Question about Toshiba 50H81 50" Rear Projection Television
Toshiba 50h81 I bought this tv used, and noticed that the tv will go off by itself in the middle of viewing, but come right back on. The red led that indicates the power is on stayed lit up. The tv was manufactured in Sept 2001.
    Problem Solver:
  • 5 Answers
It happens to my toshiba.. once in a while and gradually shutsdown every minute during the last 2 mos..
Mine is Toshiba 55 TZ, have it since 98', shutdown and red light blinking problem, search the net and found out, generally a Convergence IC (stk392-110) problem. bought 2 for $15 at suburban-elect.com (ebay). replaced following direction from http://www.casiasfamily.com/repairlog/tp50h15.html
Open back cover, 9 screws and wirings (pls mark), removed(soldered) a electronic board infront of convergence ic. removed IC (stk392-110) (screwed and soldered).
Replaced everything and voila...! it is now working again..
no more shutsdown and red blinking light. Saves mo $400 for a repariman. of course just be careful with static and stuff.
I don't know how to solder, so I ask friend to do it for me. But I did the rest. Just to give you an idea that it can be done even if you don't know much about electronics. This in no way a recommendation but just stating my experience. Follow at own risk.
Posted on Mar 17, 2008
Red led blinking. tv wont turn on model number
Hi Rick,
First of all, thank you for posting your question here at Fixya.
My first advice is to unplug the unit from the outlet at least 30 minutes to reset itself and check if the symptoms still persists. If yes, may I know if it encountered before then there's some instances that the unit will power up after a few minutes of pressing the power button key?
Also, please double check the model number of your unit, if I'm not mistaken, it is 50H81 not 50H87.
Jdvillanueva
Jan 21, 2012 | Toshiba Televison & Video
Red and Blue seperate and picture curved toward the middle
You have a hardware problem, you cannot fix it using the menu. in fact you could make it worse.
Try googling DIY convergence repair if you can solder.
If not then call in a pro, about $300
Jul 12, 2009 | Toshiba 50H81 50" Rear Projection...
Toshiba 50H81 Projection TV
youre convergence ICs need to be replaced there are two of them they are both STK392-110 you can get replacement Ics and free instalation instructions at the following link.
http://servicemanuals.vstore.ca/
May 24, 2008 | Toshiba 50H81 50" Rear Projection...
Projection tv toshiba
my tv did the same thing except it is a 57in hdtv
May 21, 2008 | Toshiba 50H81 50" Rear Projection...
Red light flashes no picture or sound. Likely causes?
did your TV just cut off in the middle of watching it and it want come back on. My red light beside the power button flashes also.
May 06, 2008 | Toshiba 50H81 50" Rear Projection...
Tv won't come on
Mine is Toshiba 55 TZ, have it since 98', shutdown and red light blinking problem, search the ned and found out, generally a Convergence IC (stk392-110) problem. bought 2 for $15 at suburban-elect.com (ebay). replaced following direction from http://www.casiasfamily.com/repairlog/tp50h15.html
Feb 29, 2008 | Toshiba 50H81 50" Rear Projection...
Toshiba 50H81 manual convergence
are you sure it's yoke? these are know for bad convergence amp ic's
other wise it's a screw and glue holding the yoke in place loose the screw and try to break the glue with out breaking the plastic on the yoke, the other thing you can do is adjust the magnets which have tabs on the yoke. i would mark the position's of everything on the tube with a sharpie so you can get it back to start.
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 28, 2008 | Toshiba 50H81 50" Rear Projection...
Toshiba 50h81 turned off and now nothing
Did you check the supply fuses to the convergence ICs? Did you check the output resistors?
if all ok i would replace the convergence ic's
Nov 10, 2007 | Toshiba 50H81 50" Rear Projection...
Tv shutting off
Sep 11, 2007 | Toshiba 50H81 50" Rear Projection...
Toshiba 50H81 50" Rear Projection Television Logo
83 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
