Question about Sony Grand WEGA KF60XBR800 60" Rear Projection Television
Sony K60XBR800 I HAVE UPGRADED MY DIRECTV EQUIPMENT DUE TO SOME NEW CHANGES AND I HAVE AQUIRED SHADOWS OR GHOSTS. I HAVE THIS PROBLEM ON REGULAR CABLE, SATELLITE AND WHEN WATCHING A DVD. WHAT DO YOU SUGGEST. THANKS, RR
  • geegster Sep 13, 2008
    hello~
    I am trying to implement this fix on my sony kf60xbr800.
    In the instructions, it states (in multiple steps) to:
    "Change data from 1 1 ->1"
    What button to I use when the instructions say this?
    I don't know how to "change the data..."
    your help is totally appreciated!!!
    Thanks!
    President:
  • 4,402 Answers
Model
KF50XBR800, KF60DX100, KF60XBR800
RESOLUTION
Yes. Try the attached procedure. This has proven to be very effective.
Enter the service mode by pressing Display, 5, Vol +, Power.
Press Menu and go to Setup. Select Image Revision and set to 1. Press Menu once to exit the menu screen.
Cycle thru the service mode using button 5 until you get to D-GM TG. Press number 1 on remote once. You should now be at the 1 POS CTL. Change data from 11->1.
Push the number 1 button on the remote 14 times until you are at 15 ENB POS. Change data from 5->23.
Push number 1 button on the remote 8 times until you are on item number 23 PRG POS. Change data from 0->2. Write the data to memory by pressing MUTE, ENTER.
Push number 2 on remote 6 times until you are at H POS SHIFT. Proceed with the following steps very carefully. 0 VAR POS-CTL=0. Press number 1 on remote. Change D-GM HP item 1 from 9->11. Write the data to memory by pressing MUTE, ENTER.
Press 4 on remote. Change to 0 VAR POS-CTL=1. Then press #1 on remote. D-GM HP ITEM #1. Change data from 9->11. Write data.
Press 4 on remote. Change to 0 VAR POS-CTL=2. Then press #1 on remote. D-GM HP ITEM #1. Change data from 8->10. Write data.
Press 4 on remote. Change to 0 VAR POS-CTL=3. Then press #1 on remote. D-GM HP ITEM #1. Change data from 8->10. Write data.
Press 4 on remote. Change to 0 VAR POS-CTL=4. Then press #1 on remote. D-GM HP ITEM #1. Change data from 7->9. Write data.
Press 4 on remote. Change to 0 VAR POS-CTL=5. Then press #1 on remote. D-GM HP ITEM #1. Change data from 7->9. Write data.
Press 4 on remote. Change to 0 VAR POS-CTL=6. Then press #1 on remote. D-GM HP ITEM #1. Change data from 6->8. Write data.
Press 4 on remote. Change to 0 VAR POS-CTL=7. Then press #1 on remote. D-GM HP ITEM #1. Change data from 6->8. Write data.
Press 4 on remote. Change to 0 VAR POS-CTL=8. Then press #1 on remote. D-GM HP ITEM #1. Change data from 5->7. Write data. Press 4 on remote. Change to 0 VAR POS-CTL=9. Then press #1 on remote. D-GM HP ITEM #1. Change data from 11->7. Write data. Press 4 on remote. Change to 0 VAR POS-CTL=10. Then press #1 on remote. D-GM HP ITEM #1. Change data from 11->6. Write data. Press 4 on remote. Change to 0 VAR POS-CTL=11. Then press #1 on remote. D-GM HP ITEM #1. Change data from 11->6. Write data.
Press 4 on remote. Change to 0 VAR POS-CTL=12. Then press #1 on remote. D-GM HP ITEM #1. Change data from 11->7. Write data. Press 4 on remote. Change to 0 VAR POS-CTL=13. Then press #1 on remote. D-GM HP ITEM #1. Change data from 11->7. Write data. Press 4 on remote. Change to 0 VAR POS-CTL=14. Then press #1 on remote. D-GM HP ITEM #1. Change data from 10->6. Write data. Press 4 on remote. Change to 0 VAR POS-CTL=15. Then press #1 on remote. D-GM HP ITEM #1. Change data from 10->6. Write data.
