Question about Rio Carbon MP3 Player
RIO CARBON VISTA PROBLEM LAPTOP
Hi, i have a new Sony V10 Laptop pre installed with Windows Vista but when i connect my RIO Carbon player MP3 IT initially installed it when i plugged in my USB Cable but now the icon has disappeared and its dead, any help appreciated, i do not have the original RIO C.D to install it, do i need a new C D to install Rio again.
Thanks.
  • 8,596 Answers
Here is where to get the software for your Rio:
http://www.digitalnetworksna.com/support/rio/
Rio went out of the Mp3 business before vista came around, so you may need to get in touch with Microsoft to find out if Rio can be made compat with Vista.
Posted on Mar 20, 2008
When I transfer music from Rio Music manager to my Rio Carbon the music manager indicates transfer successful but the MP3 player states no tracks present?
Try to transfer the tracks from the explorer.
1 Connect the Rio Carbon to a computer using the supplied USB cable.
2 Double-click My Computer on the Windows Desktop or in the Start Menu.
3 Locate MP3 or WMA audio files on the computer.
4 Highlight files and/or folders to transfer to the Rio Carbon.
5 Click Edit.
6 Click Copy.
7 Double-click My Computer on the Windows Desktop or in the Start Menu to open another window.
8 In the new window, locate the Rio Carbon (X:) icon that is associated with the Rio Carbon. (X equals the drive
letter assigned to the Rio Carbon.)
9 Double-click Rio Carbon (X:).
10Click Edit.
11Click Paste.
May 24, 2010 | Rio Carbon MP3 Player
My Rio says it's full, but only shows one 6KB file
no it cant be recovered you have to format the player using xp or vista if you can that is try that out
Jan 01, 2010 | Rio Carbon MP3 Player
Is Rio Carbon compatible to Vista New computer not recognising Rio
it appears that it is. should be automatically recognized by vista. if not it may have failed. try unplugging the batteries for about 20 minutes.
Nov 30, 2009 | Rio Carbon MP3 Player
Rio Carbon stuck on Formatting
Leave it for around 2 hours to format. If it is still formatting, pull the cable out. Some of your data may corrupt, but it will get unstuck. Then plug it in again, go to Start>My Computer, right click your player, and select format.
Aug 27, 2009 | Rio Carbon MP3 Player
Tranfer from player to computer?
Go to Main Menu -> Settings -> Advanced -> Transfer Mode and select MSC. Worked for me.
Nov 18, 2007 | Rio CE2100 MP3 Player
Rio s10
? Verify that the USB cable is securely inserted into the USB port on both the Rio Carbon and your computer. ? Connect the USB cable to a USB port on the back of your computer rather than to a USB port on the front of your computer. ? If using a USB hub, connect to a powered USB hub. Unpowered USB hubs may not work. ? Remove USB extension cables from the connection path. ? Disconnect other USB devices. ? Both Windows XP Service Pack 1 (SP1) (or greater) and Windows Media Player 10 (WMP10) must be installed for your computer to detect a Rio Carbon set in MTP mode. ? If you do not want to install SP1 (or greater) and WMP10 on your computer you should disconnect the Rio Carbon and change the Transfer Mode setting to MSC mode. Good Luck
May 24, 2007 | Rio S10 MP3 Player
Transferring music to new pc
You must use the music transfer software that came with the CD (also avail on Rio website) - which will not load on newer, Vista running computers.
May 03, 2007 | Rio Carbon MP3 Player
Rio Carbon 5 g
When Microsoft initiated the DRM system, any Rio Carbon that was hooked into Windows Media Player had the previously working files invalidated. Happened to me as well. The player lasted me three years, and that is about as long as any Mp3 player is going to last we are finding out b/c of all the software snafus.
Jan 09, 2007 | Rio Carbon MP3 Player
Rio pearl directory corrupted
first, and this is always good: If available, firmware for the Rio Carbon can be downloaded online. Second, this might be the problem: The Rio Carbon communicates with your computer differently in MTP mode than it does in MSC mode. When in MTP mode, the Rio Carbon cannot display hidden files in folders, cannot allow transfers to the root Rio Carbon directory, and cannot allow the creation of new folders. (Folders can be transferred to the Rio Carbon using drag-and-drop and copy-and-paste methods.) To use traditional folder options, change the Transfer Mode settings to put the Rio Carbon in MSC mode. Last, "..Removing the Rio Carbon from a USB connection before Idle is displayed on the screen may result in a corrupting the player's file system. If for any reason you suspect that your Rio player's file system has been corrupted, reformatting the player will restore the file system to its original state..."
Nov 27, 2005 | Rio Carbon MP3 Player
Rio Carbon MP3 Player Logo
237 people viewed this question
Top Rio Audio Players & Recorders Experts
Mohammad Abumuailek
Mohammad Abumuailek
Joseph Hoffmann
Are you a Rio Audio Player and Recorder Expert? Answer questions, earn points and help others
