Back to:
Tags:
Bosch HMT8625GB 900 Watts Microwave Oven
Sick Microware
posted by paul49 on Feb 05, 2008
Hello my microwave only stays on for about 22sec then cuts out,this happens on any setting, also not heating. Is this something i could fix? please help Thanks Problem - Bosch HMT8625GB 900 Watts Microwave Oven
Comment by paul49, posted on Feb 07, 2008
Thanks for reply, I will do as you said & let you know
Comment by paul49, posted on Feb 08, 2008
I afraid it didnt work, fuse wasnt gone
Thank you, in your opinion is it worth fixing it. It would cost about 250.00 to get bosch to repair & 500.00 to replace the machine, Do you think other parts might go soon. Thanks again for your help
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
FixYa! (100)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Ok easy one this, in actual fact your microwave cuts out after 23 seconds and not 22.
The problem is the magnetron.
HOWEVER I DON'T RECOMMEND YOU REMOVE THE OUTER CASING OR EVEN ATTEMPT TO WORK ON A MICROWAVE UNLESS YOU DISCHARGE THE INVERTER FIRST AS THIS HOLDS A HIGH VOLTAGE, EVEN WHEN TURNED OFF!!
Diver 1
Rating Locked! (?) paul49 has rated this solution as FixYa!
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Sick Microware:
I don't want to Accept this solution
Solution #2
posted on Feb 06, 2008
FixYa! (100)
chie-chie
Rank:Wiz Wiz
Rating: 84%, 99 votes
first unscrew the unit replace fuse "near transformer this fuse is for the heating" --i think ur microwave needs a proper ventilation..
Thank You!
Can you Help with these Microwave Ovens problems?
Microwave Ovens
Hi, we have the above mentioned model microwave which we...
Microwave Ovens
need to replace d3v-16g-3c25 for my sharp micro...where...
Microwave Ovens
sharp carousel microwave R-1514 F one touch door release...
Microwave Ovens
Our microwave died suddenly. No Lamps or power indication...
The microwave controls and mechanisms - door, timer,...
Loading problems.
Repair Service
Find Microwave Oven Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
