BUSH DVHRS02 TRIED TO PLAY AN UNFINALISED DVD WHICH I HAD DUPLICATED ON MY COMPUTER. CANNOT REMOVE IT OR GET THE DVD CONTROLS TO OPERATE. TRAY WONT OPEN
  • deanyoung Nov 13, 2008
    Hi
    Have got exactly the same problem except now because ive been mucking about trying to rectify it the screen just says lock everytime i push a button
hughv
  • 196 Answers
SOURCE: jammed sony dvd
Unplug the power cord for at least 30 seconds, then try again.
Posted on Jun 10, 2007
SOURCE: dvd player wont open
Look on the bottom of your player. Between the two front feet you should see a narrow slot that is about 1 1/2" long (it should say "emergency hole". Shine a light into the slot, you should see a black pin about as big around as a pencil lead. Carefully push this pin in the direction of the arrow. It should release the drawer and allow you to open it.
Posted on Aug 28, 2007
  • 61 Answers
SOURCE: Liteon DVD Player LVW-5115GHC+ Disk Tray stuck
The tray is either broken, or off track. You may be able to get it back on track by opening the cover and checking it out, but unplug it first, and only try this if warrantee is over and you're feeling brave...
Posted on Jan 27, 2008
  • 979 Answers
SOURCE: Unfinalized DVDs
What sort of "recognization" is your TV showing? Do you get a blue screen but no AV?...accordianman
Posted on Feb 25, 2008
ctf1800
  • 4402 Answers
SOURCE: DVD tray WONT OPEN
unplug it and try it again, if that doesn't work see if theres a pin hole where you can push a paper clip in by the tray area.
Posted on Feb 26, 2008
BUSH 3081: What code will region free this DVD player? I bought this item listed as unlocked for all regions, but it says wrong region..
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Unlock procedure to many popular brand TVs and DVDs are given.
Aug 28, 2014 | Televison & Video
Bush dvd 3081 region code
Bush / Curtis 3081
1) Open drive
2) Enter 9999
3) Enter 0 (for region free)
Aug 03, 2012 | Bush Televison & Video
My usb stick wont work with my portable dvd player?
check first in the user manual what kind of file format available in the dvd player that you bought. so you will know what kind of format that you can download to make compatible in the player using the usb stick.
Jun 25, 2012 | Bush Televison & Video
Is there a Unlock code for bush btvd91216w
This is everything that I have:
Try this general bush unlock:
Press Open tray
Press 2, 8, 1, 2 and Enter to get to the manufacturers settings
Select the required region, by pressing Enter on 9 for multi region
Press Close tray
If that didn't work, try this:
Try this one:
1. Press the Open button on your remote control to open the drive tray
2. Press the 9 button on your remote control
3. Press the 7 button on your remote control
4. Press the 3 button on your remote control
5. Press the 5 button on your remote control
6. Using the on screen menu, highlight the region option
7. Press the Right button on your remote control
8. Using your remote control, select 1 for region 1, 2 for region 2, and so on, or 0 for multi-region playback
9. Press the Enter button on your remote control
10. Press the Open button on your remote control to close the drive tray
Then there is the following and good luck:
Bush 1000
  1. Open the tray
  2. Insert a disc with desired region code, but do not close the disc tray
  3. Press 0, 1, 2, 3, Play
Bush 1005 / 2004A / DVDAV7
  1. Press the OPEN/CLOSE on the remote
  2. Press 3, 3, 0, 8, 8
  3. Press the button for the desired region or 0 for multi-region
  4. Press OPEN/CLOSE
  5. The on-screen display will now indicate the currently selected region
Bush 2000
  1. Open the disc tray
  2. Insert RC-1 DVD, don't close the disc tray
  3. Press 0, 1, 2, 3
  4. Press PLAY
    To activate RC 2:
  2. Insert RC-2 DVD, don't close the disc tray
  3. Press RETURN and PLAY
Bush 2002 / 2004
  1. Press OPEN
  2. Press 7, ENTER, 7
    A menu should appear (codefree=13)
    Method 2:
  1. Press OPEN
  2. Press 2, 0, 0, 1
Bush 2005 / 2008 / 2009
  1. Turn on the player
  2. Press OPEN/CLOSE
  3. Press ZOOM
  4. Press A/B
  5. Press Up, Left, Down, Right
    A note should be displayed.
