Question about KHypermedia (KDVRW8X) (20730176) DVD+RW Burner
Finished cd's Upon completion of burning a disk via itunes. The disc won't eject. I have to restart the computer to eject the disc, which plays fine in a cd player?????????
  • k_cuevas Feb 05, 2008
    It is checked but still wont eject the disc
  • 983 Answers
Get checked in itunes options or settings whether the ejection of the drive is check marked or not..
Posted on Feb 05, 2008
  • Dileep Keshavanarayana
    Dileep Keshavanarayana Feb 06, 2008
    then just move to ur near by expert technician and tell ur problem... if u r not afraid means just do as i say take of the rom drive in ejected mode (if it s not ejecting means then use a pin into the small hole which called as emergency eject hole... push the pin inside drive will eject then take off the drive open it and clean it wit a dry cloth especially clen near the rubber belt which is connected to dc motor... and take off the dust cleanly and then give a try....
Hey my mac won't eject a disc. i have tried a lot of stuff and nothing happened. when i restart it the disk spins and doesn't sound stuck and when i used disk utility it said there was an error...
Resolution Tip: Make sure the CD or DVD disc is not in use. Quit all applications that are using files on the disc.
  1. Press the Media Eject key at the top-right corner of the keyboard.
  2. If that doesn't work, drag the disc's icon to the Trash.
  3. If that doesn't work, restart the computer, then hold down the mouse button or trackpad button while the computer is starting up, until the disc is ejected.
    To restart, choose Restart from the Apple menu.
Aug 16, 2011 | Computers & Internet
Ejecting a Stuck CD in Mac OSX
  • First try the normal methods to remove the disc. Drag its icon to the Trash can in the Dock or select 'Eject' from the File menu.
  • If you are running a virtual machine, e.g. VMFusion, ensure that the CD is disconnected from the virtual machine. This will sometimes allow the CD to now show up in Mac OS X.
  • Shut down the computer and start up whilst holding down the mouse button. This may take some time, but keep your finger on the mouse button right up until the disc comes out or the log-in screen has appeared.
  • If you have Toast Titanium installed on your computer, choose EJECT DISC from the menubar.
  • Sometimes you can successfully use the eject disc button in iTunes even if the disc is not visible to the Finder
  • Open Disk Utility and choose the disc you wish to eject in the left-hand pane, then click on the Eject button.
  • Some Macintoshes have a paperclip hole that you can insert a straightened paperclip into, manually triggering the eject mechanism.
  • Open Terminal and type "drutil tray eject" to eject the disc/tray, and "drutil tray close" to close the tray.
  • Restart the computer while holding down Command-Option-O-F, to enter the Open Firmware prompt. Type "eject cd" without the quotes, and press return. The disk ought to eject. To start into OS X, type "mac-boot" without the quotes. Press return, and the computer will continue with the startup. (This will not work on an Intel Mac. There is no Open Firmware on Intel Macs. )
  • If your computer has an eject button on the keyboard, restart the computer holding down the Option key. When the startup disk selection screen appears, let go of the option key and press the keyboard's eject button.
Sep 17, 2010 | Apple iMac G4 Desktop
I have had to replace my hard drive on my pc how can i get my music back on to pc from my ipod and back into i tunes
Backing up your iTunes library to a CD or DVD To burn a CD (CD-R or CD-RW), your computer must have a compatible CD burner. To burn a DVD (DVD-R or DVD-RW), your computer must have a compatible DVD burner. Check in iTunes Preferences to see if a drive is compatible. See below for steps.
To create your backup disc
  1. Choose File > Library > Back up to Disc.
  2. Select the option you want from the resulting dialog and click Back Up.
  3. The two options you can select from are:
    • Back up entire iTunes library and playlists
    • Back up only iTunes Store purchases
    Whichever of these two options you choose, note that you can also choose "Only back up items added or changed since last backup" to perform an incremental backup.
  4. Insert a blank disc (CD or DVD) into your computer's optical drive. iTunes will scan the disc and begin burning.
  5. Note: If the disc you insert does not have enough space to hold all of the content you will be backing up, a dialog will appear asking whether you wish to backup to multiple discs. You can click Data Discs to continue.
iTunes burns the number of items that fit on one disc and then asks you to insert subsequent discs to continue burning the remaining files. Don't eject a disc while a backup is in progress.