Press #5 on remote 6 times back to catagory D-GM TG INV CTL. Press number 1 on remote once to the Catagory D-GM TG 1 POS CTL. Change the data value to find the best setting where no double images, ghosts nor merged colors appears. WRITE DATA.
Press #2 on the remote 11 times to the Option-E O Lamp Time. Note the current value and write it down. Add 2000 to the value (ex if 1356, than 1356+2000= 3356). Divide this number by 100 and write this value to the Option-E 11 P CTL SHT1. For our example above we would have 3356/100= 33.56. So we can round to 34.
Now add 50 to this number. In our example we would have 34+50=84. Write this value to the Option-E 12 P CTL SHT2. Make sure to write the data.
Select AUTO in the menu for the Image Revision setting and exit the menu screen. Confirm that the picture is fine.
Posted on Feb 06, 2008
There are shadows or ghosts in the picture
This is normally caused by bad grounds in the cabling. Check or replace the cable. Also check your manuals and be sure the cables don't have to be terminated
How to Fix LCD Monitor Ghost images
Aug 14, 2015 | Home Security
Before the tv warms up for about 20 minutes it will turn on and show lines across screen and ghosts or shadows
hey there it sounds like the problem is coming form your digital video board this parts run around $69.99dlls-$109.99dlls I recommend you take the part out and get the part number from the board this website has a lot of parts for your TV set
http://www.discount-merchant.com/SearchResults.asp?Search=KDL40XBR3
Sep 03, 2010 | Sony Bravia KDL40XBR3 KDL40XBR4 KDL40XBR5...
My Hitachi 43fdx01B went from a perfectly clear picture to one with red "ghosts" and very blurry. I my TV toast?
No,ur tv have a problems,known as a convergence problems,it dead.Very common problems on the DLP tvs design flaw.Most commom problems are R,G,B mis alignment,will not align,Colors shadows pictures,3D pictured and blurry?The tv convergence board require changing the 2 STK convergence ICS and some or all it resistors are dead,must changes to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 26, 2010 | Hitachi 43FDX01B TV
Picture is distorted from center on my 65" Sony projection TV.
hi. this will be an easy fix for you if you are a good solder. you will need to replace the convergence chip that is located on the PC board(main). this chip is damaged and it has failed due to this damage that has occurred. click below for your new convergence chip(stk).
CLICK HERE
May 21, 2009 | Sony Grand WEGA KDP-65WS550 65" Rear...
Getting Ghosts and color line separation.
my sony kp-57wv600 is showing a ghost of the image in all three colors.. anyone no how i can fix
Dec 27, 2008 | Televison & Video
Shadows and Ghosts on the Screen
Plugged up display via the VGA cable to an HP dv6000 laptop; the Acer powered up and displayed fine ... however, noticed a faint waving motion in the picture, as if the screen was literally gel and began to wave, from top to bottom as it appeared. Best I can describe it ... any suggestions as to why? I only connected it to this HP to try it out, I ordered it from newegg and wanted to make sure pixels werent dead on arival. I will be getting an Aurora 7500 (Alienware): AMD X2 6000, Windows Vista Premium, 2GB RAM, GeForce 512 8800GT, SLI ready motherboard ... I heard good things of Acer and hoped this display would look great with my soon-to-come setup and im sure it will. However, just nervous it will do this on my Aurora. Any help or suggestions would be beyond appreciated!!
Feb 19, 2008 | Samsung SyncMaster 191T 19" Flat Panel LCD...
Ghosts on my tv
if you can, try hooking up the tv to a different cable line in the house or bring a different tv into the room where the bad picture is [ you may have a bad connection or wire ] if this doesn't help, try rabbit ear antennas just to get a picture. if you still have ghosts on your tv, the problem is with your tv.if the picture is fine, there maybe a problem with your cable service.
hope this helps
wg
Feb 10, 2008 | JVC AV-56WP74 56" Rear Projection...
Ghosts or shadows around images
I always start my Hitachi research at their website.........
www.HitachiServiceUSA.com...................T.
Nov 28, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
Ghosts in Tv Projection TV
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Aug 02, 2007 | Philips 60PP9352 60" Rear Projection...
Sony Grand WEGA KF60XBR800 60" Rear Projection Television Logo
538 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
