Question about GE GSH22KGPBB / GSH22KGPCC / GSH22KGPWW Side by Side Refrigerator
Evaporator coils frosting up
I have a GSH22KGPBB model GE side by side. Twice both the fridge and freezer compartments started warming up. I could hear the fan running, but the air blowing out was not very cold. The ice in the ice maker was melting. There was a buildup of frost on the back of the freezer compartment
I emptied the fridge (fortunately it's winter so I moved the food to the garage), unplugged it and let it sit for several hours. Water drained from behind the back panel of the ice compartment as the frost melted. I know now that I could of used a hair dryer to speed up the defrosting process.
After the first instance the fridge worked fine, for about two weeks, before the problem recurred.
I understand that there are several possible causes. I'm just wondering if this is a common problem with this model of fridge and whether any one cause is more likely to be the culprit.
Thanks in advance for any help/advice you can provide.
  • 3 more comments
  • brailk Feb 08, 2008
    Thanks for your response drcool. I will check the suggestions that you listed. I removed the panel at the back of the freezer yesterday, and found the coils encased in frost and ice. (Previously I defrosted by opening and emptying the freezer and fridge and letting it sit. But I probably didn't allow it to sit long enough to properly defrost everything). I thoroughly removed the ice and frost with a hairdryer and of course the fridge/freezer are cooling perfectly.
    I am going to see how long it takes for frost to build up and see if there is any water draining. And then I will troubleshoot the possible causes based on what you listed above.
  • Anonymous Feb 21, 2008
    frige is not defrosting ,it freezes up every 2 weeks
  • pondfish Aug 22, 2008
    Coils freeze every couple of weeks. Does this have anything to do with The temp settings in both the refrig and freezer sections? Have deforsted with hairdryer.
  • Anonymous Mar 29, 2009
    I have the same problem. I have checked my heater coil and it has resistance. My defrost thermodisc has continuity. I have a control module rather than a electro/mechanical timer for defrost. Is it my control module?
  • Anonymous Apr 13, 2009
    Evaporator coild freezes up freezer still cold refrigerator doesnt cool as well have to defrost about every two week
  • 958 Answers
The frosting of the back compartment of the freezer indicates that the ice builds up at the evaporator ( the coil that cools). the system is supposed to melt the ice after a particular time interval for a period of time in order to start another cycle. im not sure if that model uses the electronic timer which you can not manually adjust to see if it is heating up on the heating mode. you would have to check three things. one is the defrost heater itself if it has continuity. another is the thing that we called thermodisc . its a part of the heating circuit where it cuts the heating current after it senses that the temperature of the evaporator is way up the thaw temperature. it is normally connected in series with the defrost heater and it is attached to the latter part of the evaporator tube. lastly which as i have told you is the timer. if its a mechanical timer, then probably it is not going to the heating mode. another is the electronic timer which is very hard to trouble shoot. you have to really observe the refrigerator how long it is running and if the compressor is stopping and the heater working by looking at the back if water is draining after a few minutes the compressor stop. as i may add, as you have said it is winter there, a thermostat setting could be an issue. the heater could probably not cope up with the coldness of the ambient temperature in which i may suggest to put the thermostat setting to the lowest setting on the knob. i hoped i was able to help....drcool
Posted on Feb 05, 2008
Have a GE Model #GSL22JFPHBS side-by-side refrigerator that the freezer is staying cold but the refrigerator part is not get cold.
its either the defrost heater or defrost thermostat or the defrost timer has gone bad and the evaporator is iced over,HINT: (you will see the inside rear panel in the freezer has frost on it) and the evaporator fan cannot blow cold air over the iced up coils in which case soon the freezer will start to seem warm too,if this isnt the case then its the damper vent door located between the freezer and fridge compartment that opens and closes to throttle cold air into the fridge from the freezer,sometimes they freeze shut from condensation or the door hinge breaks and it can jam shut,also if theres excessive water dripping into the fridge from the top it can be a plugged drain hole and water blocks cold air flow,also make sure the evaporator fan beneath the evaporator coil in the freezer is operating when the units running or cold air wont be pushed into the fridge either
Jun 27, 2011 | Refrigerators
My side by side fridge has stopped chilling down, the power is Ok, and moter seems to be working, but no cold inside. A few months ago the freezer side stopped, but as i did not use it , i just left well...
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Jun 14, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge and Freezer Not getting Cold
Your defrost system is at fault.
With this brand it is most likely the defrost thermostat and defrost heater located behind the back freezer panel.
Remove the shelves and bin,then remove the freezer panel. Defrost the ice manually.
Replace the thermostat and heater assembly.
Apr 27, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Started leaking water out the freezer door and ice was melting last nite... bad timing we just got a snow storm here in NC last nite. Seems to be running but food is defrosting. Its a GE Side by Side about...
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} . Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Jan 30, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
It stopped freezing and the temperature keeps rising
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
How to check stuff>
Dec 13, 2009 | GE Profile Arctica Stainless Steel Top...
GE Eterna ESS25LGNA freezer side not working
How to check stuff>
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Aug 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer not freezing
Jul 11, 2009 | GE Refrigerators
Side by side, freezer is cold, fridge is warm, freezer is iced-up
Hi: Your defrost heater ot timer is out. Hence the frost. That also clogs the airways to the fresh food compartment. If you are handy, unload the fridge (you will need a cooler or have a bbq for everybody,) I can't give you the specifics but you will need to remove the panel where the frost is, first let the frost melt off. at the bottom of the coils will be a heater tube. Usually glass with a metal coil in it. See if there is a break in the coil. If so replace it. If that is ok it is your timer. Most likely electronic and expensive. This can be anywhere. Look at a diagram of the fridge to see. Sears parts is a good site for it. Hope I helped, Jeff
Jun 01, 2009 | GE Refrigerators
Freezer coils freezing, fridge warm
You might want to check and make sure the interior fan is working above the evaporator coils. If the fan isn't working the air won't circulate over the evaporator and it will frost over very quickly, and also cold air won't be pushed into the fridge side.
The fan might turn off when the door is open, hold the door switch shut while you check it.
Apr 27, 2009 | GE GSS25SGMBS Side by Side Refrigerator
Refer side is not cooling at all and the freeze4r side is frostin
The small cooling fan in the freezer compartment that sends chilled air to the food side is defective and needs replacement.  Sometimes that are only frozen stuck.
Apr 11, 2009 | GE GSH22KGPBB / GSH22KGPCC / GSH22KGPWW...
GE GSH22KGPBB / GSH22KGPCC / GSH22KGPWW Side by Side Refrigerator Logo
926 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
