Question about Toshiba Satellite A105 Notebook
Loose keys on keyboard
Several keys have fallen off my keyboard and they will not stay on . I try to push them firmly in place hoping they will snap in but that does not work. Looking underneath, nothing seams broken or missing. How can I fix this annoying problem?
  • 1 more comment
  • rugerman Feb 05, 2008
    Thanks for your help swampduck.
    Tried this but did not work. Pushed them in pretty hard till I was afraid that I'd break something, but nothing "clicked" or "snapped" into place. They just lay on top like they are partly in place, but if I hit near the top edge of the key, then it comes right out again.
    Appreciate your help!
  • Anonymous Oct 04, 2008
    Same problem here. Brand new Toshiba Sattelite A300 and two keys have come off within ten days.
    I am returning it and may change it for an HP.
  • r_nsn Oct 13, 2008
    The 'T' and the 'A' keys are my problems, particularly the 'A' key. Pushing them intil they snap into place worked initially but not for long. I'm toying with the idea of superglue! Anyone else tried that glue?
    Robert
    Problem Solver:
  • 5 Answers
I had the same problem when i bought my new laptop, I turned it off and forced them back in they are quite hard to get back in. If its an old qwerty keyboard, then it needs replacing, the letters will never type what they should ever again.
swampduck
Posted on Feb 05, 2008
O want to install a new key . What are the steps ,please
A key falling off of a keyboard might be an annoyance, but it is not a reason to buy a new keyboard. Regardless of which key falls off, it can be replaced fairly easily. Although the method of replacing typical letter keys is a little different than replacing the space bar, replacing either of these types of keys can be done in a few minutes.
Carefully pry the key from the keyboard next to the key that has fallen off. This key can easily be pried by sliding a flat-head screwdriver underneath it and popping the key out. Be careful to make sure the key retainer underneath the key stays in place, especially if the key retainer has also fallen off the key you are attempting to fix. Look closely at the key retainer underneath the key that was just removed. Notice there is a notch in each corner of the key designed to hold the key in place. Place the key retainer back into place if it has fallen off the key you are trying to fix. Make sure it is positioned exactly as the key retainer next to it is. Put the key on top of the key retainer. Use your index finger to firmly push straight down on the key to lock the key back into place. Do the same to the key that was taken off to view the other key retainer. b> Replacing the Space Bar b> Turn the space bar upside down and use a flat-head screwdriver to separate the retainer from the back of the space bar key. Place the retainer into its place on the keyboard. The retainer will hook into small hooks on the left and right sides. The small metal bar from the retainer should line the bottom of the area where the space bar will be placed. Put the space bar back into the place where it belongs. Spread the ring finger, middle finger and index finger across the space bar, and push firmly until the key snaps into place. Put the space bar key back in place and gently press on it with fingers until it snaps back in place.
b>
Jan 16, 2013 | Computers & Internet
Key fell off completely
Set aside the key and retainer that have fallen off. If you lost the key, retainer, or both, you will have to order a replacement from the computer's manufacturer. As an alternate, you may be able to get a replacement from someone who has a non-working laptop of the same model as your own.Carefully pop off another key from your laptop. Choose one that you don't use frequently, and remove it with care so its retainer stays in the proper place. You will be using it as a model for your repair.
Note how the exposed retainer is connected to the keyboard. It will probably be connected at four separate points. This may vary, based on the make and model of your specific laptop. Study it until you feel confident replacing the retainer in the correct manner. Replace the retainer that popped off your laptop. Once you have it secured in place, pop the missing key onto it. The key should snap firmly into place onto the retainer. Replace the key cap on the retainer that you used as your model. Like the other key, it should snap firmly into place, and both keys should now be ready for use.
Mar 22, 2011 | Computers & Internet
Had a #2 key fall out complely including the cap,now I want to know how to replace it ( I have the new key complete,hinge and all that stuff) but i don't know how to replace and install it please show me...
I vacuumed my keyboard and a couple of keys came loose.seems to be a secret to getting them to stay down.Can you help, please
There are two tiny protuberances on the smaller of the clips under the key. These must be UNDER the larger clip as you push the key onto the board.
Feb 14, 2010 | HP Compaq Presario F500 F700 and G6000...
Key popped out on Gateway 450SX Laptop. Nothing Broken. How do I pu it back on. Thanks.
First make sure to remove any dust or debris from the keyboard. Align the key in the proper place on the keyboard and gently push down to see it it will snap back in place. You may have to gently wiggle the key as you press down. If the key will not stay in place you may have to replace the whole keyboard. Another alternative would be to purchase an external USB keyboard or a wireless keyboard. Good Luck!
Nov 08, 2009 | Gateway 450SX4 Notebook
One of the keys on my acer 5315 have fallen of does any one know how to resemble it again
The key should just clip back onto the board.
If not, there usually is some sort of rubber where the key was. Use a bit of double-sided sticky tape, or better: Blu-Tack (just a little) removable adhesive, and place in/on the rubber on the keyboard. Place the key in place and push down firmly.
If that doesn't resolve it, consider buying a new keyboard (about $20 and must be from same EXACT model) and put in place.
Hope this helps.
Jul 30, 2009 | Acer Aspire 5315 Notebook
The G tab came off of my Dell Studio 17.
on the bottom of the key there is little holders and what happens is when you push the key button onto the tactile that goes underneath it, it will snap into place, problem is if any of the little holders underneath the key button or any part of the tactile that it snaps onto is broken then it won't go on properly.
I think that is whats going on here, if your hearing it snap into place but it won't stay on then there is something broken between the tactile or the keyboard button. Your best bet is to get another keyboard probably if you can't get that button to stay on.
Jul 06, 2009 | Dell 0Y3740 Keyboard
Loose key
Is only the cap loose, but you can still operate that key?
On most laptop keyboards, the letters are caps on the keyboard button. They are held in place by small plastic tabs on the keyboard structure. The cap snaps in place and is held by the tabs. If the tabs are broken, the cap stays loose.
Some keyboards use a small slider that moves as you depress the key, which means you can't glue it.
Laptop keyboards are replaceable and can be purchased cheaply on ebay or some repair sites.
May 13, 2008 | Compaq Presario 700 470024-192 Notebook
My ibm thinkpad key ""Q" came loose
Situation 1. The key cap and key retainer fell off the keyboard and you cannot figure out how to assemble them back. keyboard-key-repair-1.jpg Carefully remove the cap from any other working key so the key retainer stays connected to the keyboard.
keyboard-key-repair-2.jpg Take a closer look at the key retainer, it’s connected to the keyboard at four different points.keyboard-key-repair-3.jpg Assemble the disconnected retainer the same way as one on the keyboard and put it back in place.keyboard-key-repair-4.jpg Put the key cap on the retainer and snap the cap back in place.keyboard-key-repair-5.jpg
Jan 13, 2008 | HP Pavilion dv1000 Notebook
ACER 3680 KEYBOARD
there are many many different keyboard designs, it is hard to make a suggestion...usually if it looks like nothing is broken on the key or keyboard you push down firmly and it snaps back into place.
Oct 03, 2007 | Acer Aspire 3680 Laptop
Toshiba Satellite A105 Notebook Logo
122 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
