Question about Zenith IQB64W10W 64" Rear Projection Television
I have never been able to get the pip to work.
I have figured out that i need a second tuner. i can not believe that this tv was not built with more than one. Now i am trying to figure out which is best to replace my dvd vcr combo or replace my dvd recorder or just buty a qam tuner.? Does anyone out there know???
I don,t have the answer for you but before you throw it away I would be willing to buy a board out of your tv. lavineboys@sbcglobal.net
Posted on Mar 06, 2008
I'm trying to hook up picture in a picture with my TV using the HD dual tuner DVR DC H 6416 converter box. Is there a place that I can connect a cable to the box that has video out to use individually for...
The TV requires two inputs to use the PIP function. Your setup box Has multiple outputs, but the same picture comes out of all of them. The only way you can use PIP in your TV is to split the signal and connect it to both the set-top box and the TV. However; you will not receive the additional channels that the setup box picks up unless you use 2.
Some set top boxes already have PIP built in. If it does you can view a PIP display even if your TV does not have that feature. Because the cable box has 2 tuners built in they are designed to do two different things at one time. If yours has PIP capability they will proudly and prominently tell you about it in the instruction manual..
Nov 15, 2014 | Televison & Video
How PIP works. Do I need VCR hooked up?
PiP only works if you have twin tuners built into TV.
Or
You have 1 external source (dvd, VCR etc) playing at same time as watching TV.
You can then watch the two at same time and switch between the 2.
You have to tell the PIP what the other source is.
Please dont forget to vote this answer was helpful and accept my solution.
Many thanks
Feb 17, 2011 | Samsung HL-S6187W 61 in. HDTV
I have a sony (model KP61V75) a split screen came on (two pictures) and I cannot figure out how to get it back to one screen. Im going crazy!
Some television remote controls have a PIP OFF button, while others only have a PIP button that needs to be pressed repeatedly until the PIP/Twin-View window disappears.
NOTES:
  • Some Sony rear projection televisions have a FLASH FOCUS button that will turn off the PIP/Twin-View feature.
  • Some Sony universal remote controls, if programmed to operate a Sony TV, can disable the PIP/Twin-View feature by pressing the REC or ENT button.
  • If the original TV remote control is not available or is not functioning properly, auto programming the television tuner orperforming a power reset may deactivate the PIP/Twin-View feature.
  • If pressing the appropriate buttons on the TV remote control does not work, then the PIP/Twin-View window might be from a two-tuner cable or satellite set-top box. If this is the case, use the remote control provided with the set-top box to remove the PIP/Twin-View window.
Jan 25, 2011 | Sony Televison & Video
How does PIP work ? where does the signal come from for the second picture ?
PIP uses the signal from a second tuner to insert a small or split-screen image on the main image. Some TVs have two tuners but most PIP applications need a signal from a VCR tape or tuner (tuner must be digital since 6/12), a DTV box, or a cable box for TV programs. A DVD player can also provide a signal for PIP if a DVD is playing. However some TVs will not allow PIP if the signal inputs are through the HDMI ports.
Sep 22, 2009 | Televison & Video
Can not get pip to work
Pip has its own tuner, try getting a cable splitter to split the signal into the tv. If you have digital cable you may need a second cable box to do this. If your cable provider still sends an analog signal the splitter will work.
Jul 10, 2009 | Toshiba 53H71 53 in. Rear Projection...
Picture-In-Picture does not work (32" LG LCD)
my friend told me that if Tv is purchased from Canada will not work in Saudi Arabia but why?
Mar 18, 2009 | LG 32LG30 32 in. LCD HDTV
Can't get PIP to work on my Samsung LCD 46"
its talking about the analog tuner in your tv. split the cable before it hits the box plug the cable strait into your tv if there is more than one coax connector on your tv you will need a second two way splitter run one into ant a and one into ant b yo will not be able to use pip and hd at same time you can only do pip with the analog tuners built into you tv
Mar 17, 2009 | Zenith Z36X31D TV
Pip for my iQB36B44w
The PIP may only work with an external tuner or source (VCR, DVD, CATV box, etc) If your TV doesnt say "dual tuner" then you need an external source for the PIP (Use a VCR and its tuner for instance)
Feb 13, 2008 | Zenith B27A11Z 27" TV
PIP function not working
Hi !
I'll have the same problem, but i solve it when i change the RESOLUTION OF THE COMPUTER of 1680x1050 on 1440x900 at 60hz
TRY IT !
Jan 11, 2008 | KWorld 1680 TV BOX HIGH-RESOLUTION...
Need help getting PIP to work
You don't have a problem except you need two tuners. You say you have a VCR, which this has a tuner. Set your VCR to TV and and start the PIP and choose your VCR as the second source. You will now be watching two different channels, one from the TV tuner and one from the VCR tuner. Also just to clarify, you should have the cable wire from the wall running to the INPUT on the VCR and then a cable running from the OUTPUT on the VCR to your TV to make this all work correctly.
May 24, 2007 | Philips 42PF7320A 42 in. Plasma HDTV
Zenith IQB64W10W 64" Rear Projection Television Logo
65 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
