Question about Microsoft Excel for PC
Excel Formula I have the formula for adding my column. Now I need to divide that total by a different number each day. I know how to use the proper function in excel but can I put in a formula that allows me to divide that total by a different number each day?
  • Lindypac Feb 05, 2008
    I was on that track but just needed a little bit of help. Thanks.
    Novelist:
    Scholar:
  • 108 Answers
Yes you can and there are two choices. The simple solution is to label a cell "divide by" and put your number in that filed. Then, by changing only that, your answer (in a separate cell) will be available.
There are more complex solutions -assuming your divide by number had some rhyme and reason that could be put in place but.....try this first and at a later date go back and play. Learning to do that will give you more than a fair amount of Excel expertise....something you may find fairly valuable as you continue on using Excel. FYI...I have developed full blown applications on Excel....it is an excellent tool. Hope this helps....Tango.
Posted on Feb 05, 2008
What is formula to find percentage of females in my workplace?
      To get around this, you can calculate your numbers as percentages first. For example, if you type the formula =10/100 in cell A2, Excel will display the result as 0.1. If you then format that decimal as a percentage, the number will be displayed as 10%, as you 'd expect.Aug 2, 2011
      How to do percentages in Excel - Office Blogs
      https://blogs.office.com/2011/08/02/how-to-do-percentages-in-excel/
    Feedback
    How to Calculate Percentages in Excel
    www.excelfunctions.net > Excel-Formulas
    Two Percentage Calculation Types. Calculate a Percentage as a Proportion.Calculate Percentage Change. Displaying Percentages in Excel Cells ...
    Excel formula: Get percentage of total ' Exceljet
    https://exceljet.net/formula/get-percentage-of-total
    Excel simply divides the values in column C by the total in C11. For the formula shown, the result is the decimal number .63. Because the Percentage number format is applied to cell E6, Excel displays .63 as 63%.
Jan 19, 2016 | Computers & Internet
In Excel adding positive and negative numbers
Yes,
  1. Select the column. (click on top of the column it will select)
  2. Right Click and select Format Cells.
  3. Select Currency in Category then press OK
b6298df.gif Now just type your Numbers i.e. 571 for $571 and -650 for -$650 and sum using the normal way.
That is Select the Cells which you want to SUM and Press Alt+=
This will bring the total just below the selected cells.
Thanks
Iqbal
Apr 02, 2008 | Computers & Internet
How do i subtract two cells and progress down a row by a day so the next day the formula subtracts the current day and previous day?
You have to start the sequence with a slightly different formula because there is no preceding value for Monday.
25525374-qztzwsd5tae24twsq5kxbvm0-3-0.jpg The rest of the formulas are running totals so they are the same just dynamically duplicated down the column add infinitum.
25525374-qztzwsd5tae24twsq5kxbvm0-3-2.jpg Just duplicate the the formula Picking up the value form the result column and subtracting the next running subtraction value.
Mar 06, 2015 | Microsoft Excel 2010
Average Handling Time for Emails
You only need one formula for this.
Total handling time divided by the total number of emails answered.
May 13, 2013 | Microsoft Excel for PC
I am trying to figure out a payroll formula. I
Here is how you could do the formula with two one column having the hours of each day in it and the overtime being in another cell:
Example:
Column A Column B
8
8
8
8
0
Total 40 OverTime 2
Formula in this cell where 40 is at:
=IF(SUM(A1:A7)>40,40,SUM(A1:A7))
Formula in cell where 2 is at:
=IF(A8>40,0,SUM(A1:A7)-A8)
Let me know if this helps.
Jan 01, 2010 | Microsoft Excel 2007 Home and Student...
Sometimes when I use a formula in Excel 2003 it will not calculate - it is as if the formula does not exist. an additional problem is that when the formula works it will not calculate several columns if...
Make sure, when you entr a formula that you hit the ENTER key instead of just moving to tyour next cell. To have all numbers added or moved, use the"Special" application, or change the value. Such as -if you are working in text mode and you enter numbers, they are only numbers in text mode. They don't have a value. Correct the cells to reflect numbers. Right click, format cell - select what you want.
Nov 05, 2009 | Microsoft Office Excel 2003 for PC
How do i insert a formula in a column to add each number & give a total at the bottom?
For example, you have three numbers from A1 to A3. On row A4, type =SUM(A1:A3).
That should do it. :)
Sep 16, 2009 | Microsoft Office Excel 2007
How to add % (Percentage column ) in the excel
The formula is 200/700 equals the percentage;if you're in columns a, b, and c, the formula in c1 will look like:
=b1/a1.
Then you can format the cell to show the number (.2857) as a percentage (28.57%).
Jan 03, 2009 | Microsoft Computers & Internet
No problem, Melinda, I am here to help!
If I understood correctly, your spreadsheet looks something like this:
A B C D
1 Question Yes No Total
2 Is sky blue? 20 2 22
3 Is world round? etc.
In this case, the formula for % of Yes would be: =B2/D2. This would give you a decimal point result such as 0.909091. Now if you want to make this look like a percentage in your spreadsheet, just do the following:
1) click on the cell where you have the division formula
2) clck on Format in the top menu bar
3) click on Cells
4) click on the Number tab (if you're not already there)
5) click on Percentage in the list of categories
6) click OK
To boil it all down to a simple principle, percentages are created in Excel by dividing the two numbers using a formula with "/" in it, and then formatting the result to look like a percentage instead of a decimal.
I might have misunderstood your question, and I have an idea of what else you might have been asking (and another slightly more complicated solution for it!), so please let me know if my first answer didn't hit the mark!
Good Luck!
Regards,
RichMTech
Aug 08, 2008 | Microsoft Excel for PC
Sum of Alternative Columns
Alternative Formula? please explain it.
Jul 31, 2008 | Microsoft Excel for PC
Open Questions:
See all Microsoft Excel for PC Questions
Microsoft Excel for PC Logo
134 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
