Question about Dell (E210882) Motherboard
Type of memory for e210882 motherboard
I am trying to upgrade a Dimension 1100 with the e210882 motherboard. am about to purchase 2*1gb memory sticks:-
GB PC3200 DDR 400 RAM 400Mhz 2x 1GB 2 GB G DIMM MEMORY
Specifications:2GB (1GB x2 KIT) 400MHZ 184PIN DDR Memory, No-ECC. Higher performance over mainstream PC100 or PC133 memory. Up to 3.2 GB/sec of peak bandwidth using PC3200 DIMMs (with DDR400 memory chips). JEDEC Standard. 184 pin DIMM, non-ECC. DIMM Lead pitch: 1.27 mm. 2.5 Volts. SSTL-2 I/O Interface. SPD Support. Support for Memory Chip Stacking.
Apparently this memory is high density. Does anyone know if this memory will work on this motherboard?????
Many thanks for all help.
  • adhocltd Feb 05, 2008
    I am only trying to add 2 gig Each stick = 1 gig
  • 59 Answers
the memory you're about to purchase will not work. the maximum gig that the computer can handle per stick is only 1 gig. this system is not designed for 4 gig barrier.
hope this helps.
thanks.
Posted on Feb 05, 2008
Demmy read it again
Posted on Jan 14, 2010
2 Suggested Answers
Drummernick
  • 440 Answers
SOURCE: High density memory
need low densisty on ebay 35 buck eash 1 gb ok works on picky mobos way better
Posted on Feb 07, 2008
I need the specs on a A83421-107 motherboard, E210882
-Specification Form Factor: ATX
-Front Side Bus Speed: 800 MHz
-Processor Socket Type: Socket LGA775
-Memory Memory Type: DDR2 SDRAM
-6 USB Ports
-SATA PCI Express
-4 Ram slots (1GB module each)
Jun 23, 2011 | Dell Dimension 4500 PC Desktop
My system is recognizing only half of the new module's memory
Do you have the right memory for your Dell?
Memory Upgrade for Dell Dimension 1100 Computer, the Dell Dimension 1100 Computer takes the PC2700/3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. Memory Type, and comes installed with 128 MB (removable) of Memory. You can upgrade your Dell Dimension 1100 Computer to up to a maximum of 2.0 GB Memory, the system has 2 sockets to install Memory, already with 128 MB (removable) standard Memory installed. For best Computer performance use the maximum amount of allowed Memory per slot for your Computer.
Choose the following Memory Upgrade for Dell Dimension 1100 Computer.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 20, 2010 | Dell Dimension 1100 PC Desktop
I have a Gateway tower (gt5026e) with an Intel mobo (E210882). I recently upgraded the video and purchased a pcie nvidia card. I knew I would need a new power supply (300w wasn't acceptable for the card)...
you may have dislodged something as you carried out the upgrade - Check all the cables are seated correctly - also check the memory is correctly seated does the machine bleep at all this will give an indication of what the problem may be ------ the number and pattern of the bleeps
the next step would be to remove all unnecessary devices, like the CD , DVD , spare drives - getthe machine to a minimum state of just PSU, MOBO, CPU, Memory, harddrive, graphics and see if that boots
also as you have upgraded the video card can you put the old one back in....
Mar 21, 2010 | Dell Dimension 1100 PC Desktop
Gateway motherboard E210882 I upgraded the memory from two 256MB to two 512MB. Used DDR PC3200 (400Mhz) Now I keep getting a memeory error
Recommend checking the motherboard specifications to see how much memory and what type it can handle. If you don't have this, you can easily locate it on the internet. The replacement memory sticks will need to be of the same type. That means your motherboard may not be able to handle the PC3200 type chips you have. It may require the PC2600 type instead.
Oct 25, 2009 | Computers & Internet
Ram
It appears to support either PC2700 or PC3200 DDR memory. (The PC3200 is faster).
May 26, 2009 | Dell (E210882) Motherboard
Upgrading my Dell Dimension 1100 series computer
It's hard to say without your service tag to know what motherboard they installed, what type of ram you're using, etc.
You can access a lot of automated info by entering the service tag at Dell's site, available by clicking here
But you're going to be limited, at best, expecially by today's standards.
You might be better off getting a new system and installing your hard drive as a slave, if you're attached to some of what's installed there. You'd still have to have access to installation files for all your applications, though.
Apr 10, 2009 | Dell Dimension 1100 PC Desktop
Ethernet Controller
Hi
E210882 is a number found on more than one Dell System Board. Dimension 8400 and 4600 come to mind. Possibly there are more. Secondly, E210882 is not a Dell Part number (DP/N or DS/N). While Dimension 8400 is a 775 socket, Dimension 4600 is a 478 socket. So they don't fall to the same family.
In any case the network controllers used on Dell System Boards are Intel and Broadcom.
To proceed, at least provide/confirm the system model. If this is not available, give the Dell Part Number.
Mile
Jul 10, 2008 | Dell (E210882) Motherboard
CHILL WILL'S (motherboard E210882) WOES!!!
It seems like you have done everything right but im not 100% sure that your memory is correct. read through the description here carefully and you will see that this memory comes in two different packages. One of them is the 400 (the ones you bought) and another in the 333 flavor. I am hoping they did not make a mistake and gave you the wrong ones. Look directly at the memory and make sure. I am also including the system manual for your computer. Hope this helps.
http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/index.htm
Kingston's ValueRAM KVR400/1GR is a 128M x 64-bit (1GB) DDR400 CL3 SDRAM (Synchronous DRAM) memory module. The components on the module include sixteen 64M x 8-bit (16M x 8-bit x 4 Bank) DDR333 SDRAM in TSOP packages. This 184-pin DIMM uses gold contact fingers and requires +2.6V. The product is shipped in retail packaging and includes installation instructions.
Apr 27, 2008 | Dell (E210882) Motherboard
Memory for Del E210882 motherboard
download and run the dell diagnostics memory test on one memory card at a time .
or run with one then switch . does only one fail .
and what is the board GX or dimension.
GX is really particular about memory.
Mar 30, 2008 | Dell (E210882) Motherboard
High density memory
Feb 07, 2008 | Dell (E210882) Motherboard
Dell (E210882) Motherboard Logo
6,387 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
