Question about Car Audio & Video
Alternative power I have an older motorcycle i'm hooking an amp and a cd player up to. If the electrical system can't handle it can i look into a backup battery or a capacitor?
  • 2,336 Answers
Look here for additional info: http://www.ehow.com/how_5829_wire-car-stereo.html
Posted on Feb 05, 2008
Hook a tape deck to a Audiosource 100watt amp
CD player to any audio in. Tape deck requires a dedicated tape in tape out connection found in older amps/receivers.
Dec 16, 2017 | AudioSource Audio Players & Recorders
I have an after market cd player installed in my car. it has worked fine until recently it would pause and my headlights would go dim. and it would happen over and over. the cd player pauses and my...
Do you have an amp and subwoofer hooked up to the cd player as well ?
Alot of times if your battery is old it won't hold a good charge or possibly the alternator is not able to keep up with the power demand of your car. Some aftermarket cd players can draw alot of power, and if you have an amp and subwoofer, gps, cell chargers etc. hooked up it will only drain power quicker. Which Ive seen make headlights dim and flicker on my friends cars as well as customers cars due to these same issues.
To see if either of these are a possible match, take your car to an autozone and ask them to test your battery and alternator which they will do for free. They will be able to tell you if either of them are faulty.
Let me know if that help's, feel free to comment back with any additional information or question's and I will be happy to assist you further.
Thank you for choosing Fixya,
Daniel
Jun 25, 2011 | Sony Car Audio & Video
I have a sony explode cd player. It is an older one and has been sitting in a garage for about 3 years. We hooked it up today and my subs will not play when a cd is playing but the subs will play in...
It sounds like you are using the blue wire (power antenna remote turn on) instead of the blue/white wire ( amplifier remote turn on) to turn your amp on. The power antenna remote turns off when leaving tuner mode.
May 02, 2011 | Sony XPlod CD Player w/MP3 Playback...
I hook up a amp with red and black wire from the car stereo, then the stereo stopped turning on, why?
You probably blew a fuse. The power wires for a stereo can not handle the current an amp needs. An amp has to get it's power directly off the battery. Get an amp kit that has the power wire, ground wire, turn on lead, and fuse w/fuse holder. fuse the power no less than 12" from the battery.
Apr 19, 2011 | Boss MP3-3030R CD Player
I have a KVT 514 unit that cuts out when the volume goes past 23. Even when I change the audio equalizer to natural and turn off the loud it cuts out. I have a 2003 accord ex v6 coupe, infinity reference n...
to me you need to do the big 3 upgrades .
1 second battery
2 bigger power cable
3 high output alternator
sound like you electrical system can't handle the high volume you want to here you system at.
it starving for power
need to upgrade your alternator to a 150 amp or bigger so your amps and factory accesories can get the voltage to run properly .
then put a second battery in trunk to help your amp
does you head lights flicker or interior lights flick signs of your car audio system killing your alternator
can help you more
caraudioquestion@gmail.com
Oct 14, 2010 | Kenwood KVT-514 Car DVD Player
When i hook up my amp my speakers wont play music? ive hooked up my rca cables up but i ont know if you hook it up to the input or output frum the cd player?
you rca hookup, back of cd player is rca out, at the amp it is rca in, make shure you hook up blue remote wire, also make shure you have a good ground if not amp will not turn on. if you run wires make shure you run power wire down one side of car and remote and rca down the other, This will keep all motor noise out of system.
Oct 07, 2010 | Audiofonics Car Audio & Video
I HAVE A OLDER KENWOOD STACK HOME STEREO SYSTEM WITH OUT MANUALS OR REMOTES AND NEED TO KNOW HOW TO HOOK ALL THE COMPONENTS TOGETHER. KC-206 STEREO CONTROL AMP KT-76 TUNER KX-96W CASSETTE DECK KM-106...
