Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Whirlpool Ultimate Care Model LSR8233EQO - Loud noise during final rinse/spin
It's hard to describe this noise, but I'll try. Not quite a grinding noise (but it may be?), more like dry parts rubbing together. It makes this noise anytime it spins. When it goes to the final rinse and spin cycle, when the drum spins the fastest, it gets very loud. Other than that, everything else works fine.
Any ideas?
Thanks,
Dan
Sounds like the clutch, mi9ne works fine but is noisey when spinning, repair guy said it was the clutch.
Posted on Feb 06, 2008
Cub cadet rzt 50 making grinding noise when starting after it starts still making noise sounds like coming from fly wheel. any suggestions thanks
The shaft that the solenoid pushes the gear up needs lubrication. If it's been grinding too long, the bearing in the starter is worn letting the armature to rub on the field frame. Might be time for a starter motor.
Oct 02, 2016 | Cub Cadet Garden
Ceiling fan making grinding noise
bearings are dry and noise is metal on metal you can try to oil/lube the bearings --and or a blade is rubbing on case either loose blade or bearings worn causing offset wobble
Jul 13, 2016 | Dryers
After it is done grinding and starts to brew it leaks coffee all over my counter. I have tried stopping it after the grind turning off the grind and just brew and putting it on strong and less cups. But...
Try taking the lid to the carafe and soaking in vinegar/ water. Then use as strong a jet of water as you can get from your faucet to blast the crud out from the chamber in the lid. You'll have to try different angles, they did not make that part easy to clean. (I have the same one). Also try taking the grinding basket lid and separate the 2 halves, they just click together and make sure nothing is stuck in there. Good luck!
Mar 01, 2011 | Cuisinart DGB900BCU Grind and Brew 12Cup...
Rubbing/grinding noise
Usually the strut bearing will make this noise upon turning a corner and hitting a rut or pot hole when turning. A wheel bearing will make a low pitched whinning sound constantly
Jan 16, 2010 | 1998 Ford Ranger SuperCab
My LG washer/dryer started to make a strange noise this morning when I put a few towels in to tumble dry. I put it off immediately, and have just tried again (7.30pm). Still making strange noise, not...
Your michines are still under manofacture waranty call LG customer service at the address below.
LG Support Representative at (800) 243-0000
"Was this helpful?"
May 09, 2009 | Dryers
Lg dryer - front load - making a grinding noise
I also have the same problem as klrlesimmons, exactly as described. Sounds like sand is rubbing as the drum turns, and also sounds out of balance.
Repairmen replaced upper and lower glides and also the plastic bearing but not the entire bearing assembly.
Frigidaire Gallery, Model Number 417.49012890
Mar 22, 2009 | LG DLE3777 Electric Dryer
Power supply in Dell 5150 making grinding noise sometimes
Probably the power supply fan - try blowing the power supply out first with air (carefully)
Mar 15, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Loud groaning noise when copier is turned on.
sounds to me like the laser unit is going bad. common problem on this model.
razors
Nov 28, 2007 | Copystar CS-1510 Copier
My GE WDSR2080G makes a metallic rubbing noise during agitation
Take front off and watch while it agitating useing a good light and see if you can tell where the noise is coming from 52c26ee.jpg
Oct 21, 2007 | GE WDSR2080D Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
1,090 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