Spoken programs purchased from the Audible.com website are not backed up.
Discs you create using the iTunes backup feature can be used only to restore; they can't be played in a CD or DVD player.
Restoring from a backup disc
  1. Open iTunes.
  2. Insert your backup disc.
  3. iTunes will ask whether you want to restore from this disc. Click Restore.
Check drive compatibility
  1. Choose a playlist on the left side of the iTunes window.
  2. Click the Burn Disc button on the bottom right corner of iTunes.
  3. If the drive is listed, it's compatible.
Aug 16, 2010 | Apple iTunes
I need to remove a disk from a Sony NEC Optiarc AD-7640S
CD Stuck in Device
First try the normal methods to remove the disc. Drag its icon to the Trash can in the Dock or select 'Eject' from the File menu. If you are running a virtual machine, e.g. VMFusion, ensure that the CD is disconnected from the virtual machine. This will sometimes allow the CD to now show up in Mac OS X. Shut down the computer and start up whilst holding down the mouse button. This may take some time, but keep your finger on the mouse button right up until the disc comes out or the log-in screen has appeared. If you have Toast Titanium installed on your computer, choose EJECT DISC from the menubar. Sometimes you can successfully use the eject disc button in iTunes even if the disc is not visible to the Finder Open Disk Utility and choose the disc you wish to eject in the left-hand pane, then click on the Eject button. Some Macintoshes have a paperclip hole that you can insert a straightened paperclip into, manually triggering the eject mechanism. Open Terminal and type "drutil tray eject" to eject the disc/tray, and "drutil tray close" to close the tray. Restart the computer while holding down Command-Option-O-F, to enter the Open Firmware prompt. Type "eject cd" without the quotes, and press return. The disk ought to eject. To start into OS X, type "mac-boot" without the quotes. Press return, and the computer will continue with the startup. (This will not work on an Intel Mac. There is no Open Firmware on Intel Macs. ) If your computer has an eject button on the keyboard, restart the computer holding down the Option key. When the startup disk selection screen appears, let go of the option key and press the keyboard's eject button.
Dec 23, 2009 | Computers & Internet
My Cd burner is not burning a complete disk
the ans is simple tht burn the project again on an fresh cd and play it
Dec 20, 2009 | Toshiba Satellite M55 Notebook
Hi- I've just inserted a CD into my MacBook Pro
CD Stuck in Device
Oct 13, 2009 | Apple MacBook Pro Laptop Computer with...
Can not burn disk on laptop
Will the disc play in your PC or another PC when it is put in there?
Will someone elses burned CD's play in your stereo?
If so, then there may be an additional step when you burn the disc called "finalizing" that will complete the burn on the disc in a way that will prevent any more songs from being added to it, but will make it readable in many more devices.
This usually is either a checkbox or an option pops up after the disc is burned (I don't know about i tunes software for sure).
Since a lot of older stereos cannot play burned CD's there is still a chance this will not work for you.
Jan 25, 2009 | Computers & Internet
Won't read mp3 and wma cds
The discs were not "finalized" or "closed" - place the cd's back on your computer cd-rom drive and search the help file of your CD burning software and search for "closing disc" or "finalizing disc." Some programs will allow you to close or finalize after you have already burned them, but others (Sony SoundForge is one exmaple) will not allow it - you may have to re-burn the discs and select the option that says "close disc after finishing" (this option is usually left unchecked by default, because closing or finalizing a disc prevents you from adding any new information to the disc).
-Tha Mp3 Doctor
Jan 02, 2009 | Panasonic CQ-C300U Car CD/ MP3 Player
HP 640b DVD Writer tray will not eject after burning DVD
If all else fails you can take it to best buy
I did that with one of my comp.
Dec 17, 2008 | HP LightScribe dvd640i (DVD640I)...
MacBook Force Eject CD
worked for me:
1)open Terminal
2)copy this into it:
diskutil unmount disk1
diskutil eject disk1
3)press enter
4)cd comes out
found here: http://condonethis.com/mac_eject/
Aug 11, 2008 | Apple MacBook Mac Notebook
Open Questions:
KHypermedia (KDVRW8X) (20730176) DVD+RW Burner Logo
79 people viewed this question
Top KHypermedia Computers & Internet Experts
David Payne
David Payne
Are you a KHypermedia Computer and Internet Expert? Answer questions, earn points and help others
