Rolex Submariner 16618 Wristwatch Logo
Posted on Jan 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Starting a stopped automatic wrist watch - Rolex Submariner 16618 Wristwatch
Arturs Kalnins
Level 3:
  • Master 2,338 Answers
  • Posted on Jan 07, 2010
Arturs Kalnins
Master
Level 3:
Answers
2338
Questions
9
Helped
1813631
Points
13579
Unscrew the crown and wind it, then screw it back and twist/spin your watch. If this does not restart it going, then there is mechanical problem in movement and you will need watchmakers help.
1 Related Answer
Anonymous
  • 2501 Answers
  • Posted on Feb 07, 2011
SOURCE: Fossil blue bq9307 Watch stopped, how
If it an automatic watch, it usually marked as such on the front or back.
To wind a self winding watch, shake it gently from side to side for a few minutes.
This type of watch thrives on use and if left off for more than 2-3 days it will stop.
I currently have a Relic ZR11971 automatic skeleton watch and earlier this week, I noticed that it had simply stopped working. The "Pendulum" will not move unless I swivel the watch back and forth a couple...
You watch is automatic , which means as long as it's on your wrist and moving it will run. If you have it on your wrist and shake it a little then stops , then it will most likely need internal cleaning. Unfortunately nowadays watch repair shops charge around $35 - $45 to do this task. That's the price here in Florida, I am not sure where you live. I hope this helps
Marcelo
Oct 23, 2013 • Watches
tip
HOW TO START YOUR AUTOMATIC WATCH
mcdevito75 here,The Automatic feature in your WATCH consists of a counter-weight attached to the MAIN SPRING by a gear that allows a SLOW but steady wind of your watch with the motion of your WRIST, ARM. Once, only in HIGH END watches, today almost all watch manufacturers have this feature in some of their models. Everyone who owns an AUTOMATIC watch knows, you can START your AUTOMATIC watch by WINDING THE STEM and you can continue to wind the stem with no end. This will at least START your AUTOMATIC watch and, this is true to some extent BUT, does this apply to my watch you ask?, Here"s how to tell if your AUTOMATIC watch will START with a few winds of the stem or not. ------- Very Simply, Hold your AUTOMATIC watch to your ear and wind the stem, if you hear a sound as though something is DRAGGING or the stem feels slightly stiff one way you wind the stem and you hear a clicking sound when you wind in the other direction, then you have the TYPE of AUTOMATIC watch that will start with a few winds of the stem, approx, 20 turns or winds. If on the other hand you hear nothing when you wind the stem and the stem feels very loose when turnning then you have the TYPE of AUTOMATIC watch that winds only with the motion of your wrist / arm, to start this type of AUTOMATIC watch, simply hold the watch in your hand and rock your watch back and forth, say from the 12 O"clock to the 6 O"clock, and or, Hold your watch securely in your hand a make circular motions with your hand, any movement to get your watches counter-balance to turn and thus wind your watch. Approx. 1 minute of this extra motion will start your AUTOMATIC watch, then simply wear your watch and your wrists / arm motion will keep it wound.
on Jul 06, 2010 • Watches
How do I start a breitling automatic watch
Automatic watches are powered by the movement of your wrist.
Twist your wrist from side to side should start the watch.
IT IS AN ORVIS AUTOMATIC AND IT STARTS AND STOPS AND DOESN'T KEEP CORRECT TIME.
Thank you for contacting FixYa.
When you first receive your automatic watch, you must give the watch an initial pre-wind. If you wear it everyday, it will continue to wind itself on your wrist when you move around and walk. If you stop wearing it for more than approximately 2 days, the watch will need to be reset, but will then automatically wind itself once you start wearing it again. The disadvantage to this is pretty clear. Your watch does not t keep time if you do not wear it constantly. The advantages are that you will never have to replace a battery, the watch keeps great time when it is running, and most of all, this type of movement is exactly what the originals use! If your Automatic is losing or gaining time in a 24-hour period the watch needs to be adjusted. All of our automatics have an adjustment screw on the movement just like the originals. Any local jeweler can service these watches.
Best regards! Jewel
My tag heuer link automatic stopped working what could be wrong with it
Assuming the watch wont start when worn then its time to get a specialist watchmaker to investigate.A premier watch as you have will need regular servicing at 3-5 year intervals.try www.rolexrepairs.co.uk they will provide a free estimate and operate a fully insured postal service.
WILL RUN A SHORT TIME THEN STOP
mcdevito75 here, I would imagine your Rolex is an automatic, not all Rolexes are. After 2 days not running at all your Rolex needs a very good start not just putting it on and that"s it. Sorry to say!, I would ask you to do this, With your watch close to your ear I would like you to wind the watch, listen closely, if you haer a clicking or a drag sound you know you have to give about 20 winds to your watch before you put it on, after the 20 winds the automatic takes over. If the stem just spins and no sound, Click or drag, then your rolex is fully automatic, after you put it on you"ll have to ttwist your wrist back and forth to get the automatic moveing to wind your watch somewhat. Twist your wrist back and forth maybe 20--30 times, this way your watch has an initial wind and as you wear it the winding continues with the motion of your wrist, after it"s wound pretty good if it stops and goes, have the watch serviced.
Watch winding is not holding
Two words: Wind it! When any self-winding (automatic) watch runs down from not wearing it you have to manually wind it to get it going again. Once you've done that the movement of your wrist will cause the self-winding rotor mechanism to keep it running as long as you are reasonably active and wear it everyday. Just wind it about 40 turns and you'll be good to go. Oris is a great watch company and you should enjoy it for many years.
Seconds hand starts ticking then stops
Your band may be too loose. This is the model that moves when worn correct?
Tag heuer link automatic
exact same problem, no one seems to know
2answers
Watch stops
sounds like the oil is contaminated and causing undo friction or the main spring is ether broken or slipping. Time to service your watch. call me 707-338-3207 www.finewatchmaking.com
Top Rolex Watches Experts
NOEL
NOEL
john h
k24674
Are you a Rolex Watch Expert? Answer questions, earn points and help others
