Question about HP 4250 Monochrome LaserJet Printer
Envelopes smudge I have a new HP 4250 and letterhead envelopes smudge 100% of the time. white envelopes don't. I have tried changing fusor settings to no avail. ideas?
  • traveldiane Nov 25, 2008
    I have the same problem. How do you trick the printer?
  • batman123180 Apr 04, 2009
    HP 4250TN PRINTER PRINT SMUDGE
I have been informed that these fusers have a seperate heating element in the middle of the heat roller for envelopes to save energy and it's temperature is not sensed by the thermistor.If I trick the printer (with paper path tests) into printing envvelopes while thinking that it is letter the fusing is ok.
Posted on Apr 24, 2008
  • gundown Apr 24, 2008
    My post was only an explanation not a solution.I believe HP will have to correct this with driver or fimware upgrades.
When I try to print #10 envelopes on my HP Laserjet 4 Plus printer through the MP tray, they come ou with wrinkles, smudges and creases. And they are hot! ideas?
Make sure that if you have a setting for paper type you have it set for envelope. This would be found in the setup menus, I just don't remember if this model has that setting, they are getting to be rare now. The other common cause of print problems is the envelopes themselves, if they are old or have been stored where they have been allowed to absorb moisture, you will have a very hard time printing on them. Try some different envelopes if you have them.
Jul 11, 2011 | HP LaserJet 4 plus Printer
Loading envelopes in an HP Laserjet 4250
Envelopes in the HP 4250 are loaded in tray 1 -- the pull-out tray on the front of the printer. Set the envelopes in and adjust the side guides, then go into the menu and set the correct paper size and type for tray 1.
Jan 29, 2010 | HP LaserJet 1020 Printer
4250 HP. Loses settings. Correct to show envelope
In the paper-handling menu set the envelope feeder size to the size of your envelope and the envelope feeder type to *any type.
Then ensure you are printing envelopes from your application.
Nov 25, 2009 | HP LaserJet 4350 Printer
Hp color LaserJet 3700 jams 70# uncoated letterhead stock
Hi manitou344:
Here is some info that might help you.
Table 1-8. Tray 1 paper sizes1
Media Dimensions Weight or thickness Capacity
Minimum size paper 76 by 127 mm
(3 by 5 in)
60 to 163 g/m2
(16 to 43 lb bond)
100 sheets
(75 g/m2; 20 lb bond)
Maximum size paper 216 by 356 mm
(8.5 by 14 in)
60 to 163 g/m2
(16 to 43 lb bond)
100 sheets
Minimum size glossy
paper
76 by 127 mm
(3 by 5 in)
75 to 120 g/m2
(20 to 32 lb bond)
Maximum stack
height: 12 mm (0.47 in)
Maximum size glossy
paper
216 by 356 mm
(8.5 by 14 in)
75 to 120 g/m2
(20 to 32 lb bond)
Maximum stack
Minimum size
transparencies2
76 by 127 mm
(3 by 5 in)
0.12 to 0.13 mm thick
(4.7 to 5 mils thick)
50 sheets
Maximum size
transparencies2
216 by 356 mm
(8.5 by 14 in)
50 sheets
Minimum size
envelopes
76 by 127 mm
(3 by 5 in)
60 to 90 g/m2
(16 to 24 lb bond)
10 sheets
Maximum size
envelopes
216 by 356 mm
(8.5 by 14 in)
60 to 90 g/m2
(16 to 24 lb bond)
10 sheets
Minimum size label 76 by 127 mm
(3 by 5 in)
75 to 163 g/m2
(20 to 43 lb bond)
50 sheets
Maximum size label 216 by 356 mm
(8.5 by 14 in)
75 to 163 g/m2
(20 to 43 lb bond)
50 sheets
Minimum size
cardstock
76 by 127 mm
(3 by 5 in)
135 to 216 g/m2
(43 to 43 lb bond)
50 sheets
Maximum size
cardstock
216 by 356 mm
(8.5 by 14 in)
135 to 216 g/m2
(43 to 43 lb bond)
50 sheets
This printer can
detect transparencies that were not designed for use with HP Color LaserJet printers.
Jun 30, 2009 | HP Office Equipment & Supplies
Ink flakes off envelopes. No problems with sheets of laser paper.
High burnier:
Try these settings.
FUSER MODES
PLAIN
PREPRINTED
LETTERHEAD
TRANSPARENCY
PREPUNCHED
LABELS
BOND
RECYCLED
COLOR
CARDSTOCK>164 G/M2
ROUGH
[Paper Type]=
NORMAL
LOW
HIGH1
HIGH2
ENVELOPE
RESTORE MODES
Use this item to configures the fuser mode associated
with each media type.
Change the fuser mode only if you are experiencing
problems printing on certain types of media. After you
select a type of paper, you can select a fuser mode
that is available for that type. The available selections
might include some or all of the following modes:
NORMAL: Used for most types of paper.
HIGH 1: Used for rough paper.
LOW: Used for transparencies.
HIGH 2: Used for paper that has a special or rough
finish.
The default fuser mode is NORMAL for all print media
types except transparencies (LOW), and rough paper
(HIGH 1).
CAUTION
Do not change the fuser mode for transparencies.
Failure to use the LOW setting while printing
transparencies can result in permanent damage to
the printer and fuser. Always select Transparencies
as the Type in the printer driver and set the tray type
at the printer control panel to TRANSPARENCY.
When selected, RESTORE MODES resets the fuser mode
for each media type back to its default setting.
Hope this helps
May 24, 2009 | HP LaserJet 4300n Printer
Cannot print odd-sized envelope with 4250 LJ
I got to HP tech support, and they tell me that the envelope feeder is intended only for a few standard envelope sizes. If we're trying to use a different sized envelope, as in this case, it must be fed manually, and the feeder bin will not work. So that answers that. Thanks for the help, though.
Apr 29, 2008 | HP 4250 Monochrome LaserJet Printer
HP laserjet 4250 evelope smudge
I think it's been left open and has collected some fluff and dust, It needs a good clean. Just maybe there's a Toner Printer Cartridge leak.
Feb 05, 2008 | HP DeskJet 5650 InkJet Printer
Printer 4250n no print
What do you mean by logo? Do you mean the Menu Page?
Jan 30, 2008 | HP 4250 Monochrome LaserJet Printer
Hp 4250 GHOSTING
Are you telling the machine that paper type is letter head or envelopes, It must be done, it changes temp of fuser to suit the paper type, no it is not a power supply problem change paper type to card stock/thick/letterhead etc to suit then machine will adjust temp to suit.. ie file, print properties paper type.
50.2 fuser error replace fuser.
Dec 06, 2007 | HP LaserJet 4250n Printer
HP 4250 Monochrome LaserJet Printer Logo
401 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
