Extra computer connection
Adding a laptop computer so I may connect to internet
  • 449 Answers
Adding a lapttop computer to what.
Posted on Feb 05, 2008
  • 407 Answers
Conect in your lan cross conection  pc to laptop .then go to network properties then go to network setup wizard & share internet conection note pc name or laptop name both two other name.
How do I attach this monitor to my laptop to use it as a second screen Please?
How do I connect my laptop to an external monitor - Page 2 ...
h30434.www3.hp.com > Laptop & Notebook > Video/Touch
May 6, 2013 - 10 posts
I have a pavillion dv5 2070us and the screen is cracked and I can't see ... I have a pavilion dv6, can someone please tell me the order of the menu ... 06-01-2013 08:19AM ... Once I connected my laptop to the extra monitor, the screen on my extra ...Connect your second monitor while the computer is on. 2.
The HTG Guide to Adding an Extra Monitor to Your Laptop
www.howtogeek.com/.../the-htg-guide-to-adding-an-extra-monitor-to-y...
Aug 7, 2014 - Adding extra screen space to your laptop, however, can be quite a bit trickier. ... If you're looking to do the same, to add a little space to your laptop ...Playing Minecraft on the second monitor was a smooth experience with no drop in FPS. ... Because the AOC does what it does so well, we'll use it to highlight ...
AOC E1649FWU 16-Inch 1366 x 768 16 ms LED LCD Monitor
www.amazon.com/AOC...Monitor/dp/B005SEZR0G
Amazon.com, Inc.
Rating: 3.8 - ‎1,067 reviews
Jan 04, 2016 | AOC 936sw 19" Widescreen Lcd Monitor -...
Tip
How to Share your Internet Connection through laptop's WLAN(Wifi) card?
Every Windows Operating System after Windows 98 can share its Internet Connection using this Technique. Microsoft defines this technique as Internet Connection Sharing (ICS). But setting ICS is very obscure to most of the users. This comes very useful if you live with your roommates and you guys have single internet source like a USB modem Connected to one laptop only. Using Internet Connection Sharing(ICS) that laptop can Broadcast its Internet to other laptops in the room. Technically, the range of a laptop's WLAN adapter is around 20-25 meters. So it can easily handle near by rooms also. This can also be done with a PC having a WLAN card.
To setup and broadcast your internet it is mandatory that you are accessing internet using anything other than Your WLAN card like a USB modem, Ethernet etc. This is because your Wireless adapter(WLAN) will be used for Broadcasting your Internet connection to your friends.
Server laptop:- Laptop with Internet Connection.Client Laptop:- Laptops accessing the internet of server laptop.
Follow the steps to share your internet connection..here it goes:--0b73509.gif
  1. Open the "Control Panel" of the laptop that is accessing Internet and go to "Network and Internet" then "Network and Sharing Center".
  2. On the right side of the "Network and Sharing Center" click the "Change Adapter Settings" and you will see all the available network adapters in your laptop.
  3. Now Right-Click the adapter through which you access internet and click "Properties" option. The properties window will open.
  4. In "properies" Window click the "sharing" tab check "Allow other network user to connect through this computer's Internet connection"97ac799.jpg
  5. In the sharing tab, Select "Home networking connection" type as "Wireless Network Connection" click "OK" and select "Yes" to the Confirmation warning. see above image.
  6. Now Right-Click the "Wireless Network Connection" in "Change Adapter Settings"and Open Its Properties.
  7. In "Wireless Network Connection Properties" Double-click the "Internet Protocol Version 4(TCP/IPv4)" and select the "Use following IP address"
  8. Enter the IP address as "192.168.000.001" and "Subnet mask" as "255.255.255.0"
  9. Leave all other fields blank in Server laptop, which has access to internet.0219162.jpg
  10. Now setup a wireless "ad hoc" computer to computer connection using "setup a new connection or network" in "network and sharing center" and Name it as anything like "Internet_sharing".c2debe7.jpg3a69972.jpg
  11. Now bring other laptops that will use the Shared Internet connection.
  12. Open "Change adapter Setting" (Described in step 2).
  13. In "Change adapter settings" Right-click "wireless Network Adapter" and Click its properties.
  14. In "Wireless Network Connection Properties" Double-click the "Internet Protocol Version 4(TCP/IPv4)" and enter following IP address:-
  15. IP address-"192.168.000.002", Subnet mask "255.255.255.0", Default gateway-"192.168.0.001" and Preferred DNS server: "192.168.000.001".
