Question about Philips DVDR3380/05 DVD Recorder
DVD recording. I recently connected my DVD recorder to my new TV, the terrestrial recordings work fine but when I record from my Digi box and turn off the TV or go into standby the recording pauses and the red light flashes, the recording recommences when I turn the TV on again. Any help would be sppreciated. Peter.
  • Anonymous Mar 05, 2008
    we have a DVDR3380 recorder and have a new sony bravia freeview television are we able to record freeview chanels
I have to try and record from my cannon dc95 a disc that can not be finalized, so i am trying to copy straight onto a disc??i can record the normal tv onto disc and i can record sky . I can play the cam corder on to the tv!! but i am having trouble recoding the contents of the cam corder onto a new disc??? my tv is a goodmans and the dc95 plays on the av3channel fine!! but i just am unable to record this onto a blank disc!!!! help
Posted on Apr 07, 2009
  • 3 Answers
I had the same problem but had a friend who came and looked at it now because i have freeview box its set to ext2 it records beuatifully now i found a v ext1 etc no use but ext2 works fine hope it helps.
Posted on Mar 15, 2009
  • 476 Answers
Sounds like the DVDR is recording from the digi-box through the TV, so when the TV is switched of or into standby the signal is lost, causing the recorder to pause.
Assuming the digi-box has two scart sockets, connect as follows:
  • Scart 1 or TV scart of the digi-box to the TV.
  • Scart 2 or VCR/DVD scart of the digi-box to scart 1 of the DVDR3380.
The TV aerial should already be connected through the digi-box and DVDR3380 to the TV
To record from the digi-box, select AV1 / E1 / EXT1 on the DVDR3380
Posted on Feb 16, 2008
How can I set up a Bush Digi Box with 2 scart sockets to a Sony combined DVD & Videao Recorder with 2 scarts to a Sony TV with 3 scarts
Bush Digi box - 'TV' SCART to TV
Bush Digi box - 'VCR' SCART to DVD/Video recorder 'TV' SCART
The digibox will pass through when the DVD/VCR is playing.
Aug 30, 2014 | Televison & Video
Connecting JVC television set model AV29LX2 / JVC home theatre system/satellite decoder / Sony DVD recorder
You need to buy a splitter in order to put one to the DVD recorder and one to the tv from the decoder. You should be able to get one at the Local Radio Shack or other electronics store.
If you need help locating a store, please let me know
Otherwise Thank you for using Fixya and Have a Good Day!
and Good Luck...
Apr 19, 2008 | Televison & Video
My old samsung dvd recorder dvd/r120 doesnt work with my new digital tv. can only record 4 analogue channels worked fine before with digi box.have a digital aerial
> digi box (?)
Is this digital converter?
Your new TV doesn't need it but it could well work with your DVR. It wouldn't give you the benefit of HD recording but with it, you could convert the digital signal into analog and record the results.
Jan 02, 2010 | Panasonic DMR-ES10 DVD Recorder
Is it possible to record and play dvd through a set top box....on a tv with only 1 av channel
If you take a scart lead from av1 on the dvd into the tv,then a scart lead from the digi box into av2 on the dvd,you will then be able to watch dvd and digi box,also you can record from digi box on channel av2 on the dvd.You may have to turn off a unit to watch one.
Nov 01, 2009 | Televison & Video
I have a hd set top box set up to my plasma tv. I have a dvd recorder as well. How do I set up the recorder so my signal still goes through the digital box
If you connect the main aerial into the digi box,then a fly lead out of the digi box into your dvd,then from the dvd take a fly lead into your tv,hope this helps
Aug 07, 2009 | Televison & Video
Recording from sky+ box
try hooking up a splitter to the coaxcil cable ;run one line of each output; one line goes to your main box the other to your dvd recorder ;hook up to your tv how you want.switch box helps.
Mar 01, 2009 | Cyberhome DVD Recorder - DVR1600
Dmr es10 dvd recorder
Check connections, cables, settings and read both the instruction manual's troubleshooting section.
Sep 16, 2008 | Panasonic DMR-ES10 DVD Recorder
New hdtv
First off, scart has an auto detect feature across pin 8, HDMI does not. If you have turn your TV to the HDMI channel, and at some point turn off the HD source device you are going to get a blank screen, you have to manually turn your TV back.
In regard to whilst you are recording it sounds like you may have tuned in channels on your DVD but not your TV.
Do you have an RF aerial lead connected from the DVD output to the RF on you telly?
Do you have a sky/cable box connected to your TV via scart?
Does the DVD have DVB (digital video broadcast) if so and you have none of the above that is the problem, any tuner running off a single RF lead can only record/play 1 channel at a time. If you have no RF lead going to the TV, then the TV cannot show any terrestrial channels.
Jun 15, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic DVD Recorder - Digital tuner stopped working
Is your recorder hooked up to the new convert box for digital antenna reception?
I am currently researching the convert boxes for my dvd recorder. I found that some dvd recorders already have digital converter boxes already installed. This might be the case for you.
Mar 08, 2008 | Panasonic DMR-EX85EB-S DVD Recorder/HDD...
Can't tune stations from freeview box to DVDR3380/5
You can only record freeview channels through your box.
If you are doing timer recordings, you will also need to leave the freeview box on the channel you wish to record, or set the freeview box timer.
Dec 15, 2007 | Philips DVDR3380/05 DVD Recorder
Philips DVDR3380/05 DVD Recorder Logo
280 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
