Question about Samsung HCN436W 43" Rear Projection Television
The value of RZ127 and RZ128 in SP43W6HPX
Hi all i have replaced EYZ01 and EYZ02 in the above model. Both of these resistors are burnt up and i need to know the value. PLease help............. Thanks
  • PTOAL Mar 11, 2008
    Thanks for the help but i got a manual a few days ago and it is now sorted, Thankyou
  • broke-it Apr 02, 2008
    hi can anyone please send me a copy of the sp43w6hpx manual. i am at my wits end with convergence fault
  • 137 Answers
Yust email me and i wil open the one at my shop and check for you. nicaelect@excite.com. Ps do it tommorrow and i will check for you.
Posted on Mar 08, 2008
LG crt tv 21fs4rge-TS resistor R407 burnt i don't know the value
A burned out resistor means too much power has flowed and burned it out.
you need a schematic to find the resistor value but also what other parts have blown as I can guarantee just replacing the resistor would just mean another burned out resistor.
Jun 16, 2018 | LG Televison & Video
Can i have TCL 2127 model power unit IC's pin 8 resistor value
If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. Schematic diagrams to some popular model TVs are given.
Jan 05, 2014 | Televison & Video
Burn Resistor 842 conot find the value
You can get the value of this resistor from the circuit diagram of your model TV.
Usually a burnt resistor is caused by some other component failing that is connected to the resistor.
Apr 19, 2013 | LG Televison & Video
Hilti TE-5 burnt resistor value
Hilti should be able to supply that information.
Jul 24, 2012 | Drills
Burnt Resistor
There are LIKELY other bad components that caused this. Resistors USUALLY don't fail on their own.
Jan 30, 2010 | Toshiba 32A33 32" TV
I need the value of resistor R1 on my model
Hi. I have access to the Service Manual for this model, the only technical information it provides is this:
- Voltage : 100-240 V AC 50-60 Hz
- Power consumption : Motor depending
- Motor Voltage : 1,2 V
- Power system : Rechargeable
If you have no luck, Part No 4222 036 09060 is for the PCB.
A copy of the Service manual was found also at http://www.shop-stecken.de/ecarusShop/v30/pdf/HQ6613.pdf
Nov 30, 2009 | Philips Health & Beauty
Resisters questions
Its best to replace both IC's. As far as the resistors, there are location #'s marked on the board where the resistors are mounted. If any look burnt, get the location numbers off the board, and your model # and email me @ halselectronics@comcast.net. I will get you the resistor values.
Aug 10, 2008 | Hitachi 43FDX20B 43" Rear Projection...
Magnavox resistor problem
The CRT board is the one that connects to the back of the CRT.
Follow the 200VDC line to locate the burnt resistor, is normally a low value fuse resistor.
Apr 15, 2008 | Philips Magnavox 27MS343S 27" TV
65xwx20b
Is this a Hitachi set? If so then check the model number and be sure it's right.
Dec 05, 2007 | Televison & Video
Need value for part R14109
R14109=750ohms 5% 1/4w (Resistor(750r5%.25W/R14109/179317) There is much more likely wrong with the TV. Resistor don't normally burn out with help, say, without a failing flyback transformer and possibly taking a transistor or two with it. If you need the manual, go to http://www.samswebsite.com/photofact/pf_search.asp and type in "F31317" into the search field, you will several listings. If you decide to replace it yourself, here's some more part numbers in case you need them. Model: RCA\F25422TX41 Symptom: Dead Necessary parts: Transistor(Q14401) Main Voltage regulator Q14101 Resistor R14109 open. Research indicated the flyback transformer most probably bad \\CTC203AC4\HOT/D2578(Q14101/242224)* Flyback(14536119A/T14401/244229)* Main reg(P9NBSO/Q14101/244223) \Reg(MPS8599/Q14102/147665) Resistor(750r5%.25W/R14109/179317) Reg(MPSA06/Q14103/232218) Hope this helps you. ZT3000 "Beta tester of "0"s and "1's"
Aug 19, 2007 | RCA F31317 31" TV
Samsung HCN436W 43" Rear Projection Television Logo
59 people viewed this question
Jerry Greenberg
Jerry Greenberg
