Question about Toshiba 2060 Copier
Not printing properly....alignment
When we use the automatic feed the copies are being cut off on the edge of the paper. It is not centering them on the page, so it is not coping the full page. Did that make sense.
Thanks Mary
  • 1 more comment
  • Mohler Feb 05, 2008
    Adding a little bit more info. It also misprints when you lay it on the glass in between the correct marks. But if you shift it forward on the glass it will align the print correctly.
    Mary
  • Mohler Feb 06, 2008
    I really didn't understand what you are telling me to try. Which paper do I put in the bypass tray?
    Where do I put the original, on the glass or on top in the automatic feed tray?
    I think I need a picture drawn for me.
    We have only been using this machine for a cople of months. It was 2nd hand for us.
    It was working great untill recently.
    Thanks for trying to help.
  • JDavid90 Feb 02, 2009
    I have a Toshiba 2060 model - The top edge 1/2 inch is not printing when I try to print letter size but it does print when I print legal size. I believe it might have something to do with the letter size tray. Could you please tell me how to fix it ?????
    thank you,
    jenny
  • 589 Answers
It is possible that the guides in the paper tray have moved?
If they are universal trays (meaning they are not locked down to only use one particular size), they could have easily shifted, causing what you have described.
Try copying using a sheet of paper through the bypass tray, and see if the image is centered. This will at least narrow down the problem to a particular tray.
Posted on Feb 06, 2008
  • brian c
    brian c Feb 06, 2008
    If you would of asked me for more information instead of giving me that rating, I would of helped you further.
    Good luck.
MFC 240C print quality is excellent but prints crooked on page. Ran alignment multiple times, no help.
When the paper does not feed straight, dirty or sticky rollers can cause it to jamb or crinkle, also failure to remove all traces of paper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these pieces of paper. The rollers may be dirty or sticky and causes the paper to not feed straight.
Try cleaning the rollers with methylated spirits.
Mar 30, 2013 | Brother Multi-Function Center MFC-240C...
HOW TO ALIGN SCAN IN A PAPER WHEN COPING
Two ways
1-just lay the paper on top facing up and hit copy and it will feed in to the rollers and print
2-open the scanner, and lay paper face down using the built in marker, "edge", and close lid hit scan
May 17, 2010 | Lexmark X2500 All-In-One Printer
MP830, how to retrieve faxes in memory to my PC
- A margin appears
on printouts.
2 B Paper feed
Improper paper
feeding:
- Multi-feeding
- Skewed paper
feeding
- Paper jam
- Paper feeding from the
ASF
- Plain paper
- Highest print speed
(Custom setting to 5)
- In the high temperature
and high humidity
environment
- In the low temperature
and low humidity
environment
- With the maximum
amount of paper set (13
mm)
and high humidity
environment, paper
becomes wavy; in the
low temperature and
low humidity
environment, paper
curls significantly.
When the maximum
amount of paper is set
in the ASF, and if the
paper-return tab fits in a
wave or curl of the
paper, the tab slips and
does not catch paper
properly, causing paper
feed problems.
- Reduce the amount of
paper set in the ASF to
half (approx. 5 mm
high).
- Multiple sheets of
paper feed at the
same time.
- Paper feeds at an
angle.
- A paper jam
occurs.
3 C Print results
Skewed paper
feeding (at the
level of +/- 1%)
ASF
- Credit Card size
Since coaxial tolerance
between the pinch roller
and the LF roller, which
determines the paper
feed alignment, is
0.2mm, skewed paper
feeding can occur.
However, according to
the field data of current
models, the skewness
level caused by the
coaxial tolerance of
0.2mm is within the
criteria of +/- 1%, thus
the phenomenon is left
as is.
- Align the paper guide to
the paper edge tighter
than usual.
- Paper feeds at an
angle.
- A margin appears
on printouts.
4 A Print results
Soiling on the
back side of paper
(lines or streaks
parallel to the
paper feed
direction)
- After continuous
borderless printing of
small sized paper (such
as 4 x 6), when a larger
sized paper (such as A4)
is printed.
- With Photo Paper Plus
Double Sided or
postcards, the
phenomenon is likely to
be noticeable and to be
complained of by users,
as printing is performed
on both sides of such
paper.
