clicking but still wont play then you likely have a worn out laser .. unfortunately the cost of installing a new laser is often greater than the cost of a new DVD player ...
here are a few models that might be worth looking at ..
http://www.consumersearch.com/portable-dvd-players?gclid=CITHuImPjaICFchD5godvmnzUw&ef_id=1953:3:s_241d3be5bdd1ae954a703c1c03b3e8bb_3674119072:TAxys0NIYWYAAGzz04MAAATA:20100607041651
Jun 07, 2010 | Polaroid PDM-0723 Portable DVD Player
No matter what disc I put in it wont play and Bad Disc comes up on t.v. I know the movie discs are good ones.
Hello marciafoxmar,
If you know for a fact that the discs you are putting in, then there is obviously something wrong with the DVD player. When you put a DVD in your player, can you hear it spinning the disc at all? If your DVD is not even spinning the disk, I'm afraid your DVD player might be toast. If it does spin your discs, try a lens cleaning disc (available at pretty much any home electronics store or large chain store that sells home electronics). If that does not help, let us know and also let us know if you would be comfortable opening your DVD player.
Mar 02, 2009 | GoVideo DV2150 DVD Player/VCR
My Sony DVP-cx995v stopped playing DVD's
I had the same "Cannot play" problem - happened suddenly, I don't think I was doing anything unruly at the time.
After checking repair (exchange) prices in excess of $250 from Sony, I decided to open the cover to see if I could see anything wrong - normally a futile exercise with electronics except that in the past I have cleared errant disks that have lodged themselves near the drive/player at the rear of the library.
Upon opening and watching the library try to load and play I noticed the drive itself was not spinning the disk once loaded. It would sit for awhile, thinking about it I'm sure, then would unload and load the next dvd, again failing to spin.
I thought okay, maybe try to spin the dvd while in the player to see if it's jammed or otherwise hard to turn. It was not hard to turn and spun freely. In fact, when I put my finger through the hole at the exposed side of the player at the hub to spin the dvd, clockwise, it suddenly started to spin - and play!
I put the whole thing back together to test and all seems to be working fine at this point. Not sure what would cause the motor to stop spinning and remain in that state through poweroff/on cycles etc. but I'm sure this is not the last time I will have trouble of this kind.
I would note that when replacing the library back in its home on the shelf, be careful not to tip the library, especially toward the player area because the disks will spill out of the carousel near the player and become jammed when you power it on and attempt to load. A final tip of the library away from the player area may clear this if you hear the disks rolling out of their slots and you don't want to open the top again (it's a darned heavy box when fully loaded).
Jan 05, 2009 | Sony DVP-CX995V Multi-disc DVD Player
My PS2 won't spin a disc
try both audio and game disks if it will not turn the disks then the motor hub on the ps2 is shot if it will play the audio cd and not play the game then the laser is out of alignment but if you hear it spinning it could also be a burnt out laser as well further information would be required to diagnose this issue further.
Nov 30, 2008 | Sony PlayStation 2 Slimline Console
Ps3 wont read any disk
If you can't hear the disc spin it means that the lens is gone.
Purchase a mechanism KES-400 AAA and replace it (if you do not have warranty).
If the disc spins and does not load it might be the blu ray board. I have one with the same issue and I don't know how to pair a new board with the existing motherboard.
Sep 23, 2008 | Sony Playstation 3 (PS3) Console
Disk wont spin?
If its still under warranty, and the seal hasn't been cracked, contact Microsoft.
Try what hijackthis1 suggested, if that doesn't fix it, try this.
Since you have the 360 apart, and the top cover off of the dvd drive, here we go...
There's a circular cut-out that's glued to the top cover that you removed from the dvd drive, right below the sticker with all of the drive information. I was able to pop out the cut-out. After that you now have (3) pieces in your hand, the cover, cut-out, and a plastic piece.
Connected the dvd drive back in the 360 with the top cover off.
Put a game or movie in the drive, don't hit the eject botton, just put the disc in the tray.
Now with the disc in the tray, put the plastic piece in the center of the disc. Its magnetic, so it should kind of lock in to place.
Connect the power/av cords in the 360 and turn her on.
You should see the disc try to spin. (It may spin once or a couple times around, but it will stop). When you see the disc start to spin, GENTLE, spin/turn the disc in the direction in wants to go. It should load the game or dvd with no problems.
Reassemble the cover and put back on the dvd drive.
Now use the eject botton, and try games and dvds.
If disc fails to spin, do process over again.
I've done this with one of my 360's with no problems.
The drive I used was an Hitachi 0059DJ.
Dec 24, 2007 | Microsoft Xbox 360 Console
Portable DVD player not spinning says no disc
Check to see if the disc is spinning. You can do this by one of two ways either
  • a:) Listen for the disc to spin after inserting it or
  • b:) Place disk in drive right way up (so that the label is not upside down). Load the disc and eject the disc again to se if the disc has moved i.e. the writing may now be upside down.
If the disc does not spin then it is likely that there is something wrong with the disc motor. If it does spin then the issue is more likely to be with the laser unit. Try cleaning the lens but if this doesn't help it's likely to be a more serious and ultimately more expensive problem.
Hope this helps
Feb 02, 2007 | Centrios EDW8020 DVD Recorder
Mintek MDP-1030 Portable DVD Player Logo
61 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
