Question about EliteGroup L7VMM2 Motherboard
Power Supply for L7VMM2
Need you help with an eMachine c2280. Had to change power supply after power outage in area, but with new power supply there is no power to the m/board (L7VMM2). What else could be wrong?
  • 2 more comments
  • lradams244 Feb 05, 2008
    Thanks for the reply. Another question if there was problem with the board should I have seen some tell-tale sign on the resistors?
  • cathiepie Jul 09, 2008
    PSU died and was replaced. New one works and machine will start up . Power light is orange and stays on only for a few seconds, the boot sequence occurs and lights up all of the drives in sequence. The fan on the motherboard runs and the motherboard led1 light is on and stays red.
    There is no output to the monitor, but the monitor tests fine with another pc. Where do I go from here?
  • Anonymous Dec 27, 2008
    LED1 and the fans turn on, but nothing else seems to be happening.
  • Anonymous Apr 19, 2009
    I have the same problem. Not the cmos battery, not the video unless there is a jumper to bypass the onboard video I dont know about [I tried 3 pci cards], not the power supply (old one works, but tried brand new one. Could be the bios chip (shot) since there is no POST, or mpu, or mother board. Not the memory chips or slots as far as I can tell, had to remove them to re-seat the mpu so I tested them one at a time. Sooo, looks like it's the motherboard, since I wont be able to tell if bios accepts zapping, I will canabilize what I can and buy a $28 "Tiger special" motherboard that uses the same **** and run it until "IT" burns out. Cheap junk anyway!
    Champion:
  • 207 Answers
Try check the cable connections, try to reseat it properly to those pins of your motherboard..
try go to this link:
http://www.orpheuscomputing.com/computers/PSU-terminology-notes.html
hope, this will work..goodluck!!!
Posted on Feb 05, 2008
    Scholar:
  • 119 Answers
Well,if you are sure that the new power supply is new and ok,than more than sure,if you dont have any response from the mainboard,that it is damaged by the high tension who allready burned your initial power supply.
I suggest you to visit a specialised service because for now its nothing you can do more.but first be sure you have a quite functional new power supply.
bye
My e machine computer will just shut off after 5 or 10 min.,
I had an Emachines W3609 that did the same thing, I changed the 350-watt power supply with a 550-watt and it still shut off, even using the newer one. I thought just the first one was bad but I guess not. It had more than enough power to power it up but nothing. And it used to randomly restart at times and then just shut off. Try and get a new hard drive maybe that will help. Good luck!
Jan 03, 2013 | E-Machines Computers & Internet
Pc desk the problem is the exit to the pc to
Would you like to re-phrase the question so that we may better understand ?
Aug 21, 2009 | E-Machines Emachine C2280 Power Supply...
Ok i have a emachine c2280 we put a new power supply changed the ram and i have no video, there is also a red light next to the ram what isit..
Anytime. Just in case you there is any way you can get video to display. There is a setting in bios to change what controls the display adaptor. You might want to try to reset your bios and see if you can change this setting. Figure there is nothing you can hurt at this point.
Just remove the "watch battery" that is on the motherboard for a couple minutes and try to start the computer. Also you might want to look for some pins on the board that say something about bios reset jumpers. Normally you short the two pins then remove and boot. Sometimes you short-boot-shutdown-unshort-boot again.
I'm thinking though if you can get in there you can set your display to pci or agp or whatever kind of video card you have.
Jan 29, 2009 | E-Machines eMachines Desktop PC
NEED POWER SUPPLY FOR ELITEGHROUP L7VMM2 MOTHERBOARD
There is no specific power suppl that you need. The only differce is the wattage 300, 350 , 500 etc. Your motherboard will work with all types not to worry. The only reason you get a higher wattage power supply is if you plug in a lot of stuff. say you have 3 HDD and 2 CDROMS then you would need the 500 Watt power supply.
Jan 05, 2009 | E-Machines (ATX-300GT) (ATX30012) 300-Watt...
Can u possibly tell me where i might be able to download a schematic for an EMachine desktop computer model #T2742? It is out of warranty and was donated to our church and we need to know where to...
Hi dallasblue08,
Here's a diagram of what your looking for:
The following eMachine models share the same motherboard (and thus the same front panel layout):
T2742 T2796 T2798 T2824 T2885 D2823 T2862 T2896 T2898 T2958
Hope this helps!
Mark
Jan 04, 2009 | Computers & Internet
Cant get any picture through the moniter tryed agp vidieo card and pci vidieo card still nothing the motherboard is out of emachines c2280 L7VMM2
Sounds like you have a bad power supply or motherboard. The power supplies in eMachines are not known for reliability, so try testing the system with another one. If you still have no video, you should replace the motherboard.
Dec 13, 2008 | EliteGroup L7VMM2 Motherboard
My computer want turn on
change your smps.
if your computer is old then put new cmos cell.
in *********** bord.
check smps first.
Nov 15, 2008 | E-Machines eMachines Desktop PC
L7VMM2 shuts down
I think you have overheating problems
Check all fans are working and vanes are clean including power supply one
Check heat sink on CPU that the vanes etc are clean and clear of dust and fluff
Give case a vacuum out including all vent holes also the ones on inside case of power supply
see how you go this problem is usually the cause of persistent reboot
Sep 24, 2008 | EliteGroup L7VMM2 Motherboard
T2085 will not turn on
it does sound like a power supply. you can pick one up for around 80 bucks retail. they aren't that hard to install. 2 plugs on the mobo and one for each drive you have installed. all you do is unscrew the current power supply (4 screws on the back), then unplug all wires connecting the power supply to the components. then take out the old power supply and work in reverse with the new power supply.
if the computer doesn't work after that, it is possible that you need a new mother board. in that case, personally i would return the power supply and start looking for another computer.
but hopefully it is just the power supply.
Agent 10708
May 29, 2008 | E-Machines eMachines Desktop PC
One problem, followed by another, followed by another
it seams that the motherboard has some power problems. Check on the motherboard for burned or blackened components, or for capacitors that are looking like they are going to blow (inflated on the top), u can do the same to the power supply.
If so change it !
Also maybe the power of the house has problems that the computers power supply cant handle (that can ruin the motherboard or other components )
U can also try to isolate the motherboard from the case (there might be a short between the motherboard and the power supply through the case metal ... )
Jan 20, 2008 | EliteGroup L7VMM2 Motherboard
EliteGroup L7VMM2 Motherboard Logo
251 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
