Zoneline 3100 I have a zoneline 3100 , and it seems at a certain temp. the unit shutts down , no fan , no heat . After a few days the unit will begine to run normal again . I have attempted to have it looked at by several heating and plumbing co. but no one wants to work on it . I`m thinking it may be a sensore issue ? Can you help please ! It`a very cold here in Weastern NY . The temp it seems to quit at is around 30-40 degrees .
  • Ajets May 19, 2008
    Not same problem, but similar. In my case the zoneline 3100 will not shut off. It will sometimes appear to but then turn itself back on (running essentially as a fan) with the switch still in the start position. Only person who even semi looked at it suggested replacing the whole unit. Seems like just a bad switch to me. Is there a good source for replacement switches for these units? (by the way - best answer so far ... not too helpful)
  • 86 Answers
Check on / off switch.
wiring of unit
there is loss connection
Posted on Mar 16, 2008
It is a Heat Pump and doesn't work well in low temperature.
Posted on Jan 21, 2013
GE Zoneline heating limits
would be easier to get those temps using the outdoor portion of the system, however, not too many companies build thermostats that reach that range
Nov 14, 2013 | GE Zoneline AZ55H07D Air Conditioner
GE Zoneline blowing hot air in afternoon.
Maybe but check the temp difference between outlet and inlet. Should be 25 to 30 degrees. Rus
Jun 29, 2009 | GE Zoneline AZ55H07D Air Conditioner
Thumping noise while running
sounds like the bearings are bad or something is catch in the fan
Apr 03, 2009 | GE Zoneline AZ55H09D Air Conditioner
Cold Air Penetrating from around & thru GE Zoneline 2100 Unit
There is a baffle/damper that allows outside fresh air to flow through the unit. This is only supposed to be open in cooling mode when the outside temp is moderate, or whenever you want just fresh air and fan operation.
Find the lever that controlls the baffle.
Some units have a switch in the control panel for this.
Jan 19, 2009 | GE Zoneline AZ38H12DAD Split System Air...
Air conitioner turns on by itself
The GE Zoneline units have small DIP switches inside the unit where you can turn various functions on or off. The units have a feature called Heat Sentinel that turns the A/C on at a certain room temperature, even when the unit is turned off. It also has a Freeze Sentinel that turns the heat on automatically, even when the unit is turned off. You can turn off the heat and freeze Sentinel features with the DIP switches in the unit. There are other features you may want to turn off. Read the owner's manual and it will tell you where the switches are and which ones turn off the features. Hope this helps.
Sep 17, 2008 | GE Zoneline AZ55H07D Air Conditioner
How to best run this thing
Hi Laurelrobin,
When the unit is on "low fan", it is fan only, and is recirculating room air. If the damper is open, it can also bring in outside air. If the space is not occupied for extended periods, it's OK to turn the unit "OFF", as long as you have a newer unit with Heat Sentinel, and the Heat Sentinel is turned on. Heat Sentinel will not let the room temp get above 85F, as long as the unit is OFF. Also, in most cases it's best to keep the damper closed. You can check your owner's manual for more info on the Heat Sentinel and other auxiliary functions. I also have an article on the temperature limiting functions of the GE Zoneline.
Feel free to contact me at greg.mcnary(at)airdistributors.com if you need further info.
Greg McNary
Air Distributors Company, Inc.
Louisville, KY
Distributors for GE Zoneline PTAC Units, Zoneiare PTAC Units, and McQuay PTAC Units.
Aug 01, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Problem with GE Zoneline 5200 model
Heat pumps have saftey circuits that prevent liquid flooding of the compressor. Inadequate airflow across the evaporator in cooling can trip this circuit. Have your package unit serviced with particular attention to cleaning the evaporator coil and be sure your filters are clean and changed frequently in the summer months. Hope this helps GL!
Jun 07, 2008 | GE Zoneline AZ38H12DAD Split System Air...
I WANT TO BUY THE UNIT WHICH CHANGE HEATING AND COOLING AND TEMPERATURE UNIT FOR GE ZONELINE
WITH ANY OF THESE UNITS YOU CAN WIRE AN EXTERNAL THERMOSTAT WICH WILL ACOMPLISH THIS, JUST MAKE SURE YOU PURCHASE A T-STAT WITH A HEAT / COOL AUTO CHANGE OVER.
Jan 10, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Short cycling
The most common cause is the fan relay on the main circuit board. However, if the outside temperature is 30degF and the inside is 60-65degF then the cause could be the insulation is ruined or missing on the backside of the unit's firewall. This can cause the unit's internal thermocouple wire to read below 45degF which is the freeze sentinal temp level. Anything below this temp level will cause the unit to come on for a few minutes to warm up the air and bring it to 46degF or higher to protect internal plumbing from freezing.
The best way to check for this is to manually set the unit to one of the heat modes and the thermostat up just until the heater comes on. Let it run until the unit turns itself off. Then set the mode switch back to Off and see if the unit still cycles on and off as before.
If it does then the main circuit board should be replaced unless you are comfortable de-soldering and re-soldering another fan relay in place.
Dec 20, 2007 | GE Zoneline AZ38H12DAD Split System Air...
Heating & Cooling Logo
322 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
