Question about HP (H50092)
I am trying to figure out how to use the hp wireless keyboard and mouse combo
Not sure how to get them initially working, I do not have the instructions
  • Anonymous Jun 05, 2008
    Wireless kb and mouse
    Champion:
  • 207 Answers
Go to www.hp.com to get your instruction manual. alright??
Goodluck!!
Posted on Feb 05, 2008
Wireless keyboard and mouse works fine with computer but when I attempt to use it on the f1dh104l switch it does not recognize the mouse or keyboard. it is a dell e6400 laptop that i'm attempting to...
the problem is that most Wireless Keyboard and Mice combos use Composite USB, the KVM however is expecting one signal on each entry port (one for mouse, and one for Keyboard).
replace yoru wireless Combo for a standard Keyboard and Mouse to make this work.
A work around would be using a MS Wireless Mouse and a different brand of Wireless Keyboard using both Wireless receivers and plug them into different ports on the KVM
Jun 05, 2011 | Computers & Internet
Wireless mouse won't work, have replace battery, rebooted laptop removed and replaced mouse connection etc. Was working fine until yesterday
Is it not working at all or is it moving erratically across the screen? If it doesn't seem to be working at all, turn off your mouse then unplug the receiver's USB cable from the laptop for about 5-10 seconds then plug it in to another USB port. It may detect a new device, just let it do the automatic installation if it asks. You should here a 'tada' or ding sound when it is plugged in. When installation is completed or about 10 seconds after you hear the sound, turn your mouse back on.
If it still doesn't work, try shutting down your laptop completely instead of just rebooting it.
If it still doesn't work after that, make sure you have a spare USB mouse available then uninstall the software for your wireless mouse or mouse/keyboard combo then reinstall it.
Mar 23, 2011 | HP Wireless Optical Mouse
I have a Dell Inspiron ONE Desktop. My wireless mouse is working properly. However, my wireless keyboard is not functioning at all.
First, make sure that all of your batteries are good and working in all your wireless devices. I am assuming that this is a wireless mouse and keyboard combo. You may have to hook up a corded keyboard at first. Is this a usb wireless device or ps2 (round kind)? Once you have made sure that all your batteries are in good condition, plug all devices in before you start your computer. and be sure that they are in a good distance from the receiver. wait till your operating system has loaded and is either at the desktop or sign in with password window. Hold down the button on the receiver and keep it pressed down while you press the connect button on the keyboard then the mouse. Do not let go of the receiver button till you have connected both devices. Did this work? If keyboard still does not work, with the corded keyboard plugged in, first make sure you have all the software for your brand of keyboard and mouse combo. Once that is done, install it. Go to control panel..keyboard or if the software takes you to a set up area. Follow their prompts. This should work.
Feb 06, 2011 | Dell Computers & Internet
Hi . .. I want to use this KVM switch to connect
The GCS632U has keyboard and mouse emulation that may not work with all wireless combos. If your wireless combo is going to work the single USB connection would need to go into the keyboard port as that is the only port that will recognize the hot key switching commands. If the wireless combo still has problems then try using a USB wired keyboard to ensure the GCS632U is working correctly.
Mar 18, 2010 | IOGear GCS632U 2-port KVM Switch
Wireless mouse not working
You can use them both at the same time.Make sure the batteries are good.There should be a sync button on the bottom of the mouse.you need to check the wireless receiver to see if there is a button on there as well.If there is you need to push the button on there first,then the mouse.
The easiest way to fix a sticking key is to remove it from the keyboard and clean it out.Then replace the key.
Sep 02, 2009 | Dynex Optical Mouse
I can't figure out how to change the batteries in the mouse.
right behind the right and left buttons apply slight pressure and move to either side to access the batteries
May 26, 2009 | Logitech Wireless Freedom Keyboard and...
HP Expansion Base - Wireless Keyboard & Mouse Set-Up
Any Radio Shack or Best Buy for sure and even Staples and the like will have wireless devices that should help you figure out how to hook up what you have. For that matter a new set might be so inexpensive as to save you the hassle.
Good luck,
JR
Feb 26, 2009 | HP xb3000 (417329-001) Docking Station
Logitech Mouse Not Working
Normal 0 Are your batteries in the Keyboard and mouse good?
You probably have gotten it working by now but here is a way to get it work if not.
Press the Receiver button a(and the lights will start flashing, then if its the Keyboard that isn't working, press the small RESET/CONNECT button on the back of the board to connect.
If its the MOUSE do the same except push the small RESET?CONNECT button on the back of the mouse to connect. Then they should work properly. Hope this helps. Bud
Dec 23, 2008 | Logitech S 510 (967555) (DH967555)...
Computers & Internet Logo
143 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
