Question about Brother IntelliFAX 4100 Laser Fax
Printing Online The window says Printing Online, but nothing is printing. It seems to be holding in memory, but I don't know how to reset it.
  • meps_sj Feb 07, 2008
    I accessed the Menu which gives me a choice of 1. General Setup 2. Fax and 3. Copy. I accessed 2 and then 0 (which was miscellaneous). The choices after that were 1. Distinctive 2. Caller ID and 3. Drum Life, none of which would reset it. Thanks for trying but I think we are talking about 2 different faxes.
I had the same problem, got this solution from brother and it worked!
unplug the fax machine
press and hold the stop button
while still hold down the stop button, plug the machine in
continue to hold down the stop button for 5 seconds
Posted on Feb 22, 2008
    Scholar:
  • 78 Answers
Access User service mode by pressing Menu, Mode then 0
Enter 91 for reset
Press stop to exit
Posted on Feb 05, 2008
  • Clint Bowden
    Clint Bowden Feb 07, 2008
    Try menu, start then 0 should also work. It has to be pretty fast and the lights should flash if you access the mode.
Brother HL-1435 printer not printing. Alarm and data lights stay on. I tried replacing the toner, replacing the drum, factory resetting printer (both are genuine Brother products), uninstalling and...
try reseting drum unit
Open the front cover. Locate the black button under the LED lights on the left side. Press and hold in the button until all the lights are lit. Release the button. The counter is reset!
its toner soup
Nov 18, 2013 | Brother HL 1435 Laser Printer
Can't reset double sided printing to single side only as default
Exact same problem... took a couple of hours of fiddling but seems that to get it to stick you have to change the printer settings in windows rather than when you are actually printing a document. eg Control Panel > Printers > right click printer > Properties > (General tab) Printing Preferences > then for Double-Sided Printing select 'none' and press OK. Job done.
Oct 08, 2012 | Samsung SCX-3400 All-in-one Laser printer...
Hi - it says on the display printing online but nothing is happening
Turn off the power, hold down the red clear/stop button while turning the power back on. This should reset whatever has locked up the printing memory.
Good Luck and Thank You for using Fixya.
May 27, 2010 | Brother FAX-8360P Plain Paper Laser
My ip4300 keeps printing the same page over and over again. There's nothing in the print Q, but no matter what new job I send to the printer it prints the same old page. Is there a way to reset the printer...
Have you rebooted your computer? The printer's memory is very limited -- certainly not enough to hold an entire page. Your computer feeds the printer a line at a time, so it would seem that your computer's print spooler is 'stuck' on that print job. Try shutting the computer down completely, then restarting and see if that print job clears out.
Mar 24, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Printing error ''Printing Online'' and nothing prints.
TURN MACHINE OFF HOLD DOWN STOP KEY AND THEN TURN ON OR PLUG IN
Aug 17, 2009 | Brother Office Equipment & Supplies
Says printing but won't print
After resetting the spooler, I had to reboot the computer for the printer to work.
Jul 22, 2009 | Office Equipment & Supplies
Uf-9000 Memory not printing
it seems to be locked up, just turn the power off then on .. you wont lose your docs and you should be working
Jun 02, 2009 | Panasonic Panafax UF-9000 All-In-One Laser...
No dial tone/message window says printing
Use Hard Reset to reset machine after power loss. See today's post.
Jul 02, 2008 | HP 1020 Plain Paper Thermal transfer Fax
Says Printing & Online Stuck
when this happens, unplug machine, hold down the "stop/exit" key while plugging machine in. continue holding the stop/exit key for 5 seconds. display should return to the regular date and time screen. if it doesn't, contact brother customer support. this problem is caused by a fax stuck in memory.
hth,
razors
May 13, 2008 | Brother IntelliFAX 4100 Laser Fax
Brother mfc 8440 "printing" problems
Hi
I recently had this problem - tested fuser and all sensors.
The fix is to reset the memory.
To do this, enter the Maintenance mode. Menu, * 2864
(enter the number quickly)
then type 01 ( zero one ), this will reset all memory including the user settings.
Finally type 99 to exit Maintenance mode.
The printer will restart and the error will be gone. Test out with copy and printer reports
Hoping this fixes your problem
Regards
Lindsay
Nov 15, 2007 | Brother MFC-8440 All-In-One Laser Printer
Brother IntelliFAX 4100 Laser Fax Logo
292 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
