Compresor is hot, have voltage in compresor conector, capacitor is ok and dont run? what next?
First unplug the machine. carfully remove the cover on the side of the compressor the get to the start device. Remove the start device. Once removed you will have 3 prongs from the compressor. Using a meter make sure you have continuity between each of the three prongs if you do not then the compressor is bad. If all check good then check each prog to the groud of the compressor or the case, if you have continuity then the compressor is bad. If you have passed both tests then you can try a new start device. after you replace the start device you will want to test the current draw from the compressor to make sure that it is not what is causing your start device to fail.
Note :The compressor is a sealed unit and its life can't be determined. puting a new start device on your compressor is a good idea and most of the time will solve your problem. But if your compressor is the cause of the problem it will only last about 30 days.
