Question about Epson AcuLaser C1900 Printer
K toner cart out, Epsom C1900 Aculaser color printer
Need some helpe
Moved the printer to a different location, and it was not used for 3-4 months. Now, it prints as if there ain't no color ( although , I have replaced all the toners a few weeks ago, with epson original). Paper keeps jamming after nearly 80% of printing. Any color on a page, the printer jams. Printing word doc just in black, are always 5-6 cm below margin, even in print preview it looks ok.
I have made a big mistakes, I have contacted the technician at Epson, online chats. they suggested to remove the photo conductor unitand the transfer unit. They told me to give a good clean with cloth which i did. when I inserted everything back. now I am getting another problem. I have removed photo conductor and transfer out again.
This is the , message I am getting
  1. K toner cart out.
K toner is new, was working before tips from epson.
I contacted epson again, they said to take the toner out and re- insert again. I did a few times.
The problem persists, now I can't even use the printer to even to print in black.
  • 27 Answers
I had the same problem as you i feel very upset with epson that they did not help you for me what i had to do is lay my printer on its side with the door to the toner facing you taking the toner out looking down into the bottom you will see a little plastic block wist it half way till it stops then reinsert the toner becarefull not to drop it in that shoud be fully fitted inside then put the unit back the right side up and start the printer up this shpuld fix your problem ok thanks
Posted on May 22, 2008
I cannot change AL-C1900 black toner because when I hopen the door there is magenta toner.
Go to the RESET menu. The last item is Change Toner Cartridge, then find the sub-menu item for the toner you want to replace.
May 22, 2011 | Epson AcuLaser C1900 Printer
We have an epson aculaser c1900 which is telling us to replace the waste t-box. What does this mean?
Hi, Waste toner container collects all the unused toner from inside the machine after every cycling, unfortunately the container gets filled up and needs6f1b8e0.jpg to be emptied at intervals. The container looks like the image inserted, just open up your printer and locate the container and empty it then reset and all will be well.
Mar 17, 2010 | Epson AcuLaser C1900 Printer
What does error code EO23 mean on an Epson Aculaser C1900
this error refers to a misalignment of the carousel, i have one that randomly does it at the moment, i also have a replace black toner even though the toner is full, i'll get back to ya when i find a fix, the service manual says it can either be the 2nd motor, clutch or sensor, but in my case all three are working fine.
Oct 07, 2009 | Epson AcuLaser C1900 Printer
EPSON AcuLaser C1900 with Error "Service Req E020"
�� Electric parts which can cause the trouble:
• Transfer Roller Pressure Solenoid (SL2)
• Transfer Roller Pressure Position Detection Sensor (PC7)
• Engine Board (PWB-A)
May 18, 2009 | Epson AcuLaser C1900 Printer
Prints black perfectly/colour print blank
the photoconductor unit may need replacing ? have you given your printer a service ? clean out all the dust from your unit making sure you dont touch the conductor unit do the best you can and try it again ok making sure the wast collector is empty too thanks
Apr 16, 2008 | Epson AcuLaser C1900 Printer
Service require E008
E008. Is a Main Motor Problem.
Main Motor, Engine, power unit
E021. Transfer Belt Cleaner Contanct/ Rease Problem.
Cleaner pressure flapper solenoid, Belt cleaner detect sensor, engine PCB.
Make sure inside on unit, has no toner spilled in it.
Feb 14, 2008 | Epson AcuLaser C1900 Printer
Epson AcuLaser C1900 starts printing too low
I have a C1900 with an error "Service Req E021". I appreciate any help as to what this refers to please.
Jan 05, 2008 | Epson AcuLaser C1900 Printer
Epson AcuLaser C1900 paper jams and almost no ink
If paper jam occurs frequently, wipe the pickup roller with a clean dampened cloth. Follow the steps below:
  1. Open Cover AB of the printer.
  2. Open the cover below the paper path roller.
  3. With a clean dampened cloth, wipe the pickup roller.
  4. Close Cover AB.
If the glass on the print head filter is dirty with toner, wipe it with a clean cloth. A vertical white line may appear in the printout. Follow the steps below:
  1. Open the front cover.
  2. Tilt the waste toner collector and pull it out.
  3. Grasp the handle of the print head filter with your fingers and gently pull it straight out of the slot. (**Note: Be careful not to spill toner that has accumulated on the print head filter. )
  4. With a clean cloth, wipe the glass surface of print head filter.
  5. Hold the print head filter by the handle and gently insert it all the way into the slot.
  6. Reinstall the waste toner collector.
  7. Close the front cover.
The print quality problem might be something as simple as turning off the Toner Save mode using the printer driver or the printer's control panel menus.
There may be a problem with the photoconductor unit. You may need to replace the photoconducter unit.
Or it might be something rather more serious (hopefully, not)Print out a status sheet. If a blank page is ejected, the problem may be with the printer. Turn off the printer and contact your dealer.
Jan 04, 2008 | Epson AcuLaser C1900 Printer
The Cleaner Pressure Flapper Solenoid it dead or dying. You can try moving it by hand to see if you can prolong it, but basically it needs a new one. Its a job for an engineer really.
See the image below for it's location.
Sep 17, 2007 | Epson AcuLaser C1900 WiFi Printer
Magicolour 2300 Toner cartridge problem
There is a Radio type sensor in the cart. First thing to try is a different cart. If the problem persists you will need check the operation of the receiver end. I think your machine is the rebadges Epson AcuLaser C1900 so getting a service manual for that machine may be of use.
Oct 11, 2006 | Minolta magicolor 2300W Laser Printer
Epson AcuLaser C1900 Printer Logo
493 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
