Question about Logitech diNovo LX300 Keyboard/Mouse
When i hit enter in Word...it brings me four or five lines down instead of just one.
    Sergeant:
  • 319 Answers
Stop hitting enter then
Posted on Feb 05, 2008
How do I get it back into the mode where it shows the decimal fractions instead of the arithmatic ratios at the end of a calculation?
Press MODE to bring up the mode editor. Press F2 to get to the second page. Use down-arrow to move to the "Exact/Approx" line. Press right-arrow to bring up the options. Use up/down-arrow to highlight "APPROXIMATE." Press ENTER twice.
Apr 25, 2011 | Texas Instruments TI-89 Calculator
How do you get the table ([2ND GRAPH]) from the [STAT] [EDIT] [L1] [L2] list to appear with [Y1] in the second the column? The information appears in the scatter plot, but the information in the table does...
Instead of hitting the [table] button. You should hit the [stat] or [stats] button as I forget which it is. Then hit [enter] which will bring you to a stats list editor of some kind. You will want to enter the data for your x-axis in L1 and the data for your y-axis in L2. Once you have completed your lists, hit the [stat] button again and then click [right] or the right arrow in order to move to the section of calc. from number 4 down it will help create a graph of that type of function. lets say you think it is linear, so you hit [enter] on number 4 and then you will be at the home screen with LinReg already written. You just have to complete the statement and it will do it for you. hit the [2nd] [1] and then the comma button, then [2nd] [2] and [enter]. that will do it for you.
Feb 14, 2011 | Texas Instruments TI-84 Plus Silver...
Dell mouse not responding; diagnostics results says test passed. mouse works on other PC
There is a very good chance it's one of two problems. First, while theoretically you can connect tons of USB products, sometimes USB ports can be kind of hinky... Try unplugging something else USB based and plugging in the mouse or try several different ports. Also be sure it's not plugged into a USB hub and is going directly into your computer. If this works play with the arrangement of your USB devices until you find a configuration that works, maybe you'll have to switch out a printer or external drive while using your USB mouse...
If this doesn't provide a solution the next thing to do is to uninstall the pointer device driver in device manager and allow it to re-install.
If you don't have an alternate mouse to complete the task, here is the keyboard shortcuts for Windows although depending on your version of Windows it may be slightly different.
-First hold the windows key and hit the r key (win+r)
this will bring up the run menu
-Next type mmc this will bring up a management console
-Next press the ALT key and hit the down arrow key
(this should drop down the file menu, if it doesn't please try ALT+F)
-Use the arrow key to scroll down to Add/Remove snap in and hit enter.
-Use the arrow key to scroll down to Device Manager and hit ALT+A to add the device manager to the console. Hit enter.
-Make sure local computer is selected if this menu comes up and hit enter.
-Hit enter one more time bringing you back to the console with the device manager added.
-Hit tab to get to the center console and scroll down to mouse.
(If tab isn't doing anything please hit the ALT key once.)
-Hit enter to open the tree if it isn't already
-Scroll down to mice and other pointing devices (or something along these lines) and hit the right arrow key to expand the tree again.
-Select the USB mouse with arrow keys
-Hit the alt key again then the down arrow (not together) and then the right arrow key until you get to the action menu and use the arrow key to go down to uninstall and hit enter.
-Wait a moment and then go back to the action menu (you may have to hit tab just keep trying tab and the down key (not together) until a menu opens. Go over to the action menu again and choose scan for hardware changes. The computer should recognize the mouse and now work.
I hope this helps you. Thank you.
Jan 04, 2011 | Dell U0636 Mouse
L was have problem will it my D-link wireless, it was just show red light .
After confirming that your internet service is not down, perform the following steps:
Open your command line prompt box on your computer by typing in cmd in the box that is labeled search or run.
From that black prompt box that comes up, type ipconfig/release and then hit enter.
Then type ipconfig/renew.
If that does not work, unplug the USB leading to the router from your modem, then unplug power from the modem, then unplug power from the router.
Wait at least five minutes before doing anything more.
Reconnect power to the modem and wait for a connected status...this may take a few minutes.
Then plug the USB cable from the wireless router back into the modem. Then reconnect the power back to the router. Wait for connection status.
Once connected, you can configure the router over your computer by typing the IP address 192.168.0.1 and hit enter.
This will bring you to an extensive user menu for your router. Navigate the pages until you locate the selection for a firmware update. This may not pertain to your problem you had but in any case may likely make your router operate better.
Nov 02, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Ok when i hit the number 1 key i get `1 that and number 2 key brings a help manue three is ok and four is five and four and five is the same.
Your Keyboard keys is just dirty inside ; try opening it up and cleaning it up -- the circuits and touch detection underneath they key could just be misdetecting the "`" on the left of the "1" key and "2" key
Mar 06, 2010 | Saitek Eclipse II
Need unlock codes to lg phones cause i got a phone for a pawn shop and there is a un lock code needed
this is what you need to do. turn the phone on. hit ##7764726 (program) then enter phone model number 8800 so it would look like this ##77647268800 pres SEND. Service cod will pop up, hit 000000 all zeros, six of them to be exact. press okay on service program it will bring you to the esn screen, hit ok. now it will say phone number. enter either all zeros or your phone number, the last four of the phone number you enter will be the unlock code. so if you enter 555 555 5555 your unlock code will be the last four so 5555. just hit okay untill your phone resets. when it turns back on, your unlock code will be the last four digits!
Sep 23, 2009 | LG Venus VX8800 Cellular Phone
I´d like to get 99 answeres instead of the default 30 in home win
When on the home screen, simply hit [F1] to get to the tools drop down menu. Either scroll down to format or hit [9]. Then a box will come up displaying the number of history reports. Simply hit the right key [>] and change the number to any interval of 10, up to 99. Then hit [ENTER] [ENTER] and you should be good...
Dec 12, 2008 | Texas Instruments TI-89 Calculator
REGISTRATION NUMBER
When you open the program are you challenged to enter the registration number?
If you are able to open the program but can't do anything until you enter the number, drop the help menu down, click on 'About' and there should be a blank text entry line to enter the number. Do that and then hit enter. Unless of course, there is a line in the Help drop down menu to register. Click on that instead and you'll be okay from there.
Regards, and ask any more questions using the comment box below.
Worldvet
Oct 31, 2008 | Nova Development Photo Explosion Deluxe...
No video on screen
Try unplugging unit, wait then plug in and try. That may reset it. If using S video maybe you should try using the reg video input and see if that helps
Jul 08, 2008 | iLO DVDR05 DVD Recorder
Parental control
1. Go to the V-chip selection in the customer menu.
2. If the set has an active PIN code, the menu will display “BLOCK-ING ACTIVE”.
3. Press RECALL on the remote four times within five seconds.
4. The menu should then display “BLOCKING RESET”.
5. Input a new four-digit PIN code and press ENTER.
6. The next menu page will appear which allows you to scroll down to the various lock selections. If you want to remove the PIN code completely, instead of entering a new code, just exit the menu after pressing recall four times.
1. Disconnect AC power for several seconds to reset unit clock.
2. Adjust unit volume to minimum.
3. Press and hold volume down button on unit control panel.
4. While holding the volume down button, press and hold the “Zero” key on the unit remote.
5. The user menu will appear with the V-Chip cursor blinking.
6. Pressing the “Enter” key on the unit remote will open the “New Password” menu.
Have a great day!!
Bill
Dec 09, 2007 | Toshiba MV13L3 13 in. TV/VCR Combo
Logitech diNovo LX300 Keyboard/Mouse Logo
88 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