  16. Use the same step from 11 to 15 to connect other laptops and Increase the IP address by +1. Ex- 192.168.0.3, 192.168.0.4 & so on. Rest of the settings like Default gateway etc will be same on all laptops. Only the server laptop will have blank entries in these settings.
  17. Now connect all the laptop with the Wireless network(ad-hoc) named "Internet-sharing" that you had previously broadcasted in step 10 in server laptop.
  18. Now in the server laptop, disconnect and then reconnect the internet connection(This is a necessary step for Internet Connection sharing(ICS) to work).
  19. Now access internet in all laptops...ENjoy.
Note:- For Advance Users.. this information is necessary only--The IP address of server laptop work as the "Default gateway" and Preferred DNS server of Client laptop and on server laptop these fields are blank. Use same series of IP address as used in the server.
please vote if you found this helpful.. --Abhishek
on Sep 30, 2010 | Computers & Internet
Tip
Set up a computer-to-computer (ad hoc) network
An ad hoc network is a temporary connection between computers and devices used for a specific purpose, such as sharing documents during a meeting or playing multiple-player computer games. You can also temporarily share an Internet connection with other people on your ad hoc network, so those people don’t have to set up their own Internet connections. Ad hoc networks can only be wireless, so you must have a wireless network adapter installed in your computer to set up or join an ad hoc network.
Click to open Connect to a Network.
Click Set up a connection or network.
Click Set up an ad hoc (computer-to-computer) network, click Next, and then follow the steps in the wizard.
Notes
If one or more of the networked computers is joined to a domain, you need to have a user account on that computer to see and access shared items on it.
If the networked computers are not joined to a domain, but you want to require people to have a user account on your computer for access to shared items, turn on password protected sharing in Network and Sharing Center.
To turn on password protected sharing
Click to open Network and Sharing Center.
Under Sharing and Discovery, if password protected sharing is off, click the arrow button to expand the section, click Turn on password protected sharing, and then click Apply. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
An ad hoc network is automatically deleted after all users disconnect from the network or when the person who set up the network disconnects and goes out of range of the other users of the network, unless you choose to make it a permanent network when you create it.
If you share your Internet connection, Internet connection sharing (ICS) will be disabled if you disconnect from the ad hoc network, you create a new ad hoc network without disconnecting from the old ad hoc network for which you enabled ICS, or you log off and then log back on (without disconnecting from the ad hoc network).
If you set up an ad hoc network and share your Internet connection, and then someone logs on to the same computer by using Fast User Switching, the Internet connection will still be shared, even if you didn't intend to share it with that person.
I hope you all found this information useful and helpful.
Phillip
on Jul 31, 2010 | Computers & Internet
How to change browser to allow conection to internet
To connect to the Internet you need a few extra things aswell as a network or wireless card and install the LAN or wireless driver.
1. You need to sign up with an Internet service provider.
2. Connect a LAN cable from your computer to the DSL or cable modem
3. You need a DSL or cable modem and connect and configure the modem to inaccordance with your Internet service provider's instructions.
4. Install Internet Explorer if it has not been done.
5. If everything has been done correctly, when you open Internet Explorer youcan access the Internet.If you have a wireless router and it is connected to the DSLor cable modem then -
To connect to yourwireless router, the router needs its wireless settings to be configuredwith the SSID, encryption key etc., also the wireless cards in all thelaptops/computers needs to be configured with these router's wireless settings.Then the laptops/desktop computers can communicate with your wireless router.
