Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
I cant acess my cruzer
I plug in my cruzer in another computer and when I click on the removeable drive it asks me to insert disk but my cruzer is already inserted....how do I gain acess?
  • JazzySaz Feb 05, 2008
    it works at home though....just not on a different computer...but ok...I guess. Thanks
  • Anonymous Apr 24, 2008
    I purchase a micro 8GB cruzer USB flash drive. It is working on other computers but my laptop is not recognising the drive. When we try to navigate it through explorer, the explorer hangs. However the indicator of the 8GB Flash Drive continues to blink. After waiting for long time of non responding explorer when we disconnects the 8GB Flash drive the computer hangs. I have tried with some solutions even with the help of IT Dept of my company but it did'nt worked.
  • 2,336 Answers
Right click on my computer > manage > double click on disk management > right click on disk1 (removable device) > change drive letter and paths > click on change and asign "Z" for example.
Now you should be able to use that device.
Good Luck.
Posted on Feb 05, 2008
    Novelist:
    Champion:
  • 202 Answers
Dear... may be the OS on the other computer u r using may be a problem, try formatting the cruzer (with the proper tool) to FAT and then try it on!
Also try on some other computer before doing this...If it is working, please ask the person who owns the computer for permission to re-install the drivers...just use windows to do it from the system manager
Try to tell me.... whether my suggestion was useful???
Bye
Have a nice day.
  • 449 Answers
Am sorrry your cruzer is no longer useful try and get another one
I cnt open my pen drive..it's showing insert disk..it is a cruzer blade 16gb pen drive..and I have a windows XP..
Windows XP should be able to automatically detect and install it. Try using it on another computer that has either Windows XP, Vista , or Windows 7 on it. If it doesn't automatically detect and install it on that one then the flashdrive is dead.
May 09, 2012 | SanDisk 8gb X2 = 16gb Cruzer Blade Usb...
Unable to read the Cruzer 8GB flash drive
Most likely then its a hardware issue with the drive, try the following:
1- Plug the USB key into the computer 2- Click Start 3- Right Click on Computer (Win7) or My Computer (XP) and select manage 4- Select Storage and then Disk Management
Here you should be able to see the drive and it will show if there is media or any type of partition on the drive. If it the USB key still shows up as a CD-ROM and you have tested on two computer its the key that is the issue and you would need to replace it
Apr 14, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
PC is not detecting my Cruzer micro pendrive but
I have experienced this type of problem before. But what I did was to install an Avira Anti-virus on a system using windows xp and eventually it did open.
So you can try it as well or insert your flash into any another system that had a strong anti-virus which can enable you scan/format the drive.
Best of Luck
Nov 06, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Cruzer micro 4gb will not format. Also, PC will not reveal contents.
Sometimes when a flash memory stick fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
You need to format the external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs).
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Oct 12, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Sandisk Cruzer no longer prompting for password
I think the problem is corrosion on the contacts. Shut the computer off. Gently insert and remove the USB drive several times to try and clean the contacts. Turn the computer ON and when Windows has set up properly, insert the USB drive and see if you can read it. Many of the new drives and reader ports do not use gold contacts (too expensive) but use copper or aluminium which corrode easier an easiest.
Jun 10, 2009 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
SanDisk 2GB Cruzer Micro USB I/O device error
I would recommend plugging your Cruzer into another computer. It's possible that your computer has corrupted or incorrect drivers for the flash drive. This is one cause of the yellow alert in Device Manager. If you move the flash drive to another machine and it works, you can save your data and make a backup copy. If your Cruzer doesn't work in a different computer (I would try at least 2 other working computers), it's possible that the flash drive is faulty.
May 13, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sandisk pen drive cruzer 2gb not detected by the computer
first insert your sandisk pendrive.Now right click on my computer.Go to manage option . select disk management. From that you must select your drive letter for your pen drive.Go to Action menu near to File menu.Fromthat select all tasks and select formatting.Then again goto all tasks and select change drive letter and paths.select the drive letter and your problem is solved. thanks for asking your problem.
Mar 28, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
When i plug my cruzer micro it asks to insert disk when it never came with 1.....what shall i do??? Help me plz!!!!
If you just got it go to my computer right-click on it select format and click ok this shold work.
Sometimes an internet connection is required for software download and that could be the only problem.
p.s. when I got one it had to get all the software online.
Feb 24, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sandisk cruzer micro
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Oct 24, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
USB flash disk not working
Assuming you are using a Cruzer Micro Drive with U3 Smart, things can be a little confusing because the drive actually shows up as two independent devices. When you insert the drive, there should be two devices showing up in your list of drives. One of them is installed as a CD Rom Drive and the other one is a Removable Drive. If you double click on the CD Rom Drive instead of the Removable Drive and you don't have any U3 applications mapped to the CD Rom Drive, then you'll get an insert disk message because Windows thinks that the CD Rom Drive is empty. Just use the Removable Drive if you want to simply install and transfer files.
Jan 05, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
122 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
k24674
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
