Question about HP Compaq Business d530 Ultra-Slim PC Desktop
Sony vaio desktop
Hi I have been told that my Vaio desktop needs a new powersupply fan I wonder if you could point me in the right direction of where to get one, its making a bit of a noise and recently i had a blue screen, anyway the other fans were cleaned and it is all working although the repair guy told me that the power supply fan is a sealed unit and needs to be replaced.
I hope you can helpall the best
Vinny Mann
  • Anonymous Mar 08, 2008
    The fan is makes noise like a small jet engine. I kave not taken any staps to resolve the problem. There is no authorized Sony service for Vaio desk tyops in Turkey I was told. What do I do?
  • slathrom Feb 05, 2009
    exact same problem as vinnymyboy's
    Novelist:
    Scholar:
  • 108 Answers
Pricewatch.com is a place to go to get fan prices and suppliers but a local PC shop usually has a pile of old used fans...fans seldom go out....but....
You need to check the power supply for the fan size and even, if a newer model power supply, check to see how many fans there are (although most fans are the same size in most power supplies).
This assumes you are willing to repair the power supply. If so you will probably have to remove it from the computer. Open the power supply. Cut the wires to the fan (although some have a pin to simply disconnect) and then replace it with a new fan plus more than likely do a little soldering. But do I recommend this...NO.
Why....well if the fan has failed it probably failed for mechanical reasons....i.e. dirt implying that a can of pressurized air was not used to once every couple months to blow out the entire computer....power supply and other fans....plus dust in general. Also....if an older machine it makes more sense to replace the entire power supply (they ultimately fail) with the same wattage as is on the one you have particularly if it's a few years old. This is also a lot cheaper than ultimately replacing a motherboard, cpu et al. Back to dirt. There are very few mechanical parts on a computer ....the fans, the trays or inserts on media, and the arm on the disk drive. The trays or inserts for media almost never go out and when they do it's the result of someone inadvertently putting pressure on it usually, the fans seldom go out before the power supply does but the arm on the disk drive...well when it starts to growl you best copy your drive to another but by all means copy your work to some back up media. The life of both the power supply and your computer in general can be increased by keeping it clean....power fluctuations and heat are your enemies.
While inside the power supply you might also want to check to see if it is fused. If it is and the fuse is blown...replace it. It was not the fan.
If you do take the power supply out (and its an older machine where the power cable or cables - newer computers connect in two places- to the motherboard) make sure record the way it goes back in. Failure to do so will be abrupt...as in POOF....there goes the motherboard. You plugged in in backwards. Newer motherboards are designed to prevent this with either a pin block or a one way only clip.
Lastly....power supplies are a pretty well developed product from a manufacturing perspective. Any low cost power supply is adequate. Those that sell for above $20 (in 2008 dollars) offer no real advantage for the typicial pc owner.
Hope this helps....Tango. Send chocolate to Tangoblue@netscape.net.
Posted on Feb 05, 2008
  • 449 Answers
Just go to the computer store near your area and get one
Sony vaio problem with drivers plz can u help ? :)
Hiiiiiii..................
Hello.............
Sony Vaio Drivers - What Are They? The new sony vaio drivers are software which are hardware-dependent and operating-system-specific. The motive force from the new sony DVD RW is that they are obtainable on the web free of charge.
Sony drivers are often compatible and may be up-to-date regularly. When installing brand new sony vaio drivers, getting familiar with the operating-system and also the device model is essential. When the needed version is not available, shooting a request email towards the supplier is essential.
How can I download / update Sony vaio drivers?
You will find losonyvaiodrivers1.jpgts of sites online that provide automatic installation, mostly free. However, it's still best to visit the web site of the new sony for that specific software that you'll require.
Online are you able to only be confident that that which you download is original and up-to-date through the manufacturer themselves.
About the new sony vaio drivers website, you have to pick the most relevant operating-system and also the device model for this to set up easily. Install your up-to-date driver as directed on the website. For this to operate correctly, the pc should be restarted. When checking for sony vaio drivers, do the next step:
Sony Vaio Drivers - Directions 1. Visit the Device Manager
2. Visit the My Computer icon and right click
3. Click Qualities and visit the hardware tab, click it.
4. (The unit driver's title is going to be visible within this section) Input the model and version number.
most drivers are here...
http://support.vaio.sony.eu/computing/vaio/index.aspx
apart from the 'vaio recovery ultility' software...
fixed everything for me :)
Sep 21, 2011 | Computers & Internet
Hi, With what Sony Vaio computer does the SONY VAIO MODEL VGP-WKB1/G WIRELESS KEYBOARD belong to? Will it work with the Sony Vaio VGC-V517G all-in-one model computer? Thank you. Angelo
Angelo, do you have the installation CD-ROM that came with the keyboard and mouse? If so, it should work just find with your Sony Vaio VGC-V517G all-in-one computer. Let me know if you have any issues.
Mar 01, 2011 | Sony VAIO VGP-WKB1 Keyboard
Have a Vaio PCV-RS 530G, everything lights up on front of computer but nothing shows up on monitor and a beeping noise sounds from the computer.
Those beeping sounds are the computer post codes. They point you in the direction of any hardware problem its encountered while trying to boot up.
Here's a url which should help you with a bit more info:-
http://www.computerhope.com/beep.htm
That beep code should point you in the right direction of any component failure you may have.
Jun 06, 2010 | Sony VAIO PCV-RS530G PC Desktop
Sony vaio vgc-rc320p cpu fan is bad, do I need a 4 pin fan or will a 3 pin fan do?
You will need a new fan with a connector having the same number of pins which you have at present.
May 29, 2010 | Sony VAIO® VGC-RC202 PC Desktop
Replacing the powersupply on a Sony VAIO PCV-RS720G desktop
Hi There,
From the looks of things that model will take a standard ATX power supply which would be available from and computer part dealer and ebay etc, get yourself a nice 400w replacement try and get a small form factor one if you can as it will be a tight sqeeze inside the case.
when replacing it you will have to open the case up (get an anti static wristband if you can, and work on a table rather that a carpeted floor) un hook all the connectors the old power supply (one in each drive and there should be 2 in the motherboard) you may have to pull the Dvd rom out slightly to get the new supply in, unscrew the 4 case screws holding the power supply from the back of the case. lift it out then put in the new one, screw it in using the case screws and connect up the internal power cables to the drives motherboard and new graphics card, close the case, plug in and voila
If you get stuck just ask and we will help
Dec 10, 2008 | Sony VAIO PCV-RS720G (027242658103) PC...
CPU coolers
TYPE YOU'R MODEL # INTO GOOGLE,SHOULD GIVE YOU A GOOD STARTING POINT.
Nov 06, 2008 | Sony VAIO VGC-RB50 PC Desktop
Sony VAIO PCV V100G
This product by sony has not been designed for high end gaming. The video card on the product cannot be upgraded.
Thanks
Proton
Sep 06, 2008 | Sony VAIO PCV-V100G (PCVV100GKIT1) PC...
Answer Sony VAIO PCV-W510G PC Desktop
http://esupport.sony.com/US/perl/model-documents.pl?mdl=PCV-W510G&region_id=1
Jul 05, 2008 | Sony VAIO PCV-W510G PC Desktop
Sony Vaio PCG-K86P laptop
hi, the problem seems with the RAM, remove and clean the contacts with an rubber/easer, this should fix ur problem,let me know
Dec 20, 2007 | Sony VAIO PCG-K25 Notebook
HP Compaq Business d530 Ultra-Slim PC Desktop Logo
288 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