Dec 27, 2011 | Computers & Internet
My wifi doesn't connect to any routers but it connect to my laptop ad-hoc.Still i am not able to use internet through ad-hoc.I have tried restoring my iphone, reset and erase settings, reset network...
Ad-hoc is a computer to computer connection.
You need to change the wireless configuration to Access Point (Infrastructure) mode with encryption.
Your wireless card in your computer or laptop needs to be configured with the router's wireless settings eg. the SSID and encryption key
The encryption key (network key) is in your wireless router, without this key the wireless router won't allow the computer or laptop to connect to this wireless router.
The WEP, WPA, WPA2 encryption key is in your router's wireless settings. Log into your router and got to the wireless settings, you will need to get the SSID and the encryption key. Then go to your computer or laptop's wireless card and configure it with the router's SSID and encryption key, so it will then connect to the wireless router and the Internet.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Dec 30, 2010 | Apple Cell Phones
Tip
Connecting ur Nokia N95 to internet through WIFI [No Wireless Router]
Tutorial for connecting ur Nokia N95 to internet through WIFI [No Wireless Router]
Hello mates,
Finally after 4 hours of searching and trying I was able to hook my Nokia N95 to my laptop without router and browse internet on my mobile.
I tried using my laptop’s Wi-Fi Card as router or connection point between my pc and my phone.
This connection is known as “ad-hoc” connection. Ad hoc wireless networks work more like walkie-talkies, because the computers communicate directly with each other. By enabling Internet Connection Sharing on one of the computers, you can share Internet access.
To see the difference between ad-hoc and router check the picture
With router
http://img127.imageshack.us/my.php?i...3669887ko0.gif
With ad-hoc
http://img408.imageshack.us/my.php?i...9484580ds9.gif
Now lets see what do we need:
1. We need a Wi-Fi card on the computer
2. Internet connection that doesn’t use your Wi-Fi card (example Like mine: Cable-modem connected to my laptop through LAN).
Now Let’s Setup our Wi-Fi card as router:
1. Click Start, and then click Control Panel.
2. Click Network and Internet Connections.
3. Right-click your wireless network connection, and then click Properties.
4. In the Wireless Network Connection Properties dialog box, click the Wireless Networks tab.
5. Next, click the Advanced tab at the top of the window. Select Computer to computer (ad hoc) networks only and clear the Automatically connect to non-preferred networks box if it is selected. This setting, along with removing preferred networks, ensures connection to the ad hoc network only.
6. Click the Wireless Networks tab again. Under Preferred Networks, click Add,
7. In the Wireless Network Properties dialog box, specify a Network name (SSID). I chose (My Nokia N95).
[img=http://img111.imageshack.us/img111/487/37714878od7.th.gif]
8. Unclear the box “ the key is provided for me automatically”.
[img=http://img87.imageshack.us/img87/9949/86872283hs2.th.gif]
9. Type your Network key password and confirm it in the second Network key conformation box( your password has to be 5 characters or 13 characters ), Press Ok.
[img=http://img503.imageshack.us/img503/9176/10is2.th.gif]
10. After configuring the network name (SSID) in the Wireless Network Properties dialog box, the new ad hoc network will be displayed with a PC Card icon to designate that this is a computer-to-computer network. Press also Ok.
[img=http://img111.imageshack.us/img111/4931/101mu2.th.gif]
11. Right-click the Wireless Network icon in the lower right corner of your screen, and then click View Available Wireless Networks..
[img=http://img503.imageshack.us/img503/7017/12yf6.th.gif]
12 . The Wireless Network Connection window appears and displays your wireless network listed with the SSID you chose( My Nokia N95). If you don't see your network, click Refresh Network List in the upper left corner. Do not click Connect in the lower right corner.
[img=http://img87.imageshack.us/img87/6600/13wm3.th.gif]
Now we have to share the internet:
14. Click Start, and then click Control Panel.
[img=http://img111.imageshack.us/img111/6918/14ta5.th.gif]
15. Click Network and Internet Connections.
[img=http://img503.imageshack.us/img503/5887/15xb5.th.gif]
16. Since I have a cable modem and it connected to my laptop through LAN so must share its connection with My Wi-FI card. Right-click the Local Area Connection and press properties.
