TROUBLE FITTING NEW BELT
Ariston washing machine new belt fitting A1636
  • mangoputtney Feb 05, 2008
    is there a belt tentioner
I put the belt on large wheel then with a large Phillips screwdriver
though a socket slightly larger than the motor wheel put the belt around the socket on the screwdriver and put the driver in the small
hole in end of the motor wheel,lever the belt and slide the socket with the belt on down to the wheel ,push the belt over the socket onto the
motor wheel this my take 5-6 atemps but ive done it about 5 times
Posted on Aug 09, 2009
Ariston a1636 will not spin
could be motor brushes/ or capasitor depending which is fitted. Be careful not to mix capasitor with suspressor if cap is fitted
Feb 11, 2010 | Washing Machines
I cant fit a drive belt on ariston washing machine, none of the bolts seem to slacken the motor
Don't know if you have solved this yet but I found a good tip on fitting a drum belt to a machine that doesn't have tension bolts (i.e they are fixed).
First put the belt fully on the motor pulley. Now fit the other part of the belt onto the main pulley as much as possible on the right-hand side (looking at the machine from the front). Secure this part in place with a cable-tie (if you haven't got any go and buy some). With the tie in place, rotate the drum from the inside counter-clockwise and the belt should feed onto the main pulley correctly. The cable tie will either snap when you do this or you should cut it off after the belt is in place.
This worked for me.
Sep 11, 2009 | Ariston Technologies Washing Machines
Fitting new belt
Remove top cover and lower rear panel of washer
With some help, tilt washer forward, and fit belt round motor pulley first,slowly ease belt onto drum pulley and feed slowly round, turning pulley at same time, it will be very tight, so watch your fingers, you can align the belt after it is fitted. Please rate my solution.
Thanks.
Aug 19, 2009 | Washing Machines
Hotpoint WD640P - Fitting a new belt
Put belt on motor pully first then turn big pully around!Like fitting bike chain.
Oct 11, 2008 | Hotpoint Aquarius WD63 Front Load...
Fitting new drive belt to tricity bendix aw405
most have no ajustment little tip put belt round the largest wheel then on the motor spindle put a flat blade screwdriver and leaver the belt on if you can turn the drum this helps
Oct 06, 2008 | Washing Machines
FITTING NEW BELT ON ZANUSSI WASHUNG MACHINE F1045W
It is'nt any adjustment on those machines. They were fitted with eleastic belts. Is the belt not tight enough, you need a new belt.
Jan 23, 2008 | Zanussi F1045W Front Load Washer
Ariston a1636 washing machine
I have the same problem, did this get solved for you?
Jan 08, 2008 | Ariston Technologies AW149NA Washer
How do I fit a new belt on my Indesit Wil 113 washing machine?
I think its a 'front Loader'? Take the back panel off, to expose the main drive belt & pulley. When fitting the new belt it needs stretching by first putting it around the motor drive shaft & easing on to the main pulley whilst gradually rotatng the pulley. You need to finish up with the belt in the centre of both of the pulleys if possible
Oct 31, 2007 | Indesit W 123 Front Load Washer
Washer not completing cycle
I HAD THE SAME PROBLEM ON A 4 MONTH OLD MACHINE AND I CALLED A SERVICE PERSON. HE SAID THAT I CAN THROW IT AWAY. THIS IS A PROBLEM THAT NOBODY CAN FIX.
Sep 21, 2006 | Ariston Technologies AWD121WH
Washing Machines Logo
219 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
