Question about EZQuest Cobra Plus (B12660) 120 GB Hard Drive
Hardware recognition I'm connecting the EZQUEST Cobra Plus 120GB HD External to a PC using a Dynex IEEE 1394 card. The card is working properly but there is no recognition of the external hard drive...?
  • 3 more comments
  • jim1328 Feb 05, 2008
    turns out there was recognition but the HD needed to be reformatted - thanks
  • jim1328 Feb 06, 2008
    True! New problem - HD won't reformat completely; gets to "100%" and then locks up, won't "quick format" at all. Any thoughts?
    did all that - didn't work
  • jim1328 Feb 07, 2008
    did that - no luck. I did notice that in the properties window it shows format as "RAW" as opposed to "NTFS"...does "RAW" mean unformatted or stand for something else?
    This HD came from a friend who is a MAC user, fyi.
    What can I try from here?
  • anon13333 May 08, 2008
    I got a maxtor external hard drive that was loaded with pictures using mac. I am using windows xp and my computer shows the external drive in computer management section as unallocated. I cannot see what is on the external hard drive. Please help so that I view the picutures that are the drive.
    Sergeant:
  • 226 Answers
To ba able to recognize the device you must secure that the connections between the hhd and cables to other device must be properly and in tact.
if it doenst recognize it, restart your computer withour removing the device and youll see the computer recognize it.
Posted on Feb 05, 2008
  • 2 more comments
  • earl llanera
    earl llanera Feb 05, 2008
    hello!!!
    well you cannot reformat your hard drive when it is no recognize by the computer.
  • earl llanera
    earl llanera Feb 06, 2008
    right click on my computer
    click manage > click disk management > look for the drive you want to format and right click on it choose format.
  • earl llanera
    earl llanera Feb 07, 2008
    really my recent sulotion for you is the best one. try to run check disk to repair for bad clusters and sectors.
  • earl llanera
    click my computer> right click on the removable drive> properties>under tools tab> click on check now
How to connect firewires of the HD?
You just need to plug one end of the firewire (IEEE 1394) cable into the external hard drive and the other end in the slot on the computer marked IEEE 1394. Sometimes you have a IEEE 1394 slot on the front panel, and sometimes it's just on the back of the PC.
If you find you don't have a firewire (IEEE 1394) port on your PC then you will need to get adapter that will change the firewire to a usb. If you have trouble finding one of those then install a card like this in your desktop:
http://www.newegg.com/Product/Product.aspx?Item=N82E16815124002&cm_re=usb_to_IEEE_1394-_-15-124-002-_-Product
Jun 21, 2012 | Acomdata (HD080U2FE-72) 80 GB Hard Drive
How to connect firewires?
Good Luck!
Makes "clicking" noise and will not mount
that is a common noise when your HD just failed it can be internal or external most of them work the same way, there is 2 metal readers that hover on top of the actual disks to read the information. Those readers get stuck or keep going back and forward trying to read (that is the clicking noise) a way to try to fix the problem (it works sometimes) is replacing the circuit board attached to the hard drive (inside the metal enclosure) and you have to find one with the same characteristics as the one you have now. sometimes when we really need to recover the information we try that and it may, may not work
if it works for you, don't forget to rate me
thx
Jun 03, 2010 | EZQuest Cobra Plus (B12660) 120 GB Hard...
What dose the icons mean on front panel what is the little square hole for next to the mike connection
hello, it is most likely a firewire connection.
FireWire, originally created by Apple and later standardized as IEEE-1394, actually preceded USB and had similar goals. The difference is that IEEE-1394 was originally intended for devices working with lots more data -- things like camcorders, DVD players and digital audio equipment. IEEE-1394 and USB share a number of characteristics and differ in some important ways. Here's a summary:
  • Like USB, IEEE-1394 is a serial bus that uses twisted-pair wiring to move data around.
  • However, while USB is limited to 12 megabits per second, IEEE-1394 currently handles up to 400 megabits per second.
  • USB can handle 127 devices per bus, while IEEE-1394 handles 63.
  • Both USB and IEEE-1394 support the concept of a isochronous device -- a device that needs a certain amount of bandwidth for streaming data. This mode is perfect for streaming audio and video data.
  • Both USB and IEEE-1394 allow you to plug and unplug devices at any time.
hope this helps,
regards
Amar Sondhi
Dec 05, 2009 | Medion M3 Director 5100 PC Desktop
How to connect IEEE 1394 (4 pin) to computer
IEEE 1394 is commonly referred to as Firewire. Your Dell doesn't support it. You will have to purchase a firewire adapter card and install it and its drivers into your computer.
