Question about Belkin (F5D7230-4) Router (587009)
Belkin 5D3230-4 not working at all
Hi. I've had a Belkin F57230-4 wireless router for some time. Since yesterday the power led, the #1 port and the WAN leds are blinking and the "Connected" led is off. All other leds are off. I can connect to the internet from my desktop computer which is connected to the #1 port but my wireless access is out. I can't enter the web based configuration utility. I have checked and replaced the ethernet cables, disconnected the router and cable modem for hours and nothing has happened. I've also tried to reset the router with the "reset" (press and release and also 15 sec. for hard reset) button but nothing happens. I'm guessing the router is fried. What can be happening?
  • alegato Feb 06, 2008
    Xsugarbox, the problem is that I can't access the web based configuration utility, therefore I can't update the firmware.
    Problem Solver:
  • 7 Answers
Try and update your firmware on router,and see if that helps, you can go to belkin website to do that, look up your router and download firmware, call belkin they will help u install it
Posted on Feb 06, 2008
Haw can i install Belkin wireless router N300 without the CD
You can easily follow the following steps to install it without a setup CD
Step 1: Please find a compatible power source and plug your modem into it.
Step 2: Now, you can connect your computer to the modem using an Ethernet cable without the router being installed.
Step 3: please verify whether your computer is receiving an internet connection or not. Just click and access any website of your choice.
For more details kindly visit How to Login Netgear Wireless Router Routerlogin net
Apr 10, 2012 | Belkin F5D7234-4 Router
Cant get connected with my belkin router...all i can get is "connected with limited access
HI
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} How to quickly install and use your Belkin wireless G router
1. Step 1 Position your Belkin wireless G router.
Place your wireless G router in a wide open and central location. Don't connect the power plug into the router, yet. Make sure your computer is turned off.
2. Step 2 Connect all the devices.
Find the Ethernet cable that connects your PC to the modem. Unplug the Ethernet cable from your PC and insert it into the wireless G router's WAN port. You should have an additional Ethernet cable that came with your router. Take this cable and plug one end into one of the LAN ports on the router. Then connect the other end to your PC's Ethernet port.
3. Step 3 Turn on your modem, router, and PC.
Plug the power plug adapter into the modem. Turn on the modem. It'll take approximately 30 seconds for the modem to boot up. Connect the power plug adapter to the router and the other end into a power strip or outlet. Like the modem, it'll take about 30 seconds for the router to boot. Turn on your PC.
4. Step 4 Verify lights are on for your devices.
Make sure the following lights are on for your router: power, WAN, and LAN light. If you don't see any of them lit, confirm these devices are turned on. Make sure the Ethernet cable connections are installed correctly.
Step 5 Install and configure software.
Use the setup wizard application to configure your Belkin wireless G router. Set up features, such as creating your password and setting up your time zone. Continue to follow the setup wizard so you can configure ?other settings
Oct 18, 2010 | Belkin N1 Wireless-N Wireless Router
The only light on my router is the router light. No other lights are coming on. I have tried rebooting.
When facing the router, Globe/Internet LED is on the right. Below are the LED indicators; Check the steps below:
Wireless Security - This light will only turn on if the wireless security is enabled.
Wireless-Computer Status - This light will turn on if a wireless computer is connected to the router.
Wired-computer Status - This light will turn on if a wired computer is connected to the router. Connect the wired computer to any gray port on the router. (There are 4 gray ports).
Router Status - Power light. Solid blue means the router is on and ready.
Modem Status - If this is off, it means the router is not connected to the modem. Make sure the cable is connected from the modem to the yellow port on the router.
Internet Status - This light will indicate if the router is connected to the internet.
If this is the first time you are installing the router, then what is important is to get the router, wired-computer and modem lights ON. Once they are on, you may insert the CD that came with the Belkin router to setup the internet connection and wireless settings.
Dec 07, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Installing belkin wireless router
1. First, Begin by resetting your modem, the reset button can be found on the back of the modem, underneath the power button.
2. Once the modem is reset, do this for your router, and when you are finished connect the cable from your Modem into the "internet" or "modem" port on the back of your router.
3. Now run a cable from port number 1 on your router, to the back of your originial computer. Give this a moment to sync.
4. Now open your web browser and type in 192.168.2.1 and hit enter, it should prompt you for a username and password, enter "admin" in the username, and leave the password blank. You will now see the router's status page.
5. Now configure the Router according to your ISP setting.
Jul 29, 2009 | Belkin (F5D7231-4) Wireless Router
Tew-630apb
hello!
-- what is the exact model number of your access point and router?
-- what is the ip address of your access point and router?
-- what is the operating system of your computer?
-- Is your computer directly connected to the router?
-- Do you have a wireless computer? what is the model number of the wireless adapter
if you want to configure your access point with your router you may try the ff:
Step 1: Connect the Ethernet port of the access point to one of the Ethernet ports of the router
Step 2: Make sure the power adapter is plugged to an available power outlet
Step 3: Check if the corresponding LEDs on the access point are lit
Step 4: After connecting the devices together, configure the access point’s wireless settings
Step 5: Open the access point’s web-based setup page
Step 6: When the access point’s web-based setup page opens, change the SSID, Channel, and Wireless Security.
Apr 07, 2008 | Trendware TEW-630APB (TEW630APB)
No wifi connection
Verify which MAC Address U have Cloned. MAC Address of Your PC WiFi and Cloned One must not be same otherwise it will not work...
Feb 02, 2008 | Belkin (F5D7231-4) Wireless Router
Belkin router not working
Are there no leds when you power up the router? If there are no leds make sure the 110 volt circuit the router is plugged into is not tripped. If you have leds try holding in the reset button on the back of the router with a paperclip the botton is a small hole located by the internet/wlan port, hold for 10-15 seconds this resets the router to factory defaults. BPCS
Dec 28, 2007 | Computers & Internet
Belkin (F5D7230-4) Router (587009) Logo
160 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
