Question about JVC HD-52Z585 52" Rear Projection HDTV-Ready Television
Not playing dvds
Cannot get dvd to work. What channel is tv supposed to be on?
    Problem Solver:
  • 11 Answers
There wil b a button that switches between tv and video...try pressing tat nd then play
Posted on Feb 05, 2008
I can't get the DVD player to view dvd on tv
hi konni.
this is all i could find .
DVD player not working with TV By Charlotte Parker 25 Aug 2017
You've got your Sky Box, your TV, your DVD Player and your surround sound; you've also got your digi-box, your DVD recorder, Blu-Ray Player. With all that equipment, if something goes wrong it can be tricky to track down the issue. This article explains why your TV isn't playing DVDs and how to get it sorted out.
Figuring out the problem
Figuring out why your DVD Player isn't working with your TV is a process of elimination, so work through the steps below to figure out the cause of the problem.
The problem could be:
  • The connector cables/connections.
  • The DVD disc itself.
  • The DVD Player's optical reader (the lens which 'reads' the DVDs).
  • The TV.
Before doing anything, check all your connector cables. Make sure that all connections are in properly, and that the cables are in the right place.
One of the most important connections is the cable that runs between your TV and the DVD Player. If it isn't in place, then your TV can't read the information from the DVD Player and the film won't appear on your TV.
The DVD disc itself
Check for scratches, chips, smudges and any other marks. Test the disc isn't the problem by trying a different one in the player. If the new disc works, then the first one might need replacing.
The TVTry changing channels. Lots of TV's have a default channel specifically for DVD players. Have a look between the channels to see if the DVD menu appears.
On modern televisions, especially those connected to Digi-boxes or Sky Boxes, there's usually a 'Source' button on the remote control. Find it and go through until you reach the right setting for playing DVDs. To go back to watching normal TV channels after the DVD has finished, go back to the source button and change back to the original source.
That should be all you need to know to get your DVD player working with your TV
if none of above works then try putting a lens cleaner through it to try and clean the lens that reads the disc.
Nov 05, 2017 | Televison & Video
Play DVDs player
It is not going to be a channel but it will be an input selection on your remote. If you have the DVD in input 1 on the back of your TV, then you need to have input 1 selected for your display. This can be found on your remote with a label like INPUT or SOUCE
Feb 26, 2015 | Samsung Televison & Video
I have an rca tv that im trying to hook up to a dvd player and I can't get a signal or channel to work. I don't have a remote but the menu button works. what channel should it be on to play dvds
depend on tv input; if it's only one rca input mean is composite video; if are 3 rca input mean rgb video. so from dvd you need a scart to composite or rgb. on tv usually is AV or AUX channell. try to find a universal remote to select properly the channel. bye
May 23, 2014 | Televison & Video
I bought a Samsung AVR720 almost two years ago as well as a new Samsung blu-ray machine - to match our lovely Samsung series 6 TV (which our friend - who reviews all sorts of equipment - said was a really...
some of them require red , white, blue, green, an yellow audio jacks. make sure you have all the input plugs. or eles the tv will not use plugs it doesnt have.
Mar 05, 2017 | Samsung Televison & Video
Can't see dvd on TV
how to hook up to watch dvds
May 25, 2009 | Sansui VRDVD4005 DVD Player/VCR
DVD Player stopped working... will not LOAD/PLAY dvds
DVDs will not load / play... problem just started... TV approx 14 months old. Recently DVD was working and the TV just "SHUTOFF"?
Mar 03, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Cant see dvds on my emerson tv
Hello.
In many cases by connecting the DVD via a scart cable (depending in what country you live in if your system supports it)
the dvd will send a signal to the TV to switch over to RGB mode when you start playing the dvd. Rember to make sure the scart connectors are firmly pressed into their sockets on both tv and dvd.
Also if you found out how to switch channels directly on the TV try to go through them ...you might find the AV channel that will show the picture from your dvd.
Hope this will help you.
Good Luck.
Feb 13, 2009 | Emerson EWF2704 TV
Truflat tv/dvd will not play disney dvd
Check the rca guide too see supported formats and check to make sure the disney dvd matches that format.
Feb 02, 2009 | RCA 27F530T 27" TV
Unable to get play dvd or get picture on DVD channell on tv
If the player is doing that for all DVDs but playing CDs properly, the player has gone bad due to either the laser and lens being out of whack or the DVD drive just doesn't recognise DVDs anymore and needs repaired or replaced.
Sorry. Best of luck.
Jan 01, 2009 | Philips Televison & Video
Can't get to "Video 1" to play DVDs
try turning your dvd player on and then doing a channel search if that does not work just buy a RF modulator and hook up your dvd player to it and it will run on channel 3 or 4 and will switch over by itself when you turn on your dvd player
Feb 26, 2008 | Emerson EWF2703 27" TV
JVC HD-52Z585 52" Rear Projection HDTV-Ready Television Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
