Question about RCA HD52W58 52" TV
No power no sound
I was wacthing my 52in RCA big screen tv ,when all of a sudden it just cut off. i took the back off and found a glass fuse was blown. i replaced the fuse and everytime i plug it in it blows a fuse.
  • Anonymous Feb 19, 2008
    what type of fuse
    Champion:
  • 207 Answers
Oh noh!!! I suggest you should an AVR (automatic voltage regulator), these will help to control the flactuations of power. try also check the power supply (its either 110 or 220 volts), just make sure it is compatible to your default power supply.
Posted on Feb 05, 2008
How to fix an rca tv
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 13, 2015 | RCA Televison & Video
RCA 52" TV stopped working
It could be the problem or just a symptom of the problem. If the fuse is replaced and blows, then it's something else. Hopefully it's just the fuse. Good luck!
Mar 07, 2010 | Televison & Video
I have an RCA 52in Rear Projection TV. One day it
There is a sub-board in this set that powers the convergence circuit. Often a big Ic shorts, two diodes and finally the main fuse. not something you can fix yourself.
Nov 05, 2009 | RCA P52926 52" Rear Projection Television
I have a RCA HD 52in and I'm have a problem with the Convergence Ic's
Hi, rca`s don`t have convergence IC`s, they use an entirely different system to perform convergence, you have a blown chemical fuse and 3-6 bad solder joints on your flyback transformer. replace fl231 chemical fuse rated at 400ma. right beside flyback (theres 3 of them your bad one is the middle one)and while your soldering re-solder all of the flyback transformer pins and your tv will be back to normal :) video-tek
Jun 04, 2009 | RCA R52WM24 52" HDTV Projection Television
I have a 60 inch panasonic big screen tv that i shut of manually and now it will not turn back on no matter what we have tried. There is no light on either showing that there is any power to the...
I had this problem and I took off the back panel. I followed the power cord to its place of origin in the back of the TV. Right next to its hook up point there was a little glass fuse in a metal clip. I pulled it out, dusted it off, made sure it was not blown, popped it back in and bang the TV came on. I have to do this about every 6-9 mos when the dust builds up on it...
Apr 16, 2009 | RCA R52WM24 52" HDTV Projection Television
How to align projectors
It could be a fault in the convergance power supply. Located on the right hand side looking from the back. What fuse was blown. ?
Oct 12, 2008 | RCA P46924 46" Rear Projection Television
TV RCA SCENIUM D52W136D 52in
Problem solved, it was my green driver this time and only $25 to replace.
Jan 16, 2008 | RCA D52W136D 52 in. TV/DVD Combo
Rca 52in Projector
Most likely the issue in on the large signal board. The TV is going in to shutdown. Repair might run $200.00 or so.
Jun 08, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Fuse blown
the fuse will always blow if there is a shorted component. the horizontal output transistor may be the most likely culprit, if you are not a technician, have it service by a qualified one.
May 15, 2007 | Samsung TXR3079 TV
RCA HD52W58 52" TV Logo
57 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
