Question about HP DeskJet 5650 InkJet Printer
HP laserjet 4250 evelope smudge
4250 smudges envelopes. worse on letterhead evelopes.
  • Pedro Sanchez Nov 24, 2008
    your post as a comment to scot5's HP laserjet 4250 evelope smudge problem, and notify you when a new solution is offered.
This is a common problem with 4250/4350 fusers.They have a seperate heating element for envelopes in the middle of the heat roller that is not controled by the thermistor.If I trick the printer (with paper path tests) into printing on an envelope while thinking it is letter the problem dissapears.I think HP will have to fix this, perhaps with driver or firmware upgrades.
Posted on Apr 24, 2008
    President:
  • 1,017 Answers
I think it's been left open and has collected some fluff and dust, It needs a good clean. Just maybe there's a Toner Printer Cartridge leak.
Posted on Feb 05, 2008
Ink smudges on thicker weight paper even though I have selected letterhead.
hp have a print media guide u can check it to see if your paper meets hps print media suggestions
also using hp approved paper might help
u can google hp print media guide
Jan 19, 2011 | HP LaserJet P2015dn Printer
Prints dirty only with evelopes
hp recommends purchasing an envelope feeder (part # CB524A.
when using an envelope feeder the speed at which the envelopes go thru the machine changes....this should solve dirty copy issues.
Jan 08, 2010 | HP LaserJet P4014n Printer
I can print everything but envelopes. ???
get evelopes for 2 dolars at dolla tree!!
Oct 06, 2009 | HP LaserJet 4 plus Printer
Ink smudges on the right side of the paper
Your problem is due to a worn fuser unit (upper fuser roller).
The teflon coating has worn again, alowing the toner to stick to the roller and then "repeat" about 3x down the paper (getting fainter each time).
You need to order a new fuser unit.
Click here to go to HP direct
RM1-1083-070CN Fuser assembly - 110 VAC - For LaserJet 4250/4350 series RM1-1083-070CN Fuser assembly - 220 VAC - For LaserJet 4250/4350 series
Make sure you order the currect voltage (US or UK)
Regards
Vince.
Mar 04, 2009 | HP LaserJet 4250n Printer
How do you print envelops - the names are never centered and theirs a ig space between name and address on envelops hp office jet pro 6480 all in one
Since there are few step you have to complete before you can pirnt envelop
and theis site will not let me listed all of the step and pic to show you how it is setup.
the following link is the HP 6480 printer define how the evelop printing is done.
start on page 21.
http://h10032.www1.hp.com/ctg/Manual/c01325559.pdf
Jan 13, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
What kind of trouble are you having?
ie.
is it jamming is it making noises???
4250 n ,nt dtn?
Feb 05, 2008 | HP Color LaserJet 2600n Printer
Envelopes smudge
I have been informed that these fusers have a seperate heating element in the middle of the heat roller for envelopes to save energy and it's temperature is not sensed by the thermistor.If I trick the printer (with paper path tests) into printing envvelopes while thinking that it is letter the fusing is ok.
Feb 05, 2008 | HP 4250 Monochrome LaserJet Printer
Ink smudges off envelope
You will need to select in the drive that the media type you are putting in is envelopes this will adjust the printer fusing section to increase the heat.
Also you must select to go through tray one when doing this open the back door and the printed envelope will come out of the back and should be fine. If not try a lesser grade of envelope if still the same problem then the fuser unit is slipping and will need to be replaced.
Hope this helps you
Thanks J
Jan 02, 2008 | HP LaserJet 4250n Printer
Hp 4250 GHOSTING
Are you telling the machine that paper type is letter head or envelopes, It must be done, it changes temp of fuser to suit the paper type, no it is not a power supply problem change paper type to card stock/thick/letterhead etc to suit then machine will adjust temp to suit.. ie file, print properties paper type.
50.2 fuser error replace fuser.
Dec 06, 2007 | HP LaserJet 4250n Printer
HP DeskJet 5650 InkJet Printer Logo
392 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
