Question about Alpine CDA 7893 CD Player
1998 buick regal has dash lights flashing and turn signal cut power off
You can start to crank the car and all the dash lights start flashing. when you drive the car down the road and turn either turn signal on it will completly kill the power of the car
  • Anonymous Feb 05, 2009
    My dash lights flash and then the car dies.
  • 24 Answers
SOUNDS LIKE YOU HAVE A SHORT IN THE VEHILCE PROUBLY IN DASH OR COLUMN BUT FIRST CHECK BATTERY MIGHT HAVE DEAD CELLS MAKE SURE CABLES ARE TIGHT AND CLEAN
Posted on Mar 07, 2008
  • 2,039 Answers
Do you have to boost the car look like alternator problem if you charge the battery is it good for a day or so if it that i ts our alternator if not let me no thank for using fixya pierre
Posted on Feb 05, 2008
I have a buick regal super charger 1998, the car want stay started up when cranking.
You mean it "won't"? Test fuel pressure while cranking. Test for weak spark.
Jul 08, 2016 | 1998 Buick Regal
When you turn the key on , not to start the car just turning the key foward all the lights flash repeatedly, on the dash of my 2003 Buick Regal. What could cause that? It might take 5 minutes or 10 minutes...
Ignition switch is bad and needs to be replaced. My 03 Regal did the same thing and playing with the hazzard swith would make it stop. New ignition switch fixed it.
Jul 13, 2010 | 2003 Buick Regal
2000 buck regal: flashing dash lights, car won't
Could be a ground problem , do you know about automotive electrical circuit's ? Has a B+ voltage side an a ground side to compleat the circuit back to the negative side of the Battery ? Looking at wiring diagrams for the affected system's i see they share a common ground point . G 201 ,do you know about body grounds ? I would look for a loose connection . G201
Below the IP, left side of the steering column
Dec 23, 2017 | 2000 Buick Regal
1998 Buick Regal GS, Several problems are
start by checking the front wiring harness for corrosion , best is to do a continuity test on all the wires, look for corrosion in connecting harness, time consuming but the only way
Nov 28, 2009 | 1998 Buick Regal
Car will not crank and all instrument cluster lights flash
If it has a remove starter I would have that looked at or disconnect to see if that makes a differance.
Aug 05, 2009 | 2001 Buick Regal
I have a 1999 buick regal ls dying.
I have a 99 Buick Regal and it too dies out, but only when I use my turn signals. Sometimes, when trying to start the car...the dash lights would flicker and you can hear some sort of electrical ticking sound. As of today, my car will not start (5/24/09) it hadn't turned over since yesterday. After a process of elimination and searching the net, I think I need a new ignition switch. You may need one as well.
May 18, 2009 | 1999 Buick Regal
My buick regal doesnt send signal from pcm to crank relay.
check pcm with a scanner to see if crank and cam sensor are working.
Mar 28, 2009 | 1998 Buick Regal
2003 regal clusters flash on and off several times and dies
might be the crank signal sensor, try turning your key to the on position and all the lights on the dash should flicker on and off leave the it in the on position and go to the passenger side fuse panel and take out fuse 4A, the fuse for the CRANK SIGNAL , BCM, CLUSTER. if your dash stops blinking then its probably your crank sensor.
Dec 01, 2008 | 2003 Buick Regal
Alpine CDA 7893 CD Player Logo
159 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
