Question about Dishwashers
Frigidaire dishwasher no power
I just installed a Frigidaire dishwasher yesterday (FMB330RGS). I went to run a test cycle and nothing happened. I am getting 120 volts and the machine absolutely does nothing.
Any Ideas?
I SUGGEST checking door switch fisrt
Posted on Feb 07, 2008
We recently had a power outage, the next time I went to run the dish washer it would only run the lower rack 65 min. cycle. I press cancel nothing happens unless I open the door. I have tried selecting...
Hello Stacey, thank you for your post!
I understand the unit recently experienced a power outage. First, let's try reprogramming the dishwasher. This can be done by either unplugging it or flipping the household circuit breaker to the off position. It is necessary to wait roughly ten minutes and then turn the appliance on. If resetting the power does not correct the issue, your unit could be experiencing a communication error with the control board, or a potential wiring failure. I recommend reaching out to an appliance expert who is best equipped to pinpoint the exact problem, which can often save you funds and a headache.
Sep 10, 2013 | Frigidaire Professional Series 24 in....
Funny sound while operating
This happens some times. some times the dishes move due to water pressure!
Reorient the dishes and observe.
May 20, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Normal wash cycle will not work. After I used the rinse cycle on day, I went back to the normal cycle and the lights wouldn't light up. Every other cycle will still run except this one.
Could be tricky to find this one.
You need to deduce what is used in the main cycle that is not used in the others,
Whatever is used is likely to need testing or replacing.
If there is nothing else wrong (heater, pumps, thermostats) then the only thing to try is a new control board.
May 02, 2010 | Frigidaire Professional Series 24 in....
Frigidaire dishwasher fdb2415lf will not turn on. Was working fine, no fuse blown, not disconnected.
I have one of these modles and yesterday after it finished I noticed a lilttle green light on below the main options, a little lock that is telling me to "hold to unlock" not sure what that means, so tried this morning to "hold" nothing happened as need to run the machine, and right now there is no response. HELP!!!!!!!
May 31, 2009 | Frigidaire 24 in. FDBB944C Built-in...
My dishwasher will not start
Hi!
Most common d/w power is 120 volts, check for 120 volts with a volt meter at the main power harness where it enters into the dishwasher, you will have to remove the lower access panels to get to the power box. Dishwashers also have at least one and most newer dishwashers have two door switches that must be checked. You will find then behind the console at the door latch area. Please see this picture of what the dishwasher switch looks like.
Please rate this solution as Fixya if found useful.
Please ask for any clarifications.
Thanks
Rylee
Mar 13, 2009 | Frigidaire Dishwashers
Frigidaire Dishwasher Energy Star blinking lights.
Hmmm...don't know why this worked, but it did. When the lights were flashing when I tried to start my Frigidaire dishwasher model#FDB1500LF, nothing would happen...just blinking lights, so I went to the house electrical panel, found the switch for the dishwasher, turned off & on again, and now the dishwasher works.
Go figure.
Feb 16, 2009 | Frigidaire 24 in. PLD2560LCC Energy...
Kitchenaid double-drawer dishwasher will not start
i just installed a used dishwasher. It filled up with water then stopped. The lights are still on as far as the cycles but nothing is happening. I did the factory diagnostic test and the service diagnostic test, not sure how long each test was supposed to take because after it seemed to go through each cycle by the lights on the front nothing else happened. I waited over 30minutes because I didn't know how long this was going to take. When all the lights on the front went out I tried to turn it on like to run a wash cycle and nothing is happening and the bottom is still full on water. HELP!!
Oct 24, 2008 | KitchenAid 24 in. KUDS01FLBL Built-in...
Frigidaire dishwasher does not clean
the start switch in the motor is probably bad,it could also be the motor relay.if you can get to the motor run the unit and while it hums try to turn the motor.it also could be something is stuck in the motor let me know.
Aug 13, 2007 | Frigidaire 24 in. PLD2850 Built-in...
Dishwashers Logo
578 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
