Question about Brother MFC-9420CN All-In-One Laser Printer
Fuser In spite of the fact that the fuser was just replaced, the screen still displays the "replace fuser" message.
  • Anonymous Sep 15, 2008
    me too...
    no idea how to fix this....
  • Anonymous Mar 18, 2014
    replaced fuser still get message to replace fuser
    Problem Solver:
  • 5 Answers
Http://www.simplyinked.com/support/index.php?tsrc=knowledgebase&act=115&category=C5
check the link above, it may help
Posted on Oct 29, 2008
Check for formater board
Posted on Feb 25, 2008
I have a problem with the fusor xerox phaser 6125, the display say error 010-397 please help me
That is in fact a problem with the printers fuser, which melts the toner to the paper. You should replace the fuser (part# 675K65654). To replace it open the front door, and at the top right you should see a gray clip you push down and then slide the fuser out starting with the right. When installing the new fuser slide the left side in first and then the right. Iteminc.com has this part in stock and ships same day. Hope this helps, good luck. Thanks for using FixYa!
Aug 08, 2011 | Laser Phaser 6125 Colour XEROX Phaser...
When I turn the Printer on, it will initialize and then display an error message "50.7 fuser error" and will not get to 'ready mode' for printing
1. Turn the printer off, wait 10 minutes, and then turn the printer on. 2. If the message persists, reseat the fuser. If that does not work, replace the fuser. To check the fuser, turn the printer off and remove the fuser. Measure the resistance between the fuser connectors. If it is not within the proper range, replace the fuser. If there is not continuity between the fuser connectors neutral and hot with the fuser removed, replace the fuser. If the problem is not related to the fuser, replace the engine controller board. http://printertechs.com/tech/error-codes/error-codes-50-59.php
Fuser Ref: http://computer.howstuffworks.com/laser-printer3.htm
May 05, 2011 | Computers & Internet
Xerox work centre 4150 screen states faulty fuser module. Can't seem to find part...Help
That is in fact a bad fuser which must be replaced (part# 126N00321 for 110v). Replacing it is simple, open the right door and remove the 4 screws that hold in the fuser. Make sure the machine has been off for awhile because the fuser my be hot. Here is a video that shows you how. Hope it helps, and thanks for using fixya
Dec 20, 2010 | Xerox WorkCenter 4150 Black and White...
E300 error message
Hi Good day!! It may be the fuser problem. u may need to replace the fuser or buy a new unit.
Nov 19, 2010 | Canon imageCLASS D340 All-In-One Laser...
Fuser life on screen please advise
When Fuser Life message on the screen of your Lexmark X502n printer is displayed, replace the fuser immediately, For your reference, check this article in the Lexmark website. Just click on this link: http://bit.ly/b4lggj . There are also links on that page on replacing the fuser and resetting the fuser page count. Hope this helps.
Apr 15, 2010 | Lexmark X502N All-In-One Laser Printer
I have a c920 lexmark with a fault code 920.000. my guess is that the fuserisnt heating up... based on the fact that its not getting hot... im guessing the fuser lamp has blown.... is there any other...
Hi, Majorly this Error 920.X display for a cold fuser. Some 920.xx error codes may be cleared by turning the printer on and off.
In general, fuser errors require replacement of the fuser. Fuser errors can be from a cold fuser or an overheated fuser. In your case you need to replace the Fuser.
Feb 22, 2010 | Lexmark C920 Led Printer
I have replaced the fuser on Brother HL-4070cdw but the screen displays fuser unit end How do i clear the message Thank you
Look on page 115 under maintenence. Follow the instructions down to where it says Belt Unit, instead, find Fuser Unit then continue with reset instructions. Hope this helps.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_HL_4040CDN_4040CN_4070CDW_EN_1037.PDF
Oct 27, 2009 | Brother HL-2040 Laser Printer
T8008 printer with message says "replace fuser"
The 'Replace Fuser' message on the 8008 can be cleared in the following way;
• Power the printer Off
• Hold down FORM FEED and ENTER and power the printer on
Keep the FORM FEED and ENTER keys held down until the printer displays SERVICE MENU - INFORMATION
• Press the RIGHT ARROW to MAINTENANCE, and press ENTER
• The Display should read MAINTENANCE - CLEAR FUSER, if it does not press the right arrow until it does and then press MENU/ENTER
• The Display Should now Read CLEAR FUSER NOT EXECUTE, Press the right arrow until the display reads CLEAR FUSER EXECUTE
• Press ENTER, and after a pause the display should read COMPLETED CLEAR FUSER
• Power the printer off and after about 10-15 seconds power the printer back on again.
The message should now be cleared
Jan 12, 2009 | TallyGenicom 8008 Laser Printer
HP 5550dn colour printer
the fuser unit is at the end of printer section please clean it
Oct 04, 2007 | HP LaserJet 5550 Printer
Brother MFC-9420CN All-In-One Laser Printer Logo
201 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