Apr 22, 2009 | Dell Dimension 2400 PC Desktop
Acer Aspire - 5610-4648 I own this laptop without a firewire connection which I need. I have purchased a PCMCIA card but is not recognized by my laptop. Is there a specific card that will work? Thank you...
u need to cap video thru this firewire connection or what is the use kindly tell me i can help
how can u say that firewire card is not recog by ur laptop have seen it in devices hardware list control panel>system>device manager
it will show as IEEE 1394 bus host controller or something like that if u see anything like this in list IEEE 1394 then it is recog by ur system u can use it
now if u want to cap video thru video cam then simply go to any cap software like ulead , or nero vision or cyberlink power producer and try to cap video there by connecting ur video cam first and then select ur 1394 device in the list
pls let me know if more i can help
and rate me FIXYA if i fixed ur problem
Mar 04, 2009 | Acer Aspire 5610-4648 Notebook
Download PV-GS39 cam recorder drivers
Hello. I also have the PV-GS39. I had the same problem as you have, here is what I DID to resolve my problem.
1.Go to: http://www2.panasonic.com/consumer-electronics/support/Cameras-Camcorders/Camcorders/MiniDV-Camcorders/Drivers-Downloads/model.PV-GS39.D
the above link will take you RIGHT to the web page to download the PV-GS39 Software & Drivers that YOU WILL HAVE TO HAVE. But if you have WINDOWS VISTA then you can use the WINDOWS MOVIE MAKER software that is ALREADY PRE-INSTALLED on your PC then you will NOT have to download the software from the above link.
2. You HAVE TO have a: FIREWIRE IEEE 1394 PCMCIA NOTEBOOK CARD. I got mine at: Best Buy for: $53.86 with taxes. the name of this card is: DYNEX FIREWIRE IEEE 1394 PCMCIA NOTEBOOK CARD.
3. You ALSO hae to buy the CORD that connects to the PV-GS39 and the DYNEX FIREWIRE IEEE 1394 PCMCIA NOTEBOOK CARD, the cord costs $36.79 ALSO at Best Buy.
I did ALL 3 of the above and now I'm copying my movies and videos from my tape in my camcorder onto my PC and BURNING the video onto DVD/CD Disks.
If you have any questions, you can email me at: uggyredmonster@comcast.net.
Sincerely,
Rick D. Michaels
Feb 28, 2009 | Panasonic PV-GS39 Mini DV Digital...
Try to connect a panasonic PV-GS39 to my new HP notebook with Windows Vista
2. You HAVE TO have a: FIREWIRE IEEE 1394 PCMCIA NOTEBOOK CARD. I got mine at: Best Buy for: $53.86 with taxes. The name of this card is: DYNEX FIREWIRE IEEE 1394 PCMCIA NOTEBOOK CARD.
3. You ALSO have to buy the CORD that connects to the PV-GS39 and the DYNEX FIREWIRE IEEE 1394 PCMCIA NOTEBOOK CARD, the cord costs $36.79 ALSO at Best Buy.
Sincerely,
Rick D. Michaels
Jan 25, 2009 | Panasonic PV-GS39 Mini DV Digital...
Help my
If you have the PV-GS39 Camcorder and are wanting to COPY THE VIDEO FROM THE PV-GS39'S DV TAPE, HERE IS WHAT YOU HAVE TO DO...........
Sincerely,
Rick D. Michaels
Dec 05, 2008 | Panasonic PV-GS39 Mini DV Digital...
Can I use Firewire to transfer video?
Your computer must be equipped with an IEEE 1394 (Firewire) interface and video capture software. Provided you have both of these, follow the directions below. To connect your digital camcorder to your computer using IEEE1394, follow these steps: 1. Connect the IEEE 1394 interface on your camcorder to the IEEE 1394 interface on your computer. 2. Turn on your computer. 3. Turn on your camcorder. 4. Start the video capture software on the computer. Image capture should begin provided the computer hardware and software are configured correctly. If image capture does not begin, you must consult the computer or capture card manufacturer for assistance. Note: If you don't have an IEEE 1394 interface on your computer, you can buy an IEEE 1394 pci card at your local computer store that will work with most current computers.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
EZQuest Cobra Plus (B12660) 120 GB Hard Drive Logo
245 people viewed this question
Top EZQuest Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you an EZQuest Computer and Internet Expert? Answer questions, earn points and help others