start with the tuner, hook up the equalizer to the tuner, then on the rear of the equilizer hook up all the peripherals except the amps which will go to the tuner outputs and all will feed thru the tuner to the amps and out to the speakers
Oct 23, 2009 | Audio Players & Recorders
Wiring in a cd player and cant find which wires to plug in
Wiring the System:
Wiring is an important factor in your audio system. You need enough power cable to run from your car battery's positive terminal through the firewall to the amplifier. The thickness or gauge (AWG) of the power wire is very important because you want to make sure wire can handle the power demand of your system. To find out the right gauge you must ascertain the approximate current draw (in amperes) of your amplifier (or amplifiers). First, calculate the total power of each amp (multiply the number of channels by the number of RMS watts per channel). If you have multiple amps, add up the total power figures to arrive at a grand total. Second, double your grand total power figure. Finally, divide by 13.8 — the result is your system's approximate current draw in amperes. Be sure to install an in-line fuse or circuit breaker near the battery. Without one, an accidental short circuit could pose a fire hazard and damage your amp (not to mention your car). Your ground wire should be of the same gauge as your power wire and must make direct contact with the body of the car. Look for an existing bolt or screw that makes contact with the car body closest to the amp. Remove the bolt or screw, and scrape away any paint or grime. A star washer will help your ground wire maintain solid contact with the car body. Use a ring terminal on the end of the ground wire, to keep it securely fastened to the bolt or screw. If you cannot find a convenient ground screw or bolt, drill a hole for one. Be careful not to drill into the gas tank, a gas line, or a brake line. If you are grounding multiple components, try to ground each one separately, with about a half-inch of space between each of the grounding points. If you'd rather use a single bolt, place the ground for the most current-hungry component (probably the biggest amp) closest to the body of the car. Put the ground for the component that draws the least current (probably the electronic crossover) on top. The last wire you need for powering the amp is a turn-on lead. It does not need to be as thick as the power and ground wires (18 gauge should be fine). It runs from the remote turn-on lead at the back of your receiver to the remote terminal on the amp. When connecting these wires, be sure to use crimp-on spade or ring terminals to get the best signal transfer. Your car's alternator ampere rating determines how powerful an amplifier you can install. An alternator that cannot handle your power demand will hurt your systems output. Here is how to find out if your alternator can do the job for your system. Multiply the ampere rating by 40%, and you'll get a rough idea of how much power demand your car's system can handle. An alternator capable of producing 55-65 amperes is usually adequate for systems up to 350 watts RMS. A Japanese car with a 35-amp alternator can accommodate around 125 watts of power, while a German car with a 90-amp alternator can handle a 500-watt system. Heavy-duty capacitors connect to the power cable (just before it reaches your amplifier) and act as a buffer zone between your amp and your car's electrical system. They store up a reservoir of power that can supply the amplifier's peak demands (like a kick drum beat) without having to get current from the battery. Capacitors come in half or full Farad. You can use one or link as many as you want depending on what your system demands. Car audio competitors often replace their vehicle's alternators with heavy-duty upgrades to accommodate big power demands. An amp can be securely installed with just a few screws. But since amps can be sensitive to electrical and motor noise and because interference from the amp may affect your radio reception, try to mount it at least 3 feet away from the receiver. When working inside the trunk, tape over the latch, so you will not become trapped inside accidentally. If the amp is in the trunk, run the input signal leads down the same side of the car as any speaker wires you have installed. Run the power and turn-on leads down the other side of the car to avoid interference. Do not mount an amp or other car stereo components such as electronic crossovers or equalizers directly on steel — you will invite noise problems. Instead, mount the amp on a non-conductive board and mount the board to the car body (or use rubber grommets under the screws to isolate the amp). Before you drill the screw holes to mount your amp, hook it up and give it a test run. If the amp is operating correctly, with no engine noise, then proceed with the installation. There is also a safety issue here: Components that aren't securely mounted could break loose during an accident and injure someone as they fly through the passenger compartment. Use bolts and nuts or screws to secure amplifiers and other components to their mounting locations.
have a good day
Jun 12, 2009 | 1999 Ford Escort
Amps will turn on but cd player won't
if this is a stand alone cd changer, make sure you have the power wire running to an accessory that can handle the load, not the fuse your amps are hooked to as will be too much of a power draw, just step it over to another acc switch
Apr 28, 2009 | JVC KD-G140 Car CD Player
Fisher 143a CD Changer
HI...
You wont be able to play any new format CDs on an old Fisher or any other older make . It 's the internal decoder logic that's needed. And older players dont have it.
As far as top-loaders..Do a websearch . I dont know of any.
Jan 27, 2009 | Jwin JK-777 Nostalgic Stereo System with...
Car Audio & Video Logo
98 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
