Question about Akai LCT2662 Television
OFF AFTER 10-15 MINUTES
UNIT POWERS ON OK BUT AFTER 10-15 MIN GOES OFF. RED LED STAYS ON BUT GREEN GOES OFF. WAIT SOME TIME AND THE UNIT DOES IT AGAIN
    Scholar:
  • 27 Answers
This is usually caused by damaged capacitors (Akai uses very cheap components) on the power supply board. There are nine large electrolytic caps that have to be replaced. Hope this helps you out.
Posted on Feb 29, 2008
What is wrong with Acer P7280 projector? The lamp goes out after 10 min. use, and red lamp error led turn on
the lamp must be ok
the ballast may be fault
or the mainboard is fault
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Lampdeng Limited
Jerry
Jun 18, 2014 | Acer P7280 OEM Projector Lamp
I have a 50" Philips
Most likely the power supply capacitors are going bad.
Opening the TV and replacing any swollen caps may solve your issue.
Thanks
Roety
Aug 16, 2011 | Philips Televison & Video
Unit powers up for 5- 10 min good picture....then it goes black power light goes from green to red and flashes once and solid and repeats pattern .........if i go up to unit and push power off and back on...
There is circuit problem inside. For safety reasons power might get shut down! Unless the fault is rectified, this problem will continue. Do not attempt switching ON again & again. Get authorised service center assistance.
Apr 20, 2010 | Televison & Video
My tv 32pw9617 switches of by itself.
sounds lick you may have a dry joint in the powers or line o/p stage.
as a rare fault it could be the crt with an intermittant internal s/c. but you would notice the colour was tinted either red, green, or blue in the dark areas of the pic.
Jul 13, 2009 | Televison & Video
TV powers off for no reason
Its your bulb on its way out.
the replacement bulb is a Sony XL-2400 But yours should definately be under warranty
Mar 20, 2009 | Sony KDF46E2000 46" Projection HDTV
My Sony HD-TV KDF-50E2000 is about 18 months old. The picture went out. The green on light stays on for only a few minutes then goes off and the red lamp light flashes. You can turn the Tv on again and the...
How many times Red Lamp flashes, its important as it shows problem and its location in tv. Below is detail of lamp blinks and you may know the problem area in tv by counting lamp flashes.
Need further help, let me know.
Sep 13, 2008 | Televison & Video
Hitachi 50DX10B Power issue
Rollo, broken solder connections either in low voltage or sweep section of the board, probably in the horizontal out put area but could be anywhere. If you want to attempt the fix the board has to come out and you`ll need a bright light as well as a good magnifying glass to find the broken joints and then re-solder them, Be certain your tv`s AC cord is removed from the wall outlet before doing any soldering, good luck, BMW Rider
Dec 13, 2007 | Hitachi 50DX20B 50" Rear Projection...
Automatically powers off, flashing red LED
try removing one neck board at a time and see if it stays on and longer,don;t let the board touch any metal or a short wil follow and you got problems.try the red first,
Sep 03, 2007 | Toshiba 43H70 43" Rear Projection...
Akai LCT2662 Television Logo
51 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