  6. Turn it off
  7. Turn it on
Bush 2023 / 2024 / 2523
  1. Press OPEN
  2. Press 2, 8, 1, 2, Enter
  3. Set the country code to 13 and press Close
Bush 2028
    already region free
Bush 2039
  1. Press OPEN
  2. Press PROG
  3. Press ENTER three times
  4. Use UP/DOWN to select region
  5. Press STOP several times to set the region
Bush 2047
  1. Press OPEN, SETUP
  2. Go to "Preferences"
  3. Enter 2, 8, 1, 2
  4. Use UP/DOWN keys to select the region
  5. Press SETUP, OPEN
Bush DVD-102
  1. Press OPEN/CLOSE
  2. Press 2, 0, 0, 1
  3. Press ENTER
  4. Select RC (codefree=13). You can disable MacroVision, too.
  5. Press OPEN/CLOSE
Bush DVD-142TV
  1. Press DVD function on your TV set
  2. Press DVD Setup on the remote
  3. Press 1, 3, 6, 9
  4. Press Left three times
  5. Press RIGHT once
  6. Select VERSION
  7. Change the region code
Bush DVD-143TV
  1. Press DVD/TV, DVD
  2. Open the tray
  3. Press SETUP, Right, Left, Down, Up, Display
  4. Enter 0 (or 1-6 for other RC)
  5. Press Enter
    VCD/SVCD playback
  1. Press SETUP on remote
  2. Press Next, Prev, Next, Prev
    Ver should appear in the top right
  3. Change 3001 to 3000
  4. Change 5001 to 5000
Bush DVDAV11K
  1. Open the tray (be sure to be in stop mode)
  2. Press SETUP, Next, Prev, Next, Prev
  3. Select 255 for region free (use LEFT/RIGHT)
  4. Press SETUP
Bush DVDR3000
  1. The disc tray has to be empty
  2. Press TV/DVDR
  3. Press RETURN, DISPLAY
  4. Enter 8, 8, 8, 0
Bush DVHS1
  1. Press the DVD button on the remote
  2. Press OPEN
  3. Press 0, 5, 2, 0
  4. Press UP, DOWN, LEFT, RIGHT
  5. Change the region (0 = multi-region)
Bush DVRHS02
  1. Push SETUP button on the remote
  2. Select SYSTEM INFO on the menu
  3. Enter 1, 1, 0, 1
  4. It shows the current region code
  5. Push 0 on the remote for region free
Bush 2001 / 2020 / 2026 / 2029 / 2035XI / 2038 / 2042 / 5020 / BTV213DVD / DVR3000 / DVRS01 / PDVD0707 no known hacks
Jun 12, 2012 | Bush Televison & Video
Instruction booklet for bush combi btv183dvd/b
hi, the dvd tray wont open and im not to sure how to operate it please hep !
Aug 21, 2011 | Bush Televison & Video
Dvd player won't read dvds. The player mechanically operates ok in that the disk tray goes in and out. And, the read head moves back and forth when trying to read the disk. I can't see a red light from the...
There can be various reasons.1 is the region code correct?
There a selection of dvd`s which you can`t play,this is in the front of your manual.
Unfinalised discs won`t play etc
Oct 19, 2009 | Televison & Video
Bush PDVD0707 personal dvd player will not play
Oct 03, 2009 | Bush Televison & Video
Recording problem between dvd vcr recorder combi and hd lcd tv
Aparently its the wire!!! as your sawpping the scart so yeah change the wire and you be a happy person!
Jun 17, 2009 | Grundig GU19WDT 19 in. LCD TV
Unfinalized DVDs
Jan 15, 2008 | Samsung DVD-VR320 DVD Recorder/VCR
Discs wont play
what is the model and brand of your dvd player kindly post it on this website and please say how long the set have been refusing disc, and how old is the dvd player will be awaiting.you can contact me through fixya or my email nicodhem@yahoo.com see ya
Mar 26, 2007 | Bush DVD142RC 14 in. TV/DVD Combo
Televison & Video Logo
101 people viewed this question
Top Televison & Video Experts
Electro Med Services...
