Question about Palm Treo 700w Smartphone
Voice dialing is voice dialing via Jawbone possible with Treo 700w?
  • DRHJJ Feb 05, 2008
    I was led to believe by Verizon salesperson that I could voice dial on the 700W. Is it just the jawbone that doesn't work or is it impossible with all blue tooth headsets?
I did it today. The problem is that unless you are looking at the phone you have no idea when to respond to the phone when it asks for confirmation. Watch the phone when you do it, be patient and figure out the timing.
Posted on Dec 26, 2008
On my treo 700w on the today screen where you have voicemail and 411 connect when I tap voice mail it dials previous owners voicemail number...how do I change that to my number?
I fixed it! I tapped on menu and then tapped speed dial options...highlighted voicemail and tapped menu and tapped on edit and was able to change the number.
Aug 04, 2009 | Palm Treo 700w Smartphone
How do I turn off the creepy talking phone function?
Go to Start, Settings, Personal, System, Voice Command, UnCheck 'Enabled'
www.fhonwizards.com     Jim B    www.smartphonerepair.biz
Apr 29, 2009 | Palm Treo 700w Smartphone
Treo 700w doesn't ring when called
Increase the phone volume. You'll get a ding for missed call from the PDA volume side, but the phone volume controls the ringer volumes and voice features... Access it from the buttons on the side or with settings menu.
If the volume is already maxxed, try updating the firmware on the device. You'll need to have the phone attached to a PC via USB cable, download and run the package. It'll wipe out your address book and other data on the phone though so make sure you have this backed up or can replace it.
Good luck :)
Feb 02, 2009 | Palm Treo 700w Smartphone
My Treo 755p will recognizes my new jawbone but will not connect. It seems to skip the step where I am supposed to enter a password into to connect to the jawbone. Any ideas? Josh
Delete any other bluetooth devices paired to your phone. Then, for the Palm Treo 755p . . .
To pair the Palm Treo 755p handset with the Jawbone, perform the steps listed below:
  1. Set the Jawbone to Pairing Mode.
    • For the Original Jawbone, press and hold down the Noise Shield button for at least three seconds until the LED Indicator Light flashes red.
    • For the New Jawbone, press and hold down both the NoiseAssassin™ Button and the Talk Button for at least three seconds until the LED Indicator Light flashes red and white alternately.
  2. Press Applications and select Bluetooth.
  3. Select Bluetooth On.
  4. Select Setup Devices.
  5. Select Trusted Devices.
  6. Select Add Device. (The Discovery icon appears, indicating that the discovery process is active.)
  7. Select the Show pick list and select Nearby devices.
  8. Select Jawbone from the Discovery Results list, and then select OK.
  9. Enter the PIN "0000" (be sure you are entering four zeroes and not the letter "O".) and select OK.
  10. Select Done, and then select Done again to return to the Bluetooth screen.
Your phone should now be paired with the Jawbone.
Jan 26, 2009 | Palm Treo 755p Smartphone
Treo 700w
Contact your cell phone carrier.  They can fix this for you, possibly even by sending your phone a new lock code right over the wireless signal!
Sep 09, 2008 | Palm Treo 700w Smartphone
I have a Mac laptop, a Palm Treo Wx and am now using a Motorola H700. I need to know how to sync my H700 with my Treo so I can dial via my headset and not need to use the actual cell phone. It has now...
Hi, i'm not sure what the Mac has to do with your Headset. You can register your blue tooth headset with any device that supports bluetooth. In fact, you can use your headset with multiple devices. Even your Mac can use bluetooth to connect to a headset (if you have bluetooth turned on, and not all Macs have factory bluetooth).
To 'register' your headset with the Treo is a two step process.
on the Treo, make sure bluetooth connectivity is turned on, then you should have a menu that allows you to find/enroll a new bluetooth device. Before you tell it to find a bluetooth device, turn on your headset. Now tell the Treo to search for devices. If it doesn't find your headset, then press and hold the button on the side and it will send out signals that your Treo will see. The Treo might give you a password code and ask you to confirm this is the device you want to synch to. Usually '0000', but in any case say yes, so long nobody else is around trying to do the same thing you are within 30'.
That should do it.
I don't think the Treo has voice recognition, which makes dialing on my Nokia a breeze, for true hands-free operation, nothing beats it.
Also note, the Treo has been know to have issues loosing bluetooth connectivity with the headset and not reconnecting with a re-boot.
so long you keep the two devices near each other, this shouldn't be a problem.
stephen
Jul 05, 2008 | Palm Treo 700w Smartphone
Will not voice activate
Does your Treo 700W support "voice dialing"? I searched the whole user guide for the Treo 700W and it does not say anything about dialing by voice. If the phone does not support it than no matter what Blue Tooth unit you use you will not be able to voice dial.
Jun 02, 2008 | Motorola Mobility H700 Wireless Headset
Palm Treo 700w Smartphone Logo
49 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