[img=http://img503.imageshack.us/img503/4872/16ck2.th.gif]
17. Now you are in Local Area Connection Properties choose tab Advanced.
[img=http://img111.imageshack.us/img111/2746/17ih3.th.gif]
18 . select the Allow other network users to connect through this computer's Internet connection check box.
[img=http://img87.imageshack.us/img87/8369/18ve0.th.gif]
Now On Your Nokia N95 Phone (I have v20 Firmware) :
19 . Go to Menu>Tool> click on WLAN Wiz. Your Network name should appear ( in the example its “My Nokia N95”).
[img=http://img87.imageshack.us/img87/6633/screenshot0004vw7.th.jpg]
20. Select Option > Start Brwosing.
[img=http://img503.imageshack.us/img503/1807/screenshot0005wj4.th.jpg]
21. Now it should ask you for the Network key password you entered in step 9 and Press OK.
[img=http://img503.imageshack.us/img503/9264/screenshot0007yk6.th.jpg]
22. Now it opened the web so I chose Nokia Nseies web site ans start browse it.
[img=http://img87.imageshack.us/img87/4574/screenshot0010oq1.th.jpg]
23. While it connecting to” My Nokia N95” you should see that your phone Network status will appear Connected on your computer.
[img=http://img503.imageshack.us/img503/6197/19aw8.th.gif]
24. Wait for 30 Second and it will Open.
[img=http://img87.imageshack.us/img87/2649/screenshot0011qg4.th.jpg]
Note Important : you should turn you firewall off because it will block the connection and after you succeed connecting N95 to internet try configure your firewall so it will allow internet accesing.
on Aug 30, 2009 | Nokia 9500 Communicator
Can I download modem on dell laptop
Most of the time on laptops if there is no phone input for a modem you cannot just plug in and dial up. The process i use at home for my pc is dialing through my cell phone. If your carrier will allow you to tether your phone without extra charges check your phone manufacturers website for modem software. You then just connect your phone through a usb cable and set a internet connection matching your carriers instructions. Another solution is dificult without networking knowledge but you can set up a home pc with a wireless antennae as a ad-hoc server through internet connection sharing and then allow your laptop to connect through the "server" pc.
Apr 07, 2010 | Dell Computers & Internet
Unable to connect two wireless laptop for internt sharing
Make sure your computers are set to DHCP instead of static.
Sep 04, 2009 | Dell Inspiron 6400 Notebook
Connect itouch to internet
From what it sounds like, you are working in a Windows environment. What you are trying to do is bridge your wireless ad-hoc network with your wired network connection. Windows does not support this method of connection even though they have the option for "allow other network users to connect through this computer's internet connection". That would only work if you had two ethernet cards in your system, and that option bridges one ethernet port with the other. It doesn't support bridging to your wireless adapter.
Most laptop wireless cards do not support an "infrastructure" mode, which would turn your notebook into a mobile router. Instead they create an ad-hoc network completely separate from your wired network. There are some commercial pieces of software that can bridge the two, though I've never been able to make them work.
The easiest route would be to go to Target or a local electronic store and pick up a wireless router. You would take the ethernet connection from your laptop and attach it to the router. Then your laptop and iPod would both connect to the internet through the router.
Mar 29, 2009 | Apple iPod touch Second Gen (8 GB,...
Coneecting to wirles router Phillips SNB5600/00
sounds like the router can only handle two local computers. I'm not familiar with a router by philips, assuming you got it from your ISP call them and make sure that it can support more then two computers, they might want extra money for more computers. Since I do not agree with that type of business model you can get overo n them by adding your own router (I prefer linksys) and then you can connect up to 255 devices to your internet connection and your ISP will think it is only one.
Dec 29, 2008 | Computers & Internet
Computers & Internet Logo
95 people viewed this question
David Payne
David Payne
