Question about Sewing Machines
Reverse on kenmore sewing machine 385
The reverse button on the kenmore has stopped working when you push it and also the reverse on the button hole doesn't work.
thanks for any help
  • Anonymous Sep 08, 2008
    The reverse on my machine also doesn't work, plus the zig-zag is stuck in zag (needle stuck on right hand zig-zag pattern) None of the decorative stitches work either. I feel lucky if I can get it to sew forward. I'm considering adjusting the machine with a sledge hammer.
  • nomokenmore Mar 04, 2009
    reverse on my kenmore 385 suddenly stopped working. the buttonholer works in reverse but pushing the reverse button does nothing
I recommend that the machine be serviced by a professional but if you're handy it may simply need cleaning around the reverse cam. To do this place the machine on it's back. You'll need to access the rod that drives the feed dogs and cam mechanism by removing all screws holding the bottom plate of the machine. Remove the bottom plate. Note that when you push the reverse button, while turning the wheel a thin rod moves left which allows a plastic cam mounted to the cam rod to also move left and engages the feed dogs in reverse. If the cam is not moving enough or if too slow, it may be that the rod and cam need cleaning and lubrication. Clean out all lint and lubricate the cam where it moves on the shaft. Try to get it to move more freely without forcing it. When done replace the bottom plate. I just repaired my wifes machine and this solved the problem. Hope it helps.
Posted on Feb 17, 2008
  • 5 more comments
  • mg48 Dec 13, 2011
    Glad to find this exact problem I have, and the clear directions. Thank you.
  • mg48 Dec 13, 2011
    And let me add that it fixed the problem and saved me a lot of time and money.
  • aga_lupa
    aga_lupa Aug 23, 2012
    Thank you! That helped solve my problem!
  • Thomas Witman
    Thomas Witman Oct 23, 2013
    That was right on! I could see the rod moving and releasing the spring loaded cam but the cam wouldn't move. I put some sewing machine oil on the shaft and pushed the cam left until it started to move. Then put some more oil on the newly exposed shaft and moved the cam back and forth until it now moves with the force of the spring only. Backwards works as well as the stretch stitching which didn't work before!
  • Sparkle4513 Apr 13, 2015
    This info was helpful but doesn't fix my problem. My reverse button just stopped engaging entirely. It's like it's not connected to the motor. I've opened the machine up and I can't find anything disconnected or broken so I'm completely stumped.
  • WillieCindy Jan 10, 2016
    I can't get mine to work either. I've opened the bottom and can see the hook on the shaft, oiled everything I can find but it's still not engaging. Any other comments that might help me find what's wrong? I am assuming the cam is the out of round thing on the shaft. The cam seems to slip and then catch up. The hook on the shaft looks like it should be holding the cam to the right and the reverse button releases the hook, then the hook grabs again when you let go of the reverse button. My hook isn't touching anything - it doesn't put pressure on anything. does that make sense?
Will not sew in reverse when reverse button pushed
my kenmore 385.17526 will not go in reverse when I push ...
www.shopyourway.com > Manage My Life > Questions
my kenmore 385.17526 will not go in reverse when I push the button ... Having asewing machine that doesn't reverse can be a bit disappointing, especially ...
Sewing Machine Repair ' ThriftyFun
www.thriftyfun.com/tf/Home_and_Garden/.../Sewing.../index.html
Sewing Machine Won't Sew in Reverse. My Elna 3007 became temperamental atsewing in reverse some years ago. On occasion, I will need to push the button ...
Bernina 1230 Reverse Button Fix ' Temecula Valley Sewing ...
https://tv-sewingcenter.com/bernina/bernina-1230-reverse-button-fix
Aug 30, 2010 - The reverse button of the 1230 had been pulled or popped out of ... All I had to do to fix the button was to hold the button in, and then push the cap forward. ... My 1120 Bernina reverse button will not work and the person who ...
Dec 28, 2015 | Sewing Machines
Model #385.1764180 the reverse no longer works. Is there a quick fix?
Mine was doing same thing. Open up from side and see if a little oil will help. Also, keep pushing down the Reverse button and make sure your needle Iis up, push down the V Reverse and see if it works again. A lot of grease inside these macbines have gotten thick. Keep trying to use it, guarantee it will start back. Mine works all the time now.
Sep 25, 2015 | Kenmore Sewing Machines
I have a Kenmore Model 1703 and the reverse does not work. There is no resistance when pushing down on the reverse lever. I know how to get inside, but can not see what I need to do to re-engage the l
OBVIOUSLY YOU HAVE A SPRING (SOMETIMES A CONNECTING BRACKET/WIRE) THAT CAME LOOSE. FIND THIS PIECE (YOU MAY HAVE TO TURN YOUR MACHINE UPSIDE DOWN). MOVE YOUR HANDLE TO REVERSE MANY TIMES AND OBSERVE THE DIRECTION OF MOVEMENT. THE SPRING OR BRACKET WILL ATTACH HERE. ACROSS FROM THIS PIECE YOU WILL NOTICE WHERE IT CONNECTS. THERE WILL BE A HOLE THERE. NOW, YOU SHOULD HAVE PRESSURE AND YOUR REVERSE SHOULD WORK.
Nov 13, 2014 | Sewing Machines
I just got an old Sears Kenmore Sewing machine model 385.17781. Everything is working fine except the reverse stitch. When the reverse button is pressed, the fabric doesn't move or sometimes movin
it sounds like the feed dogs & the reverse button need to be
checked at a repair shop,
to see why they are not responding to each other.
Sep 08, 2012 | Sewing Machines
Will not go into reverse
Well when you push on the reverse button you should feel some resistance from the internal mechanism? If not, then the lever on inside is either broken or stuck. If you want to look at some of the reverse mechanism you may remove the bottom covers both for the base and the free area and locate the link lever that works the reverse. Then remove the top cover for more light so you can see better. Post comments for further help or information.....
Good Luck!!
Thanks for using FixYa!!
Mar 27, 2011 | Kenmore Sewing Machines
My kenmore sewing machine will not go in reverse
Good Luck!!
Jan 16, 2011 | Kenmore Sewing Machines
My machine is sewing in reverse how do I get it to go forward
if your reverse is a lever then pull the lever down to normal sewing
if it's a button, try pushing it several times & try to see if that will help it unstick
if it doesn't use some wd-40 on it & see if that will work,,& keep working the button
Nov 18, 2010 | Kenmore Sewing Machines
Start/stop button problem will the machine run on its own
You have to unplug the power cord to the the foot pedal. The manual doesn't include this. And good stinkin luck with Sears or Kenmore customer service! Just pull the cord out of the machine and the start/stop button will work. Try it on a slower setting at first though. Also, if you need additional presser feet, Singer, Brother, Janome, and possibly other brands will usually work as long as they are the snap on type. I really do like my machine, good luck with yours!
Apr 23, 2009 | Kenmore Drop-In Bobbin 16231 Mechanical...
Buttonhole
Dud you pull the button hole lever down so that it engages the foot?
sewman7
Jul 17, 2008 | Necchi 3102 Mechanical Sewing Machine
Janome JD1818 Automatic Buttonhole Not Working
If everything appears to be working correctly for the first side and stops and bunches up when it should reverse - Make sure you have pulled down the stopper arm (this is not clear in the manual) when the button hole foot contacts the stopper arm gently push the foot against the stopper arm and the direction will reverse and finish the button hole. **Stopper arm pulls down from above - Check the pictures in you manual carefully.**
Mar 16, 2008 | Sewing Machines
Sewing Machines Logo
6,635 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
