Question about Apex Digital GB5108 51" Rear Projection EDTV-Ready Television
51 big screen apex tv, convergence or verticle IC?
I have a 51 inch big screen and last year the convergence went out, the screen was red,green, and yellow and l smelled something burning. Well friday the screen goes black with just red, green, and yellow lines in the middle of the screen and the smell. You can still hear just fine. Could this be the Verticle ic or is it the convergence again? the only diff is the fact that the screen is black instead of all colorful like last time.
  • Anonymous Aug 19, 2008
    double vision and red off line
    Problem Solver:
  • 7 Answers
If the lines are thin and close together running horizontally, it may be the vertical driver, but that usually takes out the resistor and sometimes the diode in the B+ for the vert. Also you must replace the caps that caused the problem in the first place.
Posted on Apr 15, 2008
I HAVE A 51 IN APEX TV WHEN I TURN ON THE TV IT HAS PROBLEMS WITH CONVERGENCE IT HAS RED LINES BLUE & GREEN WHEN I GO AND GET THE REMOTE AND GO TO CONVFRGENCE ON THE MENUAL I PUSH RIGHT ON THE REMOTE...
Tv convergence board is dead.The 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must require replacing,to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 20, 2010 | Apex Digital GB51HD09 51" Rear Projection...
Green color projection is lifting from the bottom left corner of the screen. Convergence adjustment for the green projection is unresponsive
Howdy,
The TV has a convergence problem; the IC’s for that circuit will need to be replaced. The cost for this repair runs around $450.00 or more.
Replace the defective Convergence Output IC Part Number (STK392-110. When Convergence Output failure is
detected, it’s recommended that both IC’s be changed.
Thanks for choosing FixYA, Big Irish.
Dec 22, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Convergence out of line
STKs must not have held up Look in back of set they are 2 Big Black ICs will have part number on them example STK392-110,if 110s use 150s.you can order parts from MATs 1-800-628-1118.
Aug 20, 2009 | Apex Digital GB5108 51" Rear Projection...
Red green lines across my screen on 51 inch tv hdtv
If you cannot align those crosses, then the convergence section is damaged. should be repaired by a qualified technician, its a big job.
Jul 20, 2009 | Philips 51PW9363 51" Rear Projection...
Sony Trinitron 20" TV (KV-2093R) Suddenly Shut Off
2 things that will cause that vertical IC or Yoke! Listen to this one went on service call 2wks ago Customer had a 50 INCH1988 pioneer big screen replaced 3 capacitors resolder poor connections TV is now working like New ?
Jun 23, 2009 | Sony KP-51HW40 51" Rear Projection...
The Screen looks 3D & Colors don't line up on my big screen????
If the convergence is off more than 1/2 inch or so you can't adjust. you have a failure of hardware. most likely the output IC. This set has 2 outputs for convergence. Each output contains 3 circuits, Six circuits altogether 2 red ,2 blue and 2 green. The normal customer adjustment will only alow adjustment of blue and red. They should be converged onto the green. There is a much more complex adjustment in the service mode for Geometry and convergence. These adjustments are only needed when you replace a failed componnent like the output ic. These ICs have been upgraded several times since the production of this set. The latest and most powerfull version is STK394-160. If feel up to it I suggest changing both outputs and the corresponding output resistors. Then do a complete geometry and convergence alignment.
Apr 16, 2009 | Hitachi 50UX57B 50" Rear Projection...
Apex 51' gb5108
Just click below for convergence repair kit;
http://servicemanuals.vstore.ca/
Double images and colors are blurry .Blue,red and yellow wave coming up from the bottom of the screen on the lower left and fuzzy images this is a symptom is for busted convergence IC,you must replaced this IC in order that will works better again.STK 392-xxx ICs and it's associated resistor,this resistor automatically change value,can caused truoble even though you change the ICs.If you bring this to a service center they cost you $600 to $700,but if you buy the repair kit you can save more,don't wory it is very easy because there is intallation guide including in the repair kit. Feel free to ask whatever the result... click the link for sample picture guide step by step installation;
Hope this may help;
Regards,
VOTIT
Oct 10, 2008 | Apex Digital GB5108 51" Rear Projection...
Apex gb5108
Your Convergence is off. Go through the menue to the CONVERGENCE and follow the on screen instructions.
Start with the RED gun and align each cross point starting with the upper left corner.
You will be pulling the red to match the green.
If the television shuts down during this process, it will reset the convergence and you can try again.
After you get the red gun perfectly aligned with the green, start with the blue.
follow the on screen directs and don't forget to store.
Use the remote for these adjustments.
I hope that this helps..
Jan 06, 2008 | Apex Digital GB5108 51" Rear Projection...
Red convergence out of range.
Replace STK393-570 convergence IC. located on center PCB.
re-check alignment........T.
Oct 24, 2007 | Mitsubishi WT-42311 42" Rear Projection...
Verticle
Please reset to factory settings, if problem still there check the v-sync IC. all the best, kindly rate this solution.
Sep 12, 2007 | Panasonic PT-51G44 51" Rear Projection...
Apex Digital GB5108 51" Rear Projection EDTV-Ready Television Logo
249 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
