Question about HP Color LaserJet 2600n Printer
HP laserjet 4250 evelope smudge
This isn't my printer, but your system won't let me chat with anyone even if I can't find my product. i have an HP laserjet 4250 help. I have been trying to chat for some time.. since paying and getting nothing. please contact me!
  • Brad Clapp May 11, 2010
    What's your problem?
My pernter was not print
Posted on Jun 29, 2008
  • 35 Answers
What kind of trouble are you having?
ie.
is it jamming is it making noises???
4250 n ,nt dtn?
Posted on Apr 07, 2008
It is printing but the lettered is fuzzy
Best practice is to indicate device, brand, and model when querying about printers. Solutions vary by such often.
The blurring could be caused by the type of paper being used. Or, too much paper being in the printer. It can also be caused by substances adhering to the ribbon (where one is part of the setup). Then there is a potential problem with a fuser in a laserjet.
For example:
Printed documents print ghosted blurry grainy doubled or with smudges What...
How to Solve Common Printer Problems
Fuzzy Print HP Laserjet 4240 4250 and 4350 Printers
Aug 28, 2017 | The Office Equipment & Supplies
Need installation program
you can check how to setup, install and configure your HP laser jet 4250 printer from here
Click to see check the page
and here is the driver link for your HP laser jet 4250 select your operating system then download
Click here to Download the driver
This will help. Thanks please keep updated. please do rate the solution positively .Thank you for using Fixya
Regards
Manish
Jan 12, 2010 | HP LaserJet 4250 Printer
Error during print 'Remove all paper from bin'
HP Laserjet 4250 Network connected laserjet printer.
Steps to be follwed to set right :
01. Please check in number of desktops or laptops it connected.
02. Give proper IP Address in the Desktop or Laptop where it has to be orignally installed.
03. Being a network printer, lot of desktop or laptop users might have printing job iniated.
04. Right click the printer properties which is available bottom right hand corner ikon and delete or cacel all printing jobs.
05. The original desktop or laptop where the IP Address created will be rebooted. System should be restarted.
06. Try to print now to close this solution.
07. Still the problem persits, kindy contact local HP Authorised printer service engineer to set right this issue.
Have a nice working day.
Jul 17, 2009 | HP 4250 Monochrome LaserJet Printer
HP 4250 laserjet will not go through the start up sequence.
Well first do what joe said about checking the Plug on the Display, <Here's another solution did you also check the cables( Power Cables going to the format bd ? Sometimes you can bent those pins easily, I have seen it and ok I done it once on HP 4 plus when i first started out as a tech ? Check that ? May I asked What was the reason for replacing the Formatter board in the first Place ? were you getting an error ?
Mar 19, 2009 | HP LaserJet 4250n Printer
Ink smudges on the right side of the paper
Your problem is due to a worn fuser unit (upper fuser roller).
The teflon coating has worn again, alowing the toner to stick to the roller and then "repeat" about 3x down the paper (getting fainter each time).
You need to order a new fuser unit.
Click here to go to HP direct
RM1-1083-070CN Fuser assembly - 110 VAC - For LaserJet 4250/4350 series RM1-1083-070CN Fuser assembly - 220 VAC - For LaserJet 4250/4350 series
Make sure you order the currect voltage (US or UK)
Regards
Vince.
Mar 04, 2009 | HP LaserJet 4250n Printer
Hp 4250 paper jam erro
Is it a new or refurbished fuser? Where exactly does it jam. By trays, registration or before fuser? Problem can be with various sections. Need to know more.
Feb 12, 2008 | HP LaserJet 4250dtn Printer
I think it's been left open and has collected some fluff and dust, It needs a good clean. Just maybe there's a Toner Printer Cartridge leak.
Feb 05, 2008 | HP DeskJet 5650 InkJet Printer
Envelopes smudge
I have been informed that these fusers have a seperate heating element in the middle of the heat roller for envelopes to save energy and it's temperature is not sensed by the thermistor.If I trick the printer (with paper path tests) into printing envvelopes while thinking that it is letter the fusing is ok.
Feb 05, 2008 | HP 4250 Monochrome LaserJet Printer
HP Laserjet 4250 PCL6 prints only one page
Vista??? will be a driver issue, are cd drivers correct for your system?
Goto canon web download correct driver, delete old reinstall, most operating system will have this driver standard.
doubt printer problem prove by doing test prints via printers menu.
Nov 09, 2007 | HP 4250 Monochrome LaserJet Printer
HP Color LaserJet 2600n Printer Logo
219 people viewed this question
Ben Johnson
