Question about Inter-Tel Axxess Phone 5504400
Can not receive calls from the outside
I have created a new extention. I've matched the flags and fwrd path (voicemail) with a previous working extention. Call work fine when calling from within the switch.
I have added the extention into the call route table with its own extention as the ring in destination, but when I test the call from the outside I get a recorded message stating that " this number is no longer in service"
What am I missing?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 112 Answers
Do you own that number from the telco? Is it in your DID range? Did you put it in the right call routing table?
Posted on May 19, 2009
Displaying "message" but not message in voicemail
THis is usually because it thinks that there is something there, but the code path to 'clear it" doesn't follow the same logic path. Sometimes, adding a new message - i.e. dial your number from elsewhere, to create a real message waiting, and then clearing that, resets this.
Nov 11, 2013 | Nortel Norstar M7208 Telephone
We use the Mitel 5212 IP phones for our hotel. We are trying to find a way to retrieve a previous voice message from a previous guest that stayed with us. How should I go about finding this information?...
If you're using the embedded voicemail, you won't be able to retrieve such messages. If you're using another, external, voicemail system, then it might be possible.
Every hotel I've ever installed, I've left hotel admin guides for the voicemail. This information should be in such a guide if your vendor is any decent.
To find out what sort of voicemail you've got, you should contact your vendor.
Sincerely,
Mark
May 12, 2011 | Mitel 5212 IP Phone
The remote won;t work
If it's a "Universal" remote and you've changed the batteries, you'll need to reprogram it according to the make/model of the remote. A remote that came with your receiver....
1. Check batteries, they may be dead or dying.
2. Is something blocking the remote receiving window on the receiver?
Remotes use infrared light to transmit to their matching devices and MUST have a line-of-sight path to work properly.
Apr 13, 2011 | Audio Players & Recorders
Voicemail is not picking up for incoming calls...
Sounds like you need to set the call forward no answer to the VM pilot DN for the set with the new mailbox.
May 26, 2010 | NorStar Startalk Flash 2 Phone
Ringer/ Voicemail Bounceback
Well, this one is kinda tricky. If the receptionist knows there's no one there, they can use VoiceMail Transfer.
From the phone, the user can set CF Busy or CF Busy/No Answer with the following codes on the intercom:
Do Not Disturb *7101 / Cancel *7100
Call Forwarding2.gif (FWD)
– Both Calls *710
– Outside Calls *711
– Intercom Calls *712
2 (All calls) + phone no. + #/
3 (Busy) + phone no. + #/
4 (No Answer) + phone no. + #/
5 (Busy/No Answer) + phone no. + #/
7 (Follow Me) + your extension no./
8 (Follow Me Cancel) + your extension no.
So, if your voice mail is 500, you would dial *7105500# to set CF B/NA for intercom and outside calls.
The last piece of the puzzle is the timing. That's *713 (00-99). Start with 24 (4 rings) and go from there. If it hits the receptionist before the forward takes place, you probably have to adjust the recall timer for call transfer, a system program.
Carl
Aug 11, 2009 | Panasonic KX-T7630 Corded Phone
Voicemail doesn't work
I would check with your cellular provider to make sure that they kept your voicemail when you purchased the new phone.
Jun 02, 2009 | Motorola Mobility RAZR V3
Not receiving faxes
make sure your answering machine is plugged in to the "EXT" jack on fax machine, and your main line plugged into "line". try setting fax rings to 1 or 2. set your answering machine to 4. your fax should intercept the call and if it hears the fax tone, will receive the fax. if it doesn't hear the fax tone, it should forward the call to your answering m/c.
hth,
razors
Jan 03, 2009 | Brother IntelliFax-2820 Laser Fax
Access voicemail from Nortel T7208
Have you set up the voicemail before?
OK, from your set;
-> dial FEATURE 9 8 1 (this is the code to get you to the voicemail)
-> then your passcode, if you never set up the voicemail, the temporary password is 0 0 0 0 (four - zero's).
-> if this is a new installed voicemail, the telephone system will tell you al that you need to initiate the voicemail box.
Jul 29, 2008 | Nortel Business Series Terminal T7208 -...
Call details
Clear All under the Dialed calls and Received calls and Missed calls menu to create new space.The phone should clear itself one number at a time when the memory is full but some don't.If you don't need all those numbers in there--get rid of them--delete all. Good Luck.
Apr 07, 2008 | Motorola Mobility C261 Cellular Phone
Changing the MAIN voicemail
you have to go into the administrators vm box.
press your vm btn or press intercom and dial 777.
at enter mbx prompt.
press 99#
password= 1234
press 9
follow the prompts.
hope this helps..
Feb 22, 2008 | Lucent PARTNER18 Corded Phone
Inter-Tel Axxess Phone 5504400 Logo
98 people viewed this question
Top Inter-Tel Lands Phones Experts
Marvin
Marvin
David Burbee
David Burbee
ray gallant
Are you an Inter-Tel Lands Phone Expert? Answer questions, earn points and help others
