Question about HP Compaq nx6310 Notebook
Dead laptop fails to power up when push silver on/off button- 19v reading OK from power converter unit
    Champion:
  • 207 Answers
OH no!! have it checked your laptop to your liscensed technician because I have a suspicon about your motherboard that it maybe loosing its connection or fried..
Posted on Feb 05, 2008
Lg laptop not power on only blinking 16 times then stop green led indicator light on when i press the power bottom it will not turn on and green light indicator goes out.?
Did you try a hard stop? Hold the power button down for five to ten secs until all functioning stops, wait five secs then try to power it back up? I'm no laptop expert, but that has helped me a few times here and there.
Aug 24, 2016 | LG Computers & Internet
Don,t turn on
http://www.1800customersupport.com/productdocuments/DTA800B1_RCA.pdf
above is the manual for your unit please read it, after unplugging the unit from the wall. then when you are trough treading it plug it in and verify all connections are in the right spots.
Nov 07, 2011 | RCA (DTA800B1) Video Converter
Hi, I have a Polyview V293 LCD Monitor with a power supply output of 19v 3.42A. The power supply has failed. Most i have found being offered as direct replacement for this monitor have an output of 19v...
If the power adapter is a separate from the monitor then check the monitor's label on the back of the screen for the power rating.If the rating on the label is greater than 3.16A then I would not purchase this adapter.
I suggest you purchase an adapter with a current rating greater than what is stated on the monitor's label.
Check out this WEB site for power adapters - a 19Volt 90 watt = 4.7A power supply is suitable.
http://www.cheaperoz.com/z/result.jsp?ga=sc1&q=19v+power+adapter
Apr 01, 2011 | Amptron POLYVIEW 19" Monitor
I have Fujitsu Siemens ESPRIMO MOBILE V6505.When i push power button it didn't start on; led E is on and nothing else even thought i use charger. Thanks for your helps
maybe the power on button is damaged, try to push it on it's edges or switch off the charger and take out the battery for 5 minutes.
Jan 20, 2011 | Fujitsu Siemens ESPRIMO MOBILE V6505...
What is the center pin used for on the HP 3710b business notebook?I am using a IGO aftermarket power adapter that has the three pin connector tip with center pin like the one DELL uses.Checked with volt...
so what is the full service tag data?
3710b or 6710b, you posted both , and is not complete at all those numbers, (vast submodels exist)
the former number dont fly..
if the PC run ok, on AC pack (HP spec, pack) no battery installed then it (pack) and the PC are ok (no bad jacks)
leaving 2 things, battery (that love to fail) or the charging chip you can not unsolder, ever and replace.
the center pin, seen on the schematic
https://elektrotanya.com/hp_compaq_6510b_6710b_inventec_dd1.0_dosxx_dunkel_1.0_rev_a02_sch.pdf/download.html
or is the AC line loss early warning. (tells PC to go to battery early)
this signal ends up on the charge chip
called Charge Control line.
the schematic is free.
have no battery pack schematic that drives this pin
but its tells the PC to go to (battery early, as power fails AC)
the changer over is not instant
so they this pin tells the PC early, the power is failing
my guess, it can detect power loss, in the pack, in 2 milliseconds flat. (power loss early warning)
Oct 05, 2017 | HP Compaq 6710b Notebook
Charger light flashes when plugged into laptop , stays on solid when unplugged,had charger checked 19v ok ,had socket checked 19v ok ,then checked to first board 19v ok ?? has a board gone down ??? annoyin...
your battery pack is causing your problem rule #1 never!! leave the charger in!! everytime you start up!! run off the batteries till the power low light come's on then apply the charger constant charging causes early failure of all/ any nican battery pack
Jan 13, 2010 | Acer Aspire 5920-6335 Laptop
Computer wont boot have steady amber light on the start push button nothing on monitor
check you power cable and extension socket for steady power supply. if it is ok, consider plugging it into another outlet. if that fails, check your memory card. if you have more than one card installed, consider taking one out and restarting with one. if it fails, swap it with othe on and the othe out. if it fdails, take out the C-MOS battery from the motherboard and replace it after 2 or more minutes. restart the system.
Jul 23, 2009 | Computers & Internet
Gateway laptop no power. Working ok last night checked power supply pack all ok 19v coming through But wont power laptop help
Remove the battery and try to power it. if this fail, them change the memory and then the processor if this also fail then one of the power chips on board is bad (also check the power connector if is not soldered properly.
Jul 01, 2009 | Computers & Internet
Will not turn on, no lights at all
Try to remove the battery, and plug it into the wall. If it then boots, your battery has failed. This happens frequently. If it still wont boot you will need to take to someone to see if the board has died or other issues. Hope this helps
Nov 30, 2008 | Toshiba Satellite M65-S9063 PC Notebook
Dvd is stuck
Ok what you can do (with power off and unplugged) is open the unit up, find the load and unload motor on the DVD carriage and manually turn it this will unload the disk.
Aug 16, 2007 | Zenith ZRY-316 Video Recorder
HP Compaq nx6310 Notebook Logo
59 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
