Question about Texas Instruments TI-86 Calculator
Cracked TI-86 screen
I have a TI-86 calculator that got dropped and the screen got cracked. Is there some place I can send it to get the screen fixed?
  • lpscozby Feb 05, 2008
    Where would I get a replacement for it if it is disposable?
  • Greg Collins May 11, 2010
    no, those are disposable
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 56 Answers
Well this isn't looking to good for you? The TI 86 isn't made anymore, so I doubt you can get it replaced. your luck has kinda run dry. You are probably going to have to buy a new calculator. Sorry to be the barer of bad news. Good luck though.
Posted on Feb 12, 2008
I dropped my ti 86 and now the top left corner is black and blue? whats the matter. ti still types and works right just cant see.
The Screen Was knocked out of place, the problem is pretty much just a moved part from the drop. you should probably get someone to repair it. I do not recomend attempting to fix it yourself, this can result in even bigger problems with the calculator.
Aug 24, 2010 | Texas Instruments TI-86 Calculator
Send program from one TI-86 to another TI-86
First, connect the two calculators with the unit-to-unit cable.
Prepare the receiving calculator: press 2ND [LINK] F2.
Select the item to send on the sending calculator: press 2ND [LINK] F1 F2. For each program you want to send, navigate to it using the up/down arrows and press F2. Press F1 to send.
Mar 18, 2010 | Texas Instruments TI-86 Calculator
Whenever i try to link my calculator with other ones it always says error in xmit. no matter what i do
Read the following answer from the TI Knowledge Base.
Hope it helps.
How can I troubleshoot an Error in Xmit error message when transferring data between two graphing calculators?
The Error in Xmit error message is returned when a connection cannot be established between two calculators when attempting to transfer data. There are several factors that can contribute to this error message.
• The calculators being connected are not compatible for data transfer.
• The data cable is not firmly connected to both units.
• The receiving calculator is not in receive mode.
• The I/O port on one of the graphing calculators is damaged.
The procedure for connecting two graphing calculators is as follows:
• Connect the data cable to the I/O port of each unit. The cable will fit tightly in the I/O port and snap into place. If silver from the cable is visible, the cable is not properly connected.
• Access the Link menu on each unit
• Place the receiving graphing calculator on "Receive"
• Place the sending unit on "Transmit" or "Send" from the Link menu.
Once the data has been selected, the transfer will commence accordingly.
The data transfer protocols for graphing calculator is as follows:
• TI-73 - Link allows data sharing with another TI-73, TI-82, TI-83, and TI-83 Plus.
• TI-82 - Link allows data sharing with another TI-82.
• TI-83 - Link allows data sharing with the TI-82, TI-83 family calculator, and TI-84 Plus family calculator.
• TI-83 Plus/TI-84 Plus family- Link allows data sharing with another TI-82, TI-83 family calculator, and TI-84 Plus family calculator.
• TI-85 - Link allows data sharing with another TI-85(To a TI-86. Not From a TI-86).
• TI-86 - Link allows data sharing with another TI-86 and from a TI-85 to a TI-86.
• TI-89 family- Link allows data sharing with another TI-89 family calculator and from a TI-92 family calculator.
• TI-92 family- Link allows data sharing with another TI-92 family calculator and from a TI-89 family calculator.
• Voyage™ 200 - Link allows data sharing with another Voyage 200 and TI-92 family calculator.
If the cable does not fit properly into the I/O port, or if the I/O port appears to be damaged (broken or separated plastic, obstruction inside the port), call 1-800-TI-CARES (1-800-842-2737) M-TH 8:00 AM - 7:00 PM FRI 10:00 AM - 7:00 PM Central Standard Time to speak to a representative or sending an email to ti-cares@ti.com.
Oct 22, 2009 | Texas Instruments TI-83 Plus Calculator
Cracked screen
Chances are it is too far gone. You could send it to TI for repair but that will cost almost as much as buying a new one.
Sorry :(
Dec 12, 2008 | Texas Instruments TI-84 Plus Silver...
Casio fx-570ES calculator inner screen cracked
the difficulty of finding a replacement LCD maybe would cost more than having a new one. and even if can find a replacement, installing it would again be very difficult! circuit to LCD connector is fixed, once remove, there'll be no guarantee that it would still function normally! try to disassemble your calculator and see if you can manage to disconnect and reconnect the LCD itself!
Nov 05, 2008 | Texas Instruments TI-86 Calculator
TI 89 Titanium
Well the best solution is to stop making more problems
Oct 26, 2007 | Texas Instruments TI-89 Calculator
Broken screen
I don't know that you can replace the screen, but you can download a TI emulator that will let you load you 86's ROM onto your computer and use it on your computer screen.
Check out ticalc.org
Oct 12, 2007 | Texas Instruments TI-86 Calculator
Texas Instruments TI-86 Calculator Logo
491 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