In borderless printing,
printing is performed to
the size slightly larger
than the paper size, and
ink off the paper is
absorbed by the platen's
ink absorber. Absorbed
ink may attach to the
platen rib(s) after
several dozen sheets are
printed, causing soiling
at the leading edge of
paper or on the back
side of paper.
1. Perform Bottom plate
cleaning (from the
MP driver or via the
operation panel) up to
3 times*1.
2. If soiling on the paper
still remains after 3
times of Bottom plate
cleaning, wipe the
platen rib(s) and their
surroundings with a
cotton swab.
- Paper gets
smeared.
- The back side of
paper gets
smeared.
Soiling on paper in
automatic duplex
printing (lines or
streaks
perpendicular to
the paper feed
direction)
- Automatic duplex
printing (Photo Paper
Plus Double Sided,
postcards, plain paper)
On the rib(s) inside the
sheet feed unit used for
duplex printing, ink
mist may accumulate,
smearing paper.
Temporary operational
solution:
Cancel automatic duplex
printing, and manually
print each side of paper.
Cleaning by user:
cleaning (from the
3 times*1.
- Paper gets
smeared.
- The back side of
paper gets
smeared.
- Even after Bottom
plate cleaning
was performed,
and the platen
ribs were cleaned
with cotton swab,
paper gets
smeared.
2-10
Oct 12, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Doesn't recognize paper when loaded
When loading the paper, the edge sensors can be a bit tricky.
Pull the paper through the main guide with the locking plate released. Guide the paper edge it's right along the blue (not over it, just along the left edge of the guide markings on the body of the unit). Pull the paper through and then guide it back so that the lead edge just barely shows up, below the small, black rollers in the main print area. Now lock it down and reboot the system.
Once the print head alignment has finished the unit will pull the paper through and then move it forward and back until it is properly aligned, then cut off any excess it detects.
You should now be able to print. Note: Please do not re-adjust the paper edge after this process is complete.
Aug 09, 2009 | HP DesignJet 1050c plus InkJet Printer
New cartridges - printer not printing
Align your cartridges to solve print quality problems such as: • Characters are not properly formed or are not aligned at the left margin. • Vertical, straight lines are wavy. 1 Load paper in the paper support. 2 On the control panel, press Copy. 3 Press Options until Maintenance appears. 4 Press the right arrow until Align Cartridges appears, and then press Select. An alignment page prints. Once this page prints, your automatic alignment is complete.
Please rate this solution.thanks and good luck.
Jan 22, 2009 | Lexmark X6170 All-In-One InkJet Printer
Paper not feeding in order to print
make sure the input tray is properly setup and aligned, the tab is pushed against the paper.
Dec 12, 2008 | HP LaserJet 1018 Printer
Switch the way the paper comes out of the machine
Sounds like your tray settings are incorrect. Make sure that if the tray is set to 8 1/2 X 11 in the menu settings(not 8 1/2 X 11R) that the paper is set in the tray to feed the long edge first. The machine is capable of automatically rotating the image to fit the paper as long as the paper is set correctly.
If you prefer to feed short edge first then set it for 8 1/2 X 11R.
Oct 14, 2008 | Sharp AR-M205 Copier
Brother HL 2040
Make sure the paper aligning slides are tight to the sides of the paper. In the case that they are spring loaded make sure there is not something preventing them from holding the paper properly aligned.
The print head could be 'off-track'...
If the text is properly aligned on the edge of the page, but appears crooked it is related to the print head assembly. If the text is not aligning to the edge of the page then the paper is not feeding straight and the paper aligning slides are at fault.
It is also possible that one of the paper feed rollers are not grasping the paper and it is forcing it to one side as it pulls it in.
Mar 10, 2008 | Brother HL-2040 Laser Printer
Laser Jet 4 Plus
Make sure your sheets are aligned and tucked in with the paper feed rails, otherwise, it will slightly veer off one of the sides.
Also, if you haven't replaced the paper feeder rollers, do so, one must be worn out more than the other, and this also prevents the sheets from going through straight.
Hope That Helps!
Feb 01, 2008 | HP LaserJet 4 plus Printer
281 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
